RTEMS 5.2
Modules | Files | Macros
BF533 EZ-KIT Board Support Package. More...
 CPLB Configuration
 CPLB Configuration.
 TM27 Test Support
 Interrupt Mechanisms for TM27.
file  bsp.h
 Global BSP definitions.
#define L1_DATA_SRAM_A   0xff800000L
 Blackfin environment memory map.
#define FIFOLENGTH   0x100
functions
void setLED (uint8_t value)
 Helper Function to use the EzKits LEDS. Can be used by the Application.
uint8_t getLED (void)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler. More...
void Init_RTC (void)
void bfin_null_isr (void)
PLL and clock setup values:
PLL configuration for ezkit533
XTL = 27 MHz CLKIN = 13 MHz VCO = 391 MHz CCLK = 391 MHz SCLK = 130 MHz
#define PLL_CSEL   0x0000
 CCLK = VCO *‍/.
#define PLL_SSEL   0x0003
 SCLK = CCLK/3 *‍/.
#define PLL_MSEL   0x3A00
 VCO = 29xCLKIN *‍/.
#define PLL_DF   0x0001
 CLKIN = XTL/2 *‍/.
#define CCLK   391000000
 CORE CLOCK *‍/.
#define SCLK   130000000
 SYSTEM CLOCK *‍/.
UART setup values
#define BAUDRATE   57600
 Console Baudrate *‍/.
#define WORD_5BITS   0x00
 5 bits word *‍/
#define WORD_6BITS   0x01
 6 bits word *‍/
#define WORD_7BITS   0x02
 7 bits word *‍/
#define WORD_8BITS   0x03
 8 bits word *‍/
#define EVEN_PARITY   0x18
 Enable EVEN parity *‍/.
#define ODD_PARITY   0x08
 Enable ODD parity *‍/.
#define TWO_STP_BIT   0x04
 2 stop bits *‍/
Ezkit flash ports
#define FlashA_PortB_Dir   0x20270007L
#define FlashA_PortB_Data   0x20270005L
Constants
#define RAM_START   0
#define RAM_END   0x100000
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
