RTEMS 5.2
BSP startup. More...
#include <libfdt.h>#include <rtems.h>#include <rtems/config.h>#include <rtems/counter.h>#include <rtems/sysinit.h>#include <libcpu/powerpc-utility.h>#include <bsp.h>#include <bsp/bootcard.h>#include <bsp/console-termios.h>#include <bsp/fatal.h>#include <bsp/fdt.h>#include <bsp/intercom.h>#include <bsp/irq-generic.h>#include <bsp/linker-symbols.h>#include <bsp/mmu.h>#include <bsp/qoriq.h>#include <bsp/vectors.h>Macros | |
| #define | MTIVPR(base) __asm__ volatile ("mtivpr %0" : : "r" (base)) |
| #define | VECTOR_TABLE_ENTRY_SIZE 16 |
| #define | MTIVOR(vec, offset) |
| LINKER_SYMBOL (bsp_exc_vector_base) | |
| uint32_t | _CPU_Counter_frequency (void) |
| Returns the current CPU counter frequency in Hz. More... | |
| void | qoriq_initialize_exceptions (void *interrupt_stack_begin) |
| void | bsp_start (void) |
| uint32_t | bsp_fdt_map_intr (const uint32_t *intr, size_t icells) |
| Maps the interrupt number of the FDT to the interrupt vector used by the interrupt management. More... | |
| qoriq_start_spin_table * | qoriq_start_spin_table_addr [QORIQ_CPU_COUNT/QORIQ_THREAD_COUNT] |
| unsigned int | BSP_bus_frequency |
| uint32_t | bsp_time_base_frequency |
| uint32_t | qoriq_clock_frequency |
BSP startup.
| #define MTIVOR | ( | vec, | |
| offset | |||
| uint32_t bsp_fdt_map_intr | ( | const uint32_t * | intr, |
| size_t | icells | ||
This function is used by the libbsd to implement the OFW_BUS_MAP_INTR bus method.
| [in] | intr | The FDT interrupt number cells. |
| [in] | icells | The FDT interrupt cell count. |
