RTEMS 5.2
Modules | Files | Data Structures | Macros | Functions | Variables
NXP QorIQ Board Support Package. More...
 QorIQ - Inter-Processor Communication Support
 Inter-processor communication support.
 QorIQ - Interrupt Support
 Interrupt support.
 QorIQ - MMU Support
 MMU support.
 QorIQ - UART to Intercom Bridge Support
 UART to Intercom bridge support.
file  btimer.c
 QorIQ benchmark timer.
file  clock-config.c
 QorIQ clock configuration.
file  console-config.c
 Console configuration.
file  bsp.h
 Global BSP definitions.
file  qoriq.h
 QorIQ Configuration, Control and Status Registers.
file  tsec-config.h
 TSEC configuration.
file  tm27.h
 Support file for Timer Test 27.
file  irq.c
 Interrupt implementation.
file  network.c
 Network configuration.
file  rtc-config.c
 RTC configuration.
file  bspreset.c
 BSP reset.
file  bsprestart.c
 BSP restart.
file  bspstart.c
 BSP startup.
struct  qoriq_start_spin_table
#define QORIQ_THREAD_COUNT   QORIQ_PHYSICAL_THREAD_COUNT
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_FDT_IS_SUPPORTED
#define QORIQ_CHIP(alpha, num)   ((alpha) * 10000 + (num))
#define QORIQ_CHIP_P1020   QORIQ_CHIP('P', 1020)
#define QORIQ_CHIP_T2080   QORIQ_CHIP('T', 2080)
#define QORIQ_CHIP_T4240   QORIQ_CHIP('T', 4240)
#define QORIQ_CHIP_VARIANT   QORIQ_CHIP(QORIQ_CHIP_SERIES, QORIQ_CHIP_NUMBER)
#define QORIQ_CHIP_IS_T_VARIANT(variant)   ((variant) / 10000 == 'T')
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   BSP_tsec_attach
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH4   qoriq_if_intercom_attach_detach
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "tsec1"
#define RTEMS_BSP_NETWORK_DRIVER_NAME2   "tsec2"
#define RTEMS_BSP_NETWORK_DRIVER_NAME3   "tsec3"
#define RTEMS_BSP_NETWORK_DRIVER_NAME4   "intercom1"
int BSP_tsec_attach (struct rtems_bsdnet_ifconfig *config, int attaching)
int qoriq_if_intercom_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching)
void bsp_restart (void *addr) RTEMS_NO_RETURN
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task. More...
void qoriq_start_thread (struct Per_CPU_Control *)
void qoriq_restart_secondary_processor (const qoriq_start_spin_table *spin_table) RTEMS_NO_RETURN
void qoriq_initialize_exceptions (void *interrupt_stack_begin)
void qoriq_decrementer_dispatch (void)
unsigned BSP_bus_frequency
qoriq_start_spin_tableqoriq_start_spin_table_addr [QORIQ_CPU_COUNT/QORIQ_THREAD_COUNT]
uint32_t bsp_time_base_frequency
uint32_t qoriq_clock_frequency
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
Evaluate Configuration Options.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
#include <bsp.h>
