RTEMS 5.2
Data Structures | Macros | Typedefs | Variables
qoriq.h File Reference
QorIQ Configuration, Control and Status Registers. More...
#include <bsp.h>
#include <bsp/tsec.h>
#include <bsp/utility.h>
struct  qoriq_pic_reg
struct  qoriq_pic_global_timer
struct  qoriq_pic_bit_field
struct  qoriq_pic_src_cfg
struct  qoriq_pic_per_cpu
struct  qoriq_pic
struct  qoriq_uart
struct  qoriq_gpio
struct  qoriq_usb
struct  qoriq_esdhc
struct  qoriq_lcc
struct  qoriq_law
struct  qoriq_ecm
struct  qoriq_ddr_controller
struct  qoriq_i2c
struct  qoriq_local_bus
struct  qoriq_spi
struct  qoriq_pci_express
struct  qoriq_tdm
struct  qoriq_l2_cache
struct  qoriq_dma
struct  qoriq_tdm_dma
struct  qoriq_sec
struct  qoriq_serial_rapid_io
struct  qoriq_global_utilities
struct  qoriq_performance_monitor
struct  qoriq_debug_watchpoint
struct  qoriq_serdes
struct  qoriq_boot_rom
struct  qoriq_ccsr
#define QORIQ_FILL(a, b, s)   uint8_t reserved_ ## b [b - a - sizeof(s)]
#define QORIQ_RESERVE(a, b)   uint8_t reserved_ ## b [b - a]
#define GTCCR_TOG   BSP_BBIT32(0)
#define GTCCR_COUNT_GET(reg)   BSP_BFLD32GET(reg, 1, 31)
#define GTBCR_CI   BSP_BBIT32(0)
#define GTBCR_COUNT(val)   BSP_BFLD32(val, 1, 31)
#define GTBCR_COUNT_GET(reg)   BSP_BFLD32GET(reg, 1, 31)
#define GTBCR_COUNT_SET(reg, val)   BSP_BFLD32SET(reg, val, 1, 31)
#define GTTCR_ROVR(val)   BSP_BFLD32(val, 5, 7)
#define GTTCR_ROVR_GET(reg)   BSP_BFLD32GET(reg, 5, 7)
#define GTTCR_ROVR_SET(reg, val)   BSP_BFLD32SET(reg, val, 5, 7)
#define GTTCR_RTM   BSP_BBIT32(15)
#define GTTCR_CLKR(val)   BSP_BFLD32(val, 22, 23)
#define GTTCR_CLKR_GET(reg)   BSP_BFLD32GET(reg, 22, 23)
#define GTTCR_CLKR_SET(reg, val)   BSP_BFLD32SET(reg, val, 22, 23)
#define GTTCR_CASC(val)   BSP_BFLD32(val, 29, 31)
#define GTTCR_CASC_GET(reg)   BSP_BFLD32GET(reg, 29, 31)
#define GTTCR_CASC_SET(reg, val)   BSP_BFLD32SET(reg, val, 29, 31)
#define CCSRBAR_BASE_ADDR(val)   BSP_BFLD32(val, 8, 23)
#define CCSRBAR_BASE_ADDR_GET(reg)   BSP_BFLD32GET(reg, 8, 23)
#define CCSRBAR_BASE_ADDR_SET(reg, val)   BSP_BFLD32SET(reg, val, 8, 23)
#define ALTCBAR_BASE_ADDR(val)   BSP_BFLD32(val, 8, 23)
#define ALTCBAR_BASE_ADDR_GET(reg)   BSP_BFLD32GET(reg, 8, 23)
#define ALTCBAR_BASE_ADDR_SET(reg, val)   BSP_BFLD32SET(reg, val, 8, 23)
#define ALTCAR_EN   BSP_BBIT32(0)
#define ALTCAR_TRGT_ID(val)   BSP_BFLD32(val, 8, 11)
#define ALTCAR_TRGT_ID_GET(reg)   BSP_BFLD32GET(reg, 8, 11)
#define ALTCAR_TRGT_ID_SET(reg, val)   BSP_BFLD32SET(reg, val, 8, 11)
#define BPTR_EN   BSP_BBIT32(0)
#define BPTR_BOOT_PAGE(val)   BSP_BFLD32(val, 8, 31)
#define BPTR_BOOT_PAGE_GET(reg)   BSP_BFLD32GET(reg, 8, 31)
#define BPTR_BOOT_PAGE_SET(reg, val)   BSP_BFLD32SET(reg, val, 8, 31)
#define LAWBAR_BASE_ADDR(val)   BSP_BFLD32(val, 8, 31)
#define LAWBAR_BASE_ADDR_GET(reg)   BSP_BFLD32GET(reg, 8, 31)
#define LAWBAR_BASE_ADDR_SET(reg, val)   BSP_BFLD32SET(reg, val, 8, 31)
#define LAWAR_EN   BSP_BBIT32(0)
#define LAWAR_TRGT(val)   BSP_BFLD32(val, 8, 11)
#define LAWAR_TRGT_GET(reg)   BSP_BFLD32GET(reg, 8, 11)
#define LAWAR_TRGT_SET(reg, val)   BSP_BFLD32SET(reg, val, 8, 11)
#define LAWAR_SIZE(val)   BSP_BFLD32(val, 26, 31)
#define LAWAR_SIZE_GET(reg)   BSP_BFLD32GET(reg, 26, 31)
#define LAWAR_SIZE_SET(reg, val)   BSP_BFLD32SET(reg, val, 26, 31)
typedef struct qoriq_ccsr qoriq_ccsr
volatile qoriq_ccsr qoriq
