RTEMS 5.2
Files | Macros | Functions
ARM system low level start. More...
file  arm-cp15-start.h
 Arm CP15 start.
file  start.h
file  bspstart.c
 Raspberry pi startup code.
file  bspstarthooks.c
 Rasberry Pi startup code.
#define BSP_START_TEXT_SECTION   __attribute__((section(".bsp_start_text")))
#define BSP_START_DATA_SECTION   __attribute__((section(".bsp_start_data")))
#define BSP_START_HOOKS_LOADER_ARGS   void
void _start (void)
 System start entry.
void bsp_start_hook_0 (BSP_START_HOOKS_LOADER_ARGS)
 Start entry hook 0. More...
void bsp_start_hook_1 (BSP_START_HOOKS_LOADER_ARGS)
 Start entry hook 1. More...
void bsp_start_memcpy (int *dest, const int *src, size_t n)
 Similar to standard memcpy(). More...
void bsp_start_memcpy_arm (int *dest, const int *src, size_t n)
 ARM entry point to bsp_start_memcpy().
◆ bsp_start_hook_0()
void bsp_start_hook_0 ( BSP_START_HOOKS_LOADER_ARGS  )
Start entry hook 0.
This hook will be called from the start entry code after all modes and stack pointers are initialized but before the copying of the exception vectors.
◆ bsp_start_hook_1()
void bsp_start_hook_1 ( BSP_START_HOOKS_LOADER_ARGS  )
Start entry hook 1.
This hook will be called from the start entry code after copying of the exception vectors but before the call to boot_card().
◆ bsp_start_memcpy()
void bsp_start_memcpy ( int *  dest,
const int *  src,
size_t  n
The memory areas must be word aligned. Copy code will be executed from the stack. If dest equals src nothing will be copied.
