RTEMS 5.2
qoriq.h
1
9/*
10 * Copyright (c) 2010-2015 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef LIBBSP_POWERPC_QORIQ_QORIQ_H
24#define LIBBSP_POWERPC_QORIQ_QORIQ_H
25
26#include <bsp.h>
27#include <bsp/tsec.h>
28#include <bsp/utility.h>
29
30#ifdef __cplusplus
31extern "C" {
32#endif /* __cplusplus */
33
34#define QORIQ_FILL(a, b, s) uint8_t reserved_ ## b [b - a - sizeof(s)]
35#define QORIQ_RESERVE(a, b) uint8_t reserved_ ## b [b - a]
36
37typedef struct {
38 uint32_t reg;
39 QORIQ_FILL(0x00000, 0x00010, uint32_t);
41
42typedef struct {
43 uint32_t ccr;
44 QORIQ_FILL(0x00000, 0x00010, uint32_t);
45 uint32_t bcr;
46 QORIQ_FILL(0x00010, 0x00020, uint32_t);
47 uint32_t vpr;
48 QORIQ_FILL(0x00020, 0x00030, uint32_t);
49 uint32_t dr;
50 QORIQ_FILL(0x00030, 0x00040, uint32_t);
52
53#define GTCCR_TOG BSP_BBIT32(0)
54#define GTCCR_COUNT_GET(reg) BSP_BFLD32GET(reg, 1, 31)
55
56#define GTBCR_CI BSP_BBIT32(0)
57#define GTBCR_COUNT(val) BSP_BFLD32(val, 1, 31)
58#define GTBCR_COUNT_GET(reg) BSP_BFLD32GET(reg, 1, 31)
59#define GTBCR_COUNT_SET(reg, val) BSP_BFLD32SET(reg, val, 1, 31)
60
61typedef struct {
62 uint32_t misc;
63 QORIQ_FILL(0x00000, 0x00010, uint32_t);
64 uint32_t internal [2];
65 QORIQ_FILL(0x00010, 0x00020, uint32_t [2]);
67
68typedef struct {
69 uint32_t vpr;
70 QORIQ_FILL(0x00000, 0x00010, uint32_t);
71 uint32_t dr;
72 QORIQ_FILL(0x00010, 0x00020, uint32_t);
74
75typedef struct {
76 QORIQ_RESERVE(0x00000, 0x00040);
77 qoriq_pic_reg ipidr [4];
78 uint32_t ctpr;
79 QORIQ_FILL(0x00080, 0x00090, uint32_t);
80 uint32_t whoami;
81 QORIQ_FILL(0x00090, 0x000a0, uint32_t);
82 uint32_t iack;
83 QORIQ_FILL(0x000a0, 0x000b0, uint32_t);
84 uint32_t eoi;
85 QORIQ_FILL(0x000b0, 0x01000, uint32_t);
87
88typedef struct {
89 uint32_t brr1;
90 QORIQ_FILL(0x00000, 0x00010, uint32_t);
91 uint32_t brr2;
92 QORIQ_FILL(0x00010, 0x00040, uint32_t);
93 qoriq_pic_reg ipidr [4];
94 uint32_t ctpr;
95 QORIQ_FILL(0x00080, 0x00090, uint32_t);
96 uint32_t whoami;
97 QORIQ_FILL(0x00090, 0x000a0, uint32_t);
98 uint32_t iack;
99 QORIQ_FILL(0x000a0, 0x000b0, uint32_t);
100 uint32_t eoi;
101 QORIQ_FILL(0x000b0, 0x01000, uint32_t);
102 uint32_t frr;
103 QORIQ_FILL(0x01000, 0x01020, uint32_t);
104 uint32_t gcr;
105 QORIQ_FILL(0x01020, 0x01080, uint32_t);
106 uint32_t vir;
107 QORIQ_FILL(0x01080, 0x01090, uint32_t);
108 uint32_t pir;
109 QORIQ_FILL(0x01090, 0x010a0, uint32_t);
110 qoriq_pic_reg ipivpr [4];
111 uint32_t svr;
112 QORIQ_FILL(0x010e0, 0x010f0, uint32_t);
113 uint32_t tfrra;
114 QORIQ_FILL(0x010f0, 0x01100, uint32_t);
116 QORIQ_RESERVE(0x01200, 0x01300);
117 uint32_t tcra;
118 QORIQ_FILL(0x01300, 0x01308, uint32_t);
119 uint32_t erqsr;
120 QORIQ_FILL(0x01308, 0x01310, uint32_t);
123 qoriq_pic_bit_field pm [4];
124 QORIQ_RESERVE(0x013d0, 0x01400);
125 qoriq_pic_reg msgr03 [4];
126 QORIQ_RESERVE(0x01440, 0x01500);
127 uint32_t mer03;
128 QORIQ_FILL(0x01500, 0x01510, uint32_t);
129 uint32_t msr03;
130 QORIQ_FILL(0x01510, 0x01600, uint32_t);
131 qoriq_pic_reg msir [8];
132 QORIQ_RESERVE(0x01680, 0x01720);
133 uint32_t msisr;
134 QORIQ_FILL(0x01720, 0x01740, uint32_t);
135 uint32_t msiir;
136 QORIQ_FILL(0x01740, 0x020f0, uint32_t);
137 uint32_t tfrrb;
138 QORIQ_FILL(0x020f0, 0x02100, uint32_t);
140 QORIQ_RESERVE(0x02200, 0x02300);
141 uint32_t tcrb;
142 QORIQ_FILL(0x02300, 0x02400, uint32_t);
143 qoriq_pic_reg msgr47 [4];
144 QORIQ_RESERVE(0x02440, 0x02500);
145 uint32_t mer47;
146 QORIQ_FILL(0x02500, 0x02510, uint32_t);
147 uint32_t msr47;
148 QORIQ_FILL(0x02510, 0x10000, uint32_t);
149 qoriq_pic_src_cfg ei [12];
150 QORIQ_RESERVE(0x10180, 0x10200);
151 qoriq_pic_src_cfg ii_0 [160];
152 qoriq_pic_src_cfg mi [8];
153 QORIQ_RESERVE(0x11700, 0x11c00);
154 qoriq_pic_src_cfg msi [8];
155 QORIQ_RESERVE(0x11d00, 0x13000);
156 qoriq_pic_src_cfg ii_1 [96];
157 QORIQ_RESERVE(0x13c00, 0x20000);
158 qoriq_pic_per_cpu per_cpu [2];
159} qoriq_pic;
160
161#define GTTCR_ROVR(val) BSP_BFLD32(val, 5, 7)
162#define GTTCR_ROVR_GET(reg) BSP_BFLD32GET(reg, 5, 7)
163#define GTTCR_ROVR_SET(reg, val) BSP_BFLD32SET(reg, val, 5, 7)
164#define GTTCR_RTM BSP_BBIT32(15)
165#define GTTCR_CLKR(val) BSP_BFLD32(val, 22, 23)
166#define GTTCR_CLKR_GET(reg) BSP_BFLD32GET(reg, 22, 23)
167#define GTTCR_CLKR_SET(reg, val) BSP_BFLD32SET(reg, val, 22, 23)
168#define GTTCR_CASC(val) BSP_BFLD32(val, 29, 31)
169#define GTTCR_CASC_GET(reg) BSP_BFLD32GET(reg, 29, 31)
170#define GTTCR_CASC_SET(reg, val) BSP_BFLD32SET(reg, val, 29, 31)
171
172typedef struct {
173} qoriq_uart;
174
175typedef struct {
176 uint32_t gpdir;
177 uint32_t gpodr;
178 uint32_t gpdat;
179 uint32_t gpier;
180 uint32_t gpimr;
181 uint32_t gpicr;
182 uint32_t gpibe;
183 QORIQ_RESERVE(0x001c, 0x1000);
184} qoriq_gpio;
185
186typedef struct {
187 QORIQ_RESERVE(0x000, 0x100);
188 uint16_t caplength;
189 uint16_t hciversion;
190 uint32_t hcsparams;
191 uint32_t hccparams;
192 QORIQ_RESERVE(0x10c, 0x120);
193 uint32_t dciversion;
194 uint32_t dccparams;
195 QORIQ_RESERVE(0x128, 0x140);
196 uint32_t usbcmd;
197 uint32_t usbsts;
198 uint32_t usbintr;
199 uint32_t frindex;
200 QORIQ_RESERVE(0x150, 0x154);
201 union {
202 uint32_t periodiclistbase;
203 uint32_t deviceaddr;
204 } perbase_devaddr;
205 union {
206 uint32_t asynclistaddr;
207 uint32_t addr;
208 } async_addr;
209 QORIQ_RESERVE(0x15c, 0x160);
210 uint32_t burstsize;
211 uint32_t txfilltuning;
212 QORIQ_RESERVE(0x168, 0x170);
213 uint32_t viewport;
214 QORIQ_RESERVE(0x174, 0x180);
215 uint32_t configflag;
216 uint32_t portsc1;
217 QORIQ_RESERVE(0x188, 0x1a8);
218 uint32_t usbmode;
219 uint32_t endptsetupstat;
220 uint32_t endpointprime;
221 uint32_t endptflush;
222 uint32_t endptstatus;
223 uint32_t endptcomplete;
224 uint32_t endptctrl[6];
225 QORIQ_RESERVE(0x1d8, 0x400);
226 uint32_t snoop1;
227 uint32_t snoop2;
228 uint32_t age_cnt_thresh;
229 uint32_t pri_ctrl;
230 uint32_t si_ctrl;
231 QORIQ_RESERVE(0x414, 0x500);
232 uint32_t control;
233} qoriq_usb;
234
235typedef struct {
236 uint32_t dsaddr;
237 uint32_t blkattr;
238 uint32_t cmdarg;
239 uint32_t xfertyp;
240 uint32_t cmdrsp0;
241 uint32_t cmdrsp1;
242 uint32_t cmdrsp2;
243 uint32_t cmdrsp3;
244 uint32_t datport;
245 uint32_t prsstat;
246 uint32_t proctl;
247 uint32_t sysctl;
248 uint32_t irqstat;
249 uint32_t irqstaten;
250 uint32_t irqsigen;
251 uint32_t autoc12err;
252 uint32_t hostcapblt;
253 uint32_t wml;
254 QORIQ_FILL(0x00044, 0x00050, uint32_t);
255 uint32_t fevt;
256 QORIQ_FILL(0x00050, 0x000fc, uint32_t);
257 uint32_t hostver;
258 QORIQ_FILL(0x000fc, 0x0040c, uint32_t);
259 uint32_t dcr;
261
262#if QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT)
263
264typedef struct {
265 uint32_t ccsrbarh;
266 uint32_t ccsrbarl;
267 uint32_t ccsrar;
268 uint32_t altcbarh;
269 uint32_t altcbarl;
270 uint32_t altcar;
271 uint32_t bstrh;
272 uint32_t bstrl;
273 uint32_t bstar;
274} qoriq_lcc;
275
276#define LCC_BSTAR_EN BSP_BBIT32(0)
277
278typedef struct {
279 uint32_t lawbarh;
280 uint32_t lawbarl;
281 uint32_t lawar;
282 uint32_t reserved_0xc;
283} qoriq_law;
284
285typedef struct {
286 uint32_t reserved_0x0[640];
287 uint32_t qmbm_warmrst;
288} qoriq_dcfg;
289
290typedef struct {
291 QORIQ_RESERVE(0x0000, 0x1000);
292} qoriq_bman;
293
294typedef struct {
295 QORIQ_RESERVE(0x0000, 0x1000);
296} qoriq_qman;
297
298typedef struct {
299 QORIQ_RESERVE(0x000000, 0x100000);
300} qoriq_fman;
301
302typedef struct qoriq_ccsr {
303 qoriq_lcc lcc;
304 QORIQ_FILL(0x000000, 0x000c00, qoriq_lcc);
305 qoriq_law law [32];
306 QORIQ_FILL(0x000c00, 0x001000, qoriq_law [32]);
307 QORIQ_RESERVE(0x001000, 0x040000);
308 qoriq_pic pic;
309 QORIQ_FILL(0x040000, 0x070000, qoriq_pic);
310 QORIQ_RESERVE(0x070000, 0x0e0000);
311 qoriq_dcfg dcfg;
312 QORIQ_FILL(0x0e0000, 0x0e1000, qoriq_dcfg);
313 QORIQ_RESERVE(0x0e1000, 0x114000);
314 qoriq_esdhc esdhc;
315 QORIQ_FILL(0x114000, 0x115000, qoriq_esdhc);
316 QORIQ_RESERVE(0x115000, 0x11c500);
317 qoriq_uart uart_0;
318 QORIQ_FILL(0x11c500, 0x11c600, qoriq_uart);
319 qoriq_uart uart_1;
320 QORIQ_FILL(0x11c600, 0x11d500, qoriq_uart);
321 qoriq_uart uart_2;
322 QORIQ_FILL(0x11d500, 0x11d600, qoriq_uart);
323 qoriq_uart uart_3;
324 QORIQ_FILL(0x11d600, 0x11e000, qoriq_uart);
325 QORIQ_RESERVE(0x11e000, 0x130000);
326 qoriq_gpio gpio[4];
327 QORIQ_RESERVE(0x134000, 0x210000);
328 qoriq_usb usb_1;
329 QORIQ_FILL(0x210000, 0x211000, qoriq_usb);
330 QORIQ_RESERVE(0x211000, 0x318000);
331 qoriq_qman qman;
332 QORIQ_RESERVE(0x319000, 0x31a000);
333 qoriq_bman bman;
334 QORIQ_RESERVE(0x31b000, 0x400000);
335 qoriq_fman fman[2];
336 QORIQ_RESERVE(0x600000, 0x2000000);
337} qoriq_ccsr;
338
339#else /* QORIQ_CHIP_VARIANT */
340
341typedef struct {
342 uint32_t ccsrbar;
343 uint32_t reserved_0;
344 uint32_t altcbar;
345 uint32_t reserved_1;
346 uint32_t altcar;
347 uint32_t reserved_2 [3];
348 uint32_t bptr;
349} qoriq_lcc;
350
351#define CCSRBAR_BASE_ADDR(val) BSP_BFLD32(val, 8, 23)
352#define CCSRBAR_BASE_ADDR_GET(reg) BSP_BFLD32GET(reg, 8, 23)
353#define CCSRBAR_BASE_ADDR_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 23)
354
355#define ALTCBAR_BASE_ADDR(val) BSP_BFLD32(val, 8, 23)
356#define ALTCBAR_BASE_ADDR_GET(reg) BSP_BFLD32GET(reg, 8, 23)
357#define ALTCBAR_BASE_ADDR_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 23)
358
359#define ALTCAR_EN BSP_BBIT32(0)
360#define ALTCAR_TRGT_ID(val) BSP_BFLD32(val, 8, 11)
361#define ALTCAR_TRGT_ID_GET(reg) BSP_BFLD32GET(reg, 8, 11)
362#define ALTCAR_TRGT_ID_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 11)
363
364#define BPTR_EN BSP_BBIT32(0)
365#define BPTR_BOOT_PAGE(val) BSP_BFLD32(val, 8, 31)
366#define BPTR_BOOT_PAGE_GET(reg) BSP_BFLD32GET(reg, 8, 31)
367#define BPTR_BOOT_PAGE_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 31)
368
369typedef struct {
370 uint32_t bar;
371 uint32_t reserved_0;
372 uint32_t ar;
373 uint32_t reserved_1 [5];
374} qoriq_law;
375
376#define LAWBAR_BASE_ADDR(val) BSP_BFLD32(val, 8, 31)
377#define LAWBAR_BASE_ADDR_GET(reg) BSP_BFLD32GET(reg, 8, 31)
378#define LAWBAR_BASE_ADDR_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 31)
379
380#define LAWAR_EN BSP_BBIT32(0)
381#define LAWAR_TRGT(val) BSP_BFLD32(val, 8, 11)
382#define LAWAR_TRGT_GET(reg) BSP_BFLD32GET(reg, 8, 11)
383#define LAWAR_TRGT_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 11)
384#define LAWAR_SIZE(val) BSP_BFLD32(val, 26, 31)
385#define LAWAR_SIZE_GET(reg) BSP_BFLD32GET(reg, 26, 31)
386#define LAWAR_SIZE_SET(reg, val) BSP_BFLD32SET(reg, val, 26, 31)
387
388typedef struct {
389} qoriq_ecm;
390
391typedef struct {
393
394typedef struct {
395} qoriq_i2c;
396
397typedef struct {
399
400typedef struct {
401} qoriq_spi;
402
403typedef struct {
405
406typedef struct {
407} qoriq_tdm;
408
409typedef struct {
411
412typedef struct {
413} qoriq_dma;
414
415typedef struct {
417
418typedef struct {
419} qoriq_sec;
420
421typedef struct {
423
424typedef struct {
426
427typedef struct {
429
430typedef struct {
432
433typedef struct {
435
436typedef struct {
438
439typedef struct qoriq_ccsr {
440 qoriq_lcc lcc;
441 QORIQ_FILL(0x00000, 0x00c08, qoriq_lcc);
442 qoriq_law law [12];
443 QORIQ_FILL(0x00c08, 0x01000, qoriq_law [12]);
444 qoriq_ecm ecm;
445 QORIQ_FILL(0x01000, 0x02000, qoriq_ecm);
446 qoriq_ddr_controller ddr_controller;
447 QORIQ_FILL(0x02000, 0x03000, qoriq_ddr_controller);
449 QORIQ_FILL(0x03000, 0x04000, qoriq_i2c);
450 QORIQ_RESERVE(0x04000, 0x04500);
451 qoriq_uart uart_0;
452 QORIQ_FILL(0x04500, 0x04600, qoriq_uart);
453 qoriq_uart uart_1;
454 QORIQ_FILL(0x04600, 0x04700, qoriq_uart);
455 QORIQ_RESERVE(0x04700, 0x05000);
456 qoriq_local_bus local_bus;
457 QORIQ_FILL(0x05000, 0x06000, qoriq_local_bus);
458 qoriq_spi spi;
459 QORIQ_FILL(0x06000, 0x07000, qoriq_spi);
460 QORIQ_RESERVE(0x07000, 0x08000);
461 qoriq_pci_express pci_express_3;
462 QORIQ_FILL(0x08000, 0x09000, qoriq_pci_express);
463 qoriq_pci_express pci_express_2;
464 QORIQ_FILL(0x09000, 0x0a000, qoriq_pci_express);
465 qoriq_pci_express pci_express_1;
466 QORIQ_FILL(0x0a000, 0x0b000, qoriq_pci_express);
467 QORIQ_RESERVE(0x0b000, 0x0c000);
468 qoriq_dma dma_2;
469 QORIQ_FILL(0x0c000, 0x0d000, qoriq_dma);
470 QORIQ_RESERVE(0x0d000, 0x0f000);
471 qoriq_gpio gpio;
472 QORIQ_RESERVE(0x10000, 0x16000);
473 qoriq_tdm tdm;
474 QORIQ_FILL(0x16000, 0x17000, qoriq_tdm);
475 QORIQ_RESERVE(0x17000, 0x20000);
476 qoriq_l2_cache l2_cache;
477 QORIQ_FILL(0x20000, 0x21000, qoriq_l2_cache);
478 qoriq_dma dma_1;
479 QORIQ_FILL(0x21000, 0x22000, qoriq_dma);
480 qoriq_usb usb_1;
481 QORIQ_FILL(0x22000, 0x23000, qoriq_usb);
482 qoriq_usb usb_2;
483 QORIQ_FILL(0x23000, 0x24000, qoriq_usb);
484 tsec_registers tsec_1;
485 QORIQ_FILL(0x24000, 0x25000, tsec_registers);
486 tsec_registers tsec_2;
487 QORIQ_FILL(0x25000, 0x26000, tsec_registers);
488 tsec_registers tsec_3;
489 QORIQ_FILL(0x26000, 0x27000, tsec_registers);
490 QORIQ_RESERVE(0x27000, 0x2c000);
491 qoriq_tdm_dma tdm_dma;
492 QORIQ_FILL(0x2c000, 0x2d000, qoriq_tdm_dma);
493 QORIQ_RESERVE(0x2d000, 0x2e000);
494 qoriq_esdhc esdhc;
495 QORIQ_FILL(0x2e000, 0x2f000, qoriq_esdhc);
496 QORIQ_RESERVE(0x2f000, 0x30000);
497 qoriq_sec sec;
498 QORIQ_FILL(0x30000, 0x31000, qoriq_sec);
499 QORIQ_RESERVE(0x31000, 0x40000);
500 qoriq_pic pic;
501 QORIQ_FILL(0x40000, 0x80000, qoriq_pic);
502 QORIQ_RESERVE(0x80000, 0xb0000);
503 tsec_registers tsec_1_group_0;
504 QORIQ_FILL(0xb0000, 0xb1000, tsec_registers);
505 tsec_registers tsec_2_group_0;
506 QORIQ_FILL(0xb1000, 0xb2000, tsec_registers);
507 tsec_registers tsec_3_group_0;
508 QORIQ_FILL(0xb2000, 0xb3000, tsec_registers);
509 QORIQ_RESERVE(0xb3000, 0xb4000);
510 tsec_registers tsec_1_group_1;
511 QORIQ_FILL(0xb4000, 0xb5000, tsec_registers);
512 tsec_registers tsec_2_group_1;
513 QORIQ_FILL(0xb5000, 0xb6000, tsec_registers);
514 tsec_registers tsec_3_group_1;
515 QORIQ_FILL(0xb6000, 0xb7000, tsec_registers);
516 QORIQ_RESERVE(0xb7000, 0xc0000);
517 qoriq_serial_rapid_io serial_rapid_io;
518 QORIQ_FILL(0xc0000, 0xe0000, qoriq_serial_rapid_io);
519 qoriq_global_utilities global_utilities;
520 QORIQ_FILL(0xe0000, 0xe1000, qoriq_global_utilities);
521 qoriq_performance_monitor performance_monitor;
522 QORIQ_FILL(0xe1000, 0xe2000, qoriq_performance_monitor);
523 qoriq_debug_watchpoint debug_watchpoint;
524 QORIQ_FILL(0xe2000, 0xe3000, qoriq_debug_watchpoint);
525 qoriq_serdes serdes;
526 QORIQ_FILL(0xe3000, 0xe4000, qoriq_serdes);
527 QORIQ_RESERVE(0xe4000, 0xf0000);
528 qoriq_boot_rom boot_rom;
529 QORIQ_FILL(0xf0000, 0x100000, qoriq_boot_rom);
530} qoriq_ccsr;
531
532#endif /* QORIQ_CHIP_VARIANT */
533
534extern volatile qoriq_ccsr qoriq;
535
536#if QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT)
537extern uint8_t qoriq_bman_portal[2][16777216];
538extern uint8_t qoriq_qman_portal[2][16777216];
539
540void qoriq_clear_ce_portal(void *base, size_t size);
541void qoriq_clear_ci_portal(void *base, size_t size);
542#endif
543
544static inline void qoriq_reset_qman_and_bman(void)
545{
546#if QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT)
547 qoriq.dcfg.qmbm_warmrst = 0x3;
548
549 while ((qoriq.dcfg.qmbm_warmrst & 0x3) != 0) {
550 /* Wait for reset done */
551 }
552#endif
553}
554
555#ifdef __cplusplus
556}
557#endif /* __cplusplus */
558
559#endif /* LIBBSP_POWERPC_QORIQ_QORIQ_H */
Utility macros.
Definition: intercom.c:74
Definition: 8xx_immap.h:216
Definition: qoriq.h:436
Definition: qoriq.h:439
Definition: qoriq.h:391
Definition: qoriq.h:430
Definition: qoriq.h:412
Definition: qoriq.h:388
Definition: qoriq.h:235
Definition: qoriq.h:424
Definition: qoriq.h:175
Definition: qoriq.h:394
Definition: qoriq.h:409
Definition: qoriq.h:369
Definition: qoriq.h:341
Definition: qoriq.h:397
Definition: qoriq.h:403
Definition: qoriq.h:427
Definition: qoriq.h:61
Definition: qoriq.h:75
Definition: qoriq.h:37
Definition: qoriq.h:68
Definition: qoriq.h:88
Definition: qoriq.h:418
Definition: qoriq.h:433
Definition: qoriq.h:421
Definition: qoriq.h:400
Definition: qoriq.h:415
Definition: qoriq.h:406
Definition: qoriq.h:172
Definition: qoriq.h:186
Definition: tsec.h:89
unsigned size
Definition: tte.h:1
