RTEMS 5.2
BeagleBone Black PWM support definitions. More...
#define | BBB_CONTROL_CONF_GPMC_AD(n) (0x800 + (n * 4)) |
BeagleBone Black PWM Macros. More... | |
#define | BBB_CONTROL_CONF_LCD_DATA(n) (0x8a0 + (n * 4)) |
#define | BBB_P8_13_MUX_PWM 4 |
#define | BBB_P8_19_MUX_PWM 4 |
#define | BBB_P8_45_MUX_PWM 3 |
#define | BBB_P8_46_MUX_PWM 3 |
#define | BBB_P8_34_MUX_PWM 2 |
#define | BBB_P8_36_MUX_PWM 2 |
#define | BBB_P9_14_MUX_PWM 6 |
#define | BBB_P9_16_MUX_PWM 6 |
#define | BBB_P9_21_MUX_PWM 3 |
#define | BBB_P9_22_MUX_PWM 3 |
#define | BBB_P9_29_MUX_PWM 1 |
#define | BBB_P9_31_MUX_PWM 1 |
#define | BBB_PWM_FREQ_THRESHOLD 0.5f |
Enumerations | |
enum | BBB_PWMSS { BBB_PWMSS0 = 0 , BBB_PWMSS1 , BBB_PWMSS2 , BBB_PWMSS_COUNT } |
The set of possible PWM subsystem module. More... | |
enum | bbb_pwm_pin_t { BBB_P8_13_2B = 3 , BBB_P8_19_2A , BBB_P8_45_2A , BBB_P8_46_2B , BBB_P8_34_1B , BBB_P8_36_1A , BBB_P9_14_1A , BBB_P9_16_1B , BBB_P9_21_0B , BBB_P9_22_0A , BBB_P9_29_0B , BBB_P9_31_0A } |
bool | beagle_pwm_init (BBB_PWMSS pwmss_id) |
BeagleBone Black PWM API. More... | |
int | beagle_pwm_configure (BBB_PWMSS pwm_id, float pwm_freq, float duty_a, float duty_b) |
bool | beagle_pwm_enable (BBB_PWMSS pwmid) |
This API enables the particular PWM module. More... | |
bool | beagle_pwm_disable (BBB_PWMSS pwmid) |
This API disables the particular PWM module. More... | |
bool | beagle_pwm_pinmux_setup (bbb_pwm_pin_t pin_no, BBB_PWMSS pwm_id) |
This function enables pinmuxing for PWM module. More... | |
bool | beagle_pwmss_is_running (unsigned int pwmss_id) |
This function determines whether PWMSS-wide clocks enabled or not. More... | |
#define BBB_CONTROL_CONF_GPMC_AD | ( | n | ) | (0x800 + (n * 4)) |
Copyright (c) 2016 Punit Vara punit.nosp@m.vara.nosp@m.@gmai.nosp@m.l.co.nosp@m.m
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at http://www.rtems.org/license/LICENSE. Some constants are taken from https://github.com/VegetableAvenger/BBBIOlib/blob/master/BBBio_lib/BBBiolib_PWMSS.h
enum BBB_PWMSS |
Enumerated type to define various instance of pwm module.
bool beagle_pwm_disable | ( | BBB_PWMSS | pwmid | ) |
pwmid | It is the instance number of EPWM of pwm sub system. |
bool beagle_pwm_enable | ( | BBB_PWMSS | pwmid | ) |
bool beagle_pwm_init | ( | BBB_PWMSS | pwmss_id | ) |
This function intilizes clock for pwm sub system.
PWMSS_ID | It is the instance number of EPWM of pwm sub system. |
bool beagle_pwm_pinmux_setup | ( | bbb_pwm_pin_t | pin_no, |
BBB_PWMSS | pwm_id | ||
pin_no | It is individual pin at which freuqency need to be generated. It should be according to pwm sub system. |
pwm_id | It is the instance number of EPWM of pwmsubsystem. |
bool beagle_pwmss_is_running | ( | unsigned int | pwmss_id | ) |
pwmss_id | It is the instance number of PWMSS which clocks need to be checked. |
