RTEMS 5.2
- w -
- w : APSR_Type, CONTROL_Type, IPSR_Type, tlb_sfsr_reg, tte_data, xPSR_Type
- Wait : _Thread_Control, Scheduler_Node, Thread_Proxy_control
- Wait_queue : CORE_barrier_Control, CORE_message_queue_Control, CORE_mutex_Control, CORE_semaphore_Control, Semaphore_Control
- waiters : rtems_bdbuf_buffer
- was_created_with_inherited_scheduler : _Thread_Control
- wasted_size : rtems_jffs2_info
- Watchdog : Per_CPU_Control
- Watchdogs : Watchdog_Header
- WDT_CR : Wdt
- WDT_MR : Wdt
- WDT_SR : Wdt
- wimg : bsp_tlb_entry_t
- wimge : bsp_tlb_entry_t
- WinAAttributes : RTEMS_PACKED
- WinASegment : RTEMS_PACKED
- WinBAttributes : RTEMS_PACKED
- WinBSegment : RTEMS_PACKED
- WinFuncPtr : RTEMS_PACKED
- WinGranularity : RTEMS_PACKED
- WinSize : RTEMS_PACKED
- write : i2c_dev, rtems_fdisk_driver_handlers, rtems_jffs2_flash_control, rtems_nvdisk_driver_handlers, rtems_termios_device_handler
- write_blocks : rtems_blkdev_stats
- write_errors : rtems_blkdev_stats
- write_reg : sc16is752_context
- write_req : rtems_bdbuf_swapout_transfer
- write_transfers : rtems_blkdev_stats
- wrprot_enable : ALT_QSPI_DEV_SIZE_CONFIG_s
- wRxBufferSize : _GmacInit
- wRxI : _GmacQueueDriver
- wRxListSize : _GmacQueueDriver
- wRxSize : _GmacInit
- wTxBufferSize : _GmacInit, _GmacQueueDriver
- wTxHead : _GmacQueueDriver
- wTxListSize : _GmacQueueDriver
- wTxSize : _GmacInit
- wTxTail : _GmacQueueDriver
