RTEMS 5.2
Macros | Typedefs | Functions
Mouse Parser Engine
#define RBUTTON   MV_BUTTON_RIGHT
#define MBUTTON   MV_BUTTON_CENTER
#define LBUTTON   MV_BUTTON_LEFT
typedef int COORD
typedef unsigned int BUTTON
typedef void(* mouse_parser_enqueue_handler) (unsigned char *, size_t)
int mouse_parser_initialize (const char *type)
 Initialize the mouse parser engine. More...
void mouse_parser_enqueue (unsigned char *buffer, size_t size)
 Enqueue input to the mouse parser engine. More...
◆ LBUTTON
This is the mask for the left button.
Note
Use the same definitions as the user interface.
◆ MBUTTON
This is the mask for the center button.
Note
◆ RBUTTON
This is the mask for the right button.
Note
Typedef Documentation
◆ BUTTON
This type is the mouse button mask.
◆ COORD
typedef int COORD
This type is the device coordinates.
◆ mouse_parser_enqueue_handler
This type defines a pointer to the enqueue method. It is available since some device drivers keep pointers to the method to know when to enqueue or not.
◆ mouse_parser_enqueue()
void mouse_parser_enqueue ( unsigned char *  buffer,
size_t  size
This method is used to pass mouse input to the Mouse Parser Engine.
param[in] buffer is the data to enqueue param[in] size is the amount of data to enqueue
◆ mouse_parser_initialize()
int mouse_parser_initialize ( const char *  type)
This method initializes the Mouse Parser Engine for the mouse of type. The type should be one of the following strings: pc ms, logi, ps2.
param[in] type indicates the type of mouse.
Return values
Thismethod returns 0 on success and -1 on error.
