Here is a list of all documented functions, variables, defines, enums, and typedefs with links to the documentation:
- b -
- BARRIER_INFORMATION_DEFINE : barrierdata.h
- Barrier_MP_Remote_operations : barriermp.h
- BAUDRATE : bsp.h
- BBB_CONTROL_CONF_GPMC_AD : bbb-pwm.h
- BBB_DIGITAL_IN : bbb-gpio.h
- BBB_LED_USR0 : beagleboneblack.h
- BBB_PUDEN : bbb-gpio.h
- BBB_PWMSS : bbb-pwm.h
- BCB : uart.h
- BCM2835_EMMC_BASE : raspberrypi.h
- BCM2835_GPU_TIMER_BASE : raspberrypi.h
- beagle_pwm_disable() : bbb-pwm.h
- beagle_pwm_enable() : bbb-pwm.h
- beagle_pwm_init() : bbb-pwm.h
- beagle_pwm_pinmux_setup() : bbb-pwm.h
- beagle_pwmss_is_running() : bbb-pwm.h
- beagle_setup_mmu_and_cache() : bsp.h
- BEGIN_BSS : asm.h
- BEGIN_CODE : asm.h
- BEGIN_CODE_DCL : asm.h
- BEGIN_DATA : asm.h
- BEGIN_DATA_DCL : asm.h
- benchmark_timer_disable_subtracting_average_overhead() : btimer.c, timer.c, btimer.c, timer.c, btimer.c, timer.c, btimer.c, btimer-ppc-dec.c, btimer.c, btimer.h
- benchmark_timer_empty_function() : btimer.h
- benchmark_timer_initialize() : btimer.c, timer.c, btimer.c, timer.c, btimer.c, timer.c, btimer.c, btimer-ppc-dec.c, btimer.c, btimer.h
- benchmark_timer_read() : btimer.c, timer.c, btimer.c, timer.c, btimer.c, timer.c, btimer.c, btimer-ppc-dec.c, btimer.c, btimer.h
- benchmark_timer_t : btimer.h
- bfin_interrupt_init() : interrupt.h, interrupt.c
- bfin_interrupt_register() : interrupt.h, interrupt.c
- bfin_interrupt_unregister() : interrupt.h, interrupt.c
- BI : uart.h
- BITMAPINFOHEADER : bmp.h
- BITSET_DEFINE() : processormask.h
- BLOCK_ERASE_32K : s25fl1.h
- BLOCK_ERASE_4K : s25fl1.h
- BLOCK_ERASE_64K : s25fl1.h
- BMP_TYPE : bmp.h
- BMPHeader : bmp.h
- BNRY : wd80x3.h
- BOARD_ConfigureSdram() : board_memories.h, board_memories.c
- BOARD_SDRAM_BUSWIDTH : sdramc.h
- boot_card() : bootcard.h, bootcard.c
- BREAK_INSTR : mips_opcode.h
- BSC_CORE_CLK_HZ : i2c.h
- bsp_boot_cmdline : bootcard.h, bootcard.c, bspcmdline_get.c, bspcmdline_getparamraw.c
- bsp_clicks_per_usec : bspstart.c, bsp.h, bspstart.c, clock-ppc403.c, bspstart.c
- bsp_clock_speed : bsp.h, bspstart.c, bsp.h
- BSP_connect_clock_handler() : bsp.h
- bsp_console_select() : console_select.c, serial.h, legacy-console-select.c
- BSP_Convert_decrementer : bsp.h
- bsp_fdt_map_intr() : bspstart.c
- BSP_get_current_rtems_irq_handler() : irq-legacy.c, irq.h
- bsp_get_serial_mouse_device() : serial_mouse.h
- bsp_idle_thread() : bsp.h, bspidle.c, bsp.h, bspidle.c, bsp.h, bspidle.c, bsp.h, idle-thread.c, bsp.h, bspidle.c, bsp.h
- BSP_install_rtems_irq_handler() : irq-legacy.c, irq.h
- BSP_install_rtems_shared_irq_handler() : irq-legacy.c
- bsp_interrupt_dispatch() : irq.c
- bsp_interrupt_facility_initialize() : irq.c, irq-generic.h, irq.c, ppc-irq-generic.c, irq.c, irq-default.c
- bsp_interrupt_handler_default() : irq.c, irq-generic.h, irq.c, irq-default-handler.c
- bsp_interrupt_handler_is_empty() : irq-generic.h, irq-generic.c
- bsp_interrupt_initialize() : irq-generic.h, irq-generic.c
- bsp_interrupt_report() : irq-info.h, irq-info.c
- bsp_interrupt_report_with_plugin() : irq-info.h, irq-info.c
- bsp_interrupt_shell_command : irq-info.h, irq-shell.c
- bsp_interrupt_vector_disable() : irq.c, irq-generic.h, irq.c, ppc-irq-generic.c, irq.c, irq-default.c
- bsp_interrupt_vector_enable() : irq.c, irq-generic.h, irq.c, ppc-irq-generic.c, irq.c, irq-default.c
- BSP_INTERRUPT_VECTOR_MAX : irq-default.h, irq.h
- BSP_INTERRUPT_VECTOR_MIN : irq-default.h, irq.h
- BSP_irq_ack_at_i8259s() : i8259.h, i8259.c
- BSP_irq_disable_at_i8259s() : i8259.h, i8259.c
- BSP_irq_enable_at_i8259s() : i8259.h, i8259.c
- BSP_irq_enabled_at_i8259s() : i8259.h, i8259.c
- BSP_IRQ_VECTOR_BASE : irq.h
- BSP_MAIN_FREQ : bsp.h
- BSP_MAX_INT : bsp.h
- BSP_OSC_FREQ : bsp.h
- BSP_output_char : console-config.c, printk-support.c, console.c, printk_support.c, console-config.c, console-generic.c, console-config.c, console-debugio.c, printk-dummy.c, uart-output-char.c, debugputs.c, bspIo.h
- BSP_output_char_function_type : bspIo.h
- BSP_PERIODIC_TIMER : irq.h
- BSP_poll_char : console-config.c, printk-support.c, console.c, printk_support.c, console-config.c, console-generic.c, console-config.c, console-debugio.c, printk-dummy.c, uart-output-char.c, debugputs.c, bspIo.h
- BSP_polling_getchar_function_type : bspIo.h
- BSP_remove_rtems_irq_handler() : irq-legacy.c, irq.h
- bsp_restart() : bsp.h, restart.c
- bsp_rtc_get_time() : rtc-config.c
- bsp_rtc_initialize() : rtc-config.c
- bsp_rtc_probe() : rtc-config.c
- bsp_rtc_set_time() : rtc-config.c
- BSP_rtems_irq_mngt_get() : irq-legacy.c, irq.h
- BSP_rtems_irq_mngt_set() : irq-legacy.c, irq.h
- BSP_SHARED_HANDLER_SUPPORT : irq.h
- bsp_stack_allocate() : stackalloc.h, stackalloc.c
- bsp_stack_allocate_init() : stackalloc.h, stackalloc.c
- bsp_stack_free() : stackalloc.h, stackalloc.c
- bsp_start_hook_0() : start.h
- bsp_start_hook_1() : start.h
- bsp_start_memcpy() : start.h
- bsp_start_memcpy_arm() : start.h
- bsp_start_on_secondary_processor() : bootcard.h, bspsmp.c
- bsp_start_zero() : start.h
- bsp_start_zero_begin : start.h
- bsp_start_zero_end : start.h
- bsp_start_zero_size : start.h
- BSP_UART_COM1 : uart.h
- BSP_UART_INTR_CTRL_DISABLE : uart.h
- BSP_UART_INTR_CTRL_ENABLE : uart.h
- BSP_UART_INTR_CTRL_GDB : uart.h
- BSP_UART_INTR_CTRL_TERMIOS : uart.h
- BSP_UART_STATUS_BREAK : uart.h
- BSP_UART_STATUS_CHAR : uart.h
- BSP_UART_STATUS_ERROR : uart.h
- BSP_UART_STATUS_NOCHAR : uart.h
- BusFault_Handler() : exceptions.c
- BUTTON : mouse_parser.h
- BYTE_PAGE_PROGRAM : s25fl1.h
