Here is a list of all documented functions, variables, defines, enums, and typedefs with links to the documentation:
- p -
- p : tte.h
- PAGESIZE_8K : tlb.h
- PAR : wd80x3.h
- PARTITION_INFORMATION_DEFINE : partdata.h
- Partition_MP_Remote_operations : partmp.h
- pathconf() : pathconf.c
- pause() : pause.c
- PBIST_March13N_DP : tms570_selftest.h
- PBIST_PORT0 : tms570_selftest.h
- PBIST_PORT1 : tms570_selftest.h
- PBIST_TripleReadFast : tms570_selftest.h
- PBIST_TripleReadSlow : tms570_selftest.h
- pbistPort : tms570_selftest.h
- pc : regs.h
- pCharset10x14 : lcd_font10x14.h
- PCIB_DEVSIG_BUS : pcibios.c
- PCIB_DEVSIG_MAKE : pcibios.c
- PE : uart.h
- PEN : uart.h
- Per_CPU_Control : percpu.h
- PER_CPU_DATA_GET : percpudata.h
- PER_CPU_DATA_GET_BY_OFFSET : percpudata.h
- PER_CPU_DATA_ITEM : percpudata.h
- PER_CPU_DATA_ITEM_DECLARE : percpudata.h
- PER_CPU_DATA_OFFSET : percpudata.h
- PER_CPU_WATCHDOG_COUNT : percpu.h
- Per_CPU_Watchdog_index : percpu.h
- PER_CPU_WATCHDOG_MONOTONIC : percpu.h
- PER_CPU_WATCHDOG_REALTIME : percpu.h
- PER_CPU_WATCHDOG_TICKS : percpu.h
- PIC_EOI : irq_asm.h, i8259.h
- PIC_EOSI : irq_asm.h, i8259.h
- PIC_MASTER_COMMAND_IO_PORT : irq_asm.h, i8259.h
- PIC_MASTER_IMR_IO_PORT : irq_asm.h, i8259.h
- PIC_SLAVE_COMMAND_IO_PORT : irq_asm.h, i8259.h
- PIC_SLAVE_IMR_IO_PORT : irq_asm.h, i8259.h
- PIN_USART1_RXD_DBG : dbg_console.c
- PIN_USART1_TXD_DBG : dbg_console.c
- PIO_CaptureDisable() : pio_capture.c
- PIO_CaptureDisableIt() : pio_capture.c
- PIO_CaptureEnable() : pio_capture.c
- PIO_CaptureEnableIt() : pio_capture.c
- PIO_CaptureHandler() : pio_capture.c, pio_it.h
- PIO_CaptureInit() : pio_capture.c
- PIO_Clear() : pio.c, pio.h
- PIO_Configure() : pio.c, pio.h
- PIO_ConfigureIt() : pio_it.h
- PIO_DEBOUNCE : pio.h
- PIO_DEFAULT : pio.h
- PIO_DEGLITCH : pio.h
- PIO_DisableWriteProtect() : pio.c, pio.h
- PIO_EnableWriteProtect() : pio.c, pio.h
- PIO_Get() : pio.c, pio.h
- PIO_GetOutputDataStatus() : pio.c, pio.h
- PIO_GetWriteProtectViolationInfo() : pio.c, pio.h
- PIO_INPUT : pio.h
- PIO_IT_AIME : pio.h
- PIO_IT_EDGE : pio.h
- PIO_IT_FALL_EDGE : pio.h
- PIO_IT_HIGH_LEVEL : pio.h
- PIO_IT_LOW_LEVEL : pio.h
- PIO_IT_RE_OR_HL : pio.h
- PIO_IT_RISE_EDGE : pio.h
- PIO_LISTSIZE : pio.h
- PIO_OPENDRAIN : pio.h
- PIO_OUTPUT_0 : pio.h
- PIO_OUTPUT_1 : pio.h
- PIO_PERIPH_A : pio.h
- PIO_PERIPH_B : pio.h
- PIO_PERIPH_C : pio.h
- PIO_PERIPH_D : pio.h
- PIO_PULLUP : pio.h
- PIO_RemoveIt() : pio_it.h
- PIO_Set() : pio.c, pio.h
- PIO_SetDebounceFilter() : pio.c, pio.h
- PIO_SetDriveStrength() : pio.c, pio.h
- PIO_SetPinType() : pio.c, pio.h
- PIO_WPMR_WPEN_DIS : pio.h
- PIO_WPMR_WPEN_EN : pio.h
- PIO_WPMR_WPKEY_VALID : pio.h
- pipe_ioctl() : pipe.h, fifo.c
- pipe_read() : pipe.h, fifo.c
- pipe_release() : pipe.h, fifo.c
- pipe_write() : pipe.h, fifo.c
- PL011 : console-config.c
- PLL_CSEL : bsp.h
- PLL_DF : bsp.h
- PLL_MSEL : bsp.h
- PLL_SSEL : bsp.h
- PMC_ConfigureMckWithPlla() : pmc.c
- PMC_ConfigurePCK0() : pmc.c
- PMC_ConfigurePCK1() : pmc.c
- PMC_ConfigurePCK2() : pmc.c
- PMC_DisableAllClocks() : pmc.c
- PMC_DisableAllPeripherals() : pmc.c
- PMC_DisableExtOsc() : pmc.c
- PMC_DisableIntRC4_8_12MHz() : pmc.c
- PMC_DisablePeripheral() : pmc.c
- PMC_EnableAllPeripherals() : pmc.c
- PMC_EnableExtOsc() : pmc.c
- PMC_EnableIntRC4_8_12MHz() : pmc.c
- PMC_EnablePeripheral() : pmc.c
- PMC_EnableXT32KFME() : pmc.c
- PMC_IsPeriphEnabled() : pmc.c
- PMC_SelectExtBypassOsc() : pmc.c
- PMC_SelectExtOsc() : pmc.c
- PMC_SetMckSelection() : pmc.c
- PMC_SetPllaClock() : pmc.c
- POSIX_CONDITION_VARIABLES_NO_MUTEX : condimpl.h
- POSIX_Fatal_domain : posixapi.h
- POSIX_FD_PTHREAD : posixapi.h
- POSIX_FD_PTHREAD_ONCE : posixapi.h
- POSIX_KEYS_INFORMATION_DEFINE : key.h
- POSIX_MESSAGE_QUEUE_INFORMATION_DEFINE : mqueue.h
- POSIX_Mutex_Protocol : muteximpl.h
- POSIX_SCHEDULER_MINIMUM_PRIORITY : priorityimpl.h
- POSIX_SEMAPHORE_INFORMATION_DEFINE : semaphore.h
- POSIX_SEMAPHORE_MAGIC : semaphoreimpl.h
- POSIX_SHM_INFORMATION_DEFINE : shm.h
- POSIX_TIMER_INFORMATION_DEFINE : timer.h
- POSIX_TIMER_RELATIVE : timerimpl.h
- POSIX_TIMER_STATE_CREATE_NEW : timerimpl.h
- POSIX_TIMER_STATE_CREATE_RUN : timerimpl.h
- POSIX_TIMER_STATE_CREATE_STOP : timerimpl.h
- POSIX_TIMER_STATE_FREE : timerimpl.h
- ppc_boom_bam : tictac.c
- PPC_CLEAR_DEVICE_CONTROL_REGISTER_BITS : powerpc-utility.h
- PPC_CLEAR_SPECIAL_PURPOSE_REGISTER_BITS : powerpc-utility.h
- PPC_DEVICE_CONTROL_REGISTER : powerpc-utility.h
- PPC_DISABLE_INLINE_ISR_DISABLE_ENABLE : paravirt.h
- PPC_DISABLE_MSR_ACCESS : paravirt.h
- ppc_exc_alignment_handler() : vectors.h
- ppc_exc_cache_wb_check : vectors.h, ppc_exc_initialize.c
- ppc_exc_categories : vectors.h
- ppc_exc_categories_for_cpu() : vectors.h, ppc_exc_categories.c
- ppc_exc_category : vectors.h
- ppc_exc_category_for_vector() : vectors.h, ppc_exc_categories.c
- ppc_exc_get_DAR : vectors.h, ppc_exc_print.c
- ppc_exc_get_handler() : vectors.h
- ppc_exc_handler_default() : vectors.h
- ppc_exc_handler_t : vectors.h
- ppc_exc_handler_table : vectors.h
- ppc_exc_initialize_with_vector_base() : vectors.h, ppc_exc_initialize.c
- ppc_exc_make_prologue() : vectors.h, ppc_exc_prologue.c
- ppc_exc_msr_bits : vectors.h
- ppc_exc_set_handler() : vectors.h
- ppc_exc_vector_address() : vectors.h, ppc_exc_address.c
- PPC_INTERRUPT_DISABLE_MASK_DEFAULT : registers.h
- PPC_NO_CACHE_ALIGNMENT : powerpc.h
- PPC_NO_CACHE_ALIGNMENT_POWER : powerpc.h
- PPC_SET_DEVICE_CONTROL_REGISTER : powerpc-utility.h
- PPC_SET_DEVICE_CONTROL_REGISTER_BITS : powerpc-utility.h
- PPC_SET_DEVICE_CONTROL_REGISTER_BITS_MASKED : powerpc-utility.h
- PPC_SET_SPECIAL_PURPOSE_REGISTER : powerpc-utility.h
- PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS : powerpc-utility.h
- PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS_MASKED : powerpc-utility.h
- PPC_SET_THREAD_MGMT_REGISTER : powerpc-utility.h
- PPC_SPECIAL_PURPOSE_REGISTER : powerpc-utility.h
- PPC_STRINGOF : powerpc-utility.h
- PPC_THREAD_MGMT_REGISTER : powerpc-utility.h
- ppc_tic_tac : tictac.c
- pr : tlb.h
- printk() : bspIo.h, printk.c
- Priority_Action_type : priority.h
- Priority_Control : priority.h
- PRIORITY_DEFAULT_MAXIMUM : priority.h
- PRIORITY_MAXIMUM : scheduler.h
- PRIORITY_MINIMUM : priority.h
- PRIORITY_PSEUDO_ISR : priority.h
- PRIxblkcnt_t : inttypes.h
- PRIxblksize_t : inttypes.h
- PROTECT_SECTOR : s25fl1.h
- PSR_OFFSET : cpu.h
- PSTART : wd80x3.h
- PSTOP : wd80x3.h
- pthread_atfork() : pthreadatfork.c
- pthread_attr_getschedpolicy() : pthreadattrgetschedpolicy.c
- pthread_attr_init() : pthreadattrinit.c
- pthread_cond_broadcast() : condbroadcast.c
- pthread_cond_destroy() : conddestroy.c
- pthread_cond_init() : condinit.c
- pthread_cond_signal() : condsignal.c
- pthread_detach() : pthreaddetach.c
- pthread_key_create() : keycreate.c
- PTHREAD_MINIMUM_STACK_SIZE : pthreadimpl.h
- pthread_mutex_init() : mutexinit.c
- pthread_mutex_timedlock() : mutextimedlock.c
- pthread_mutex_trylock() : mutextrylock.c
- pthread_mutexattr_destroy() : mutexattrdestroy.c
- pthread_mutexattr_init() : mutexattrinit.c
- PUBLIC : asm.h
- putk() : bspIo.h, putk.c
- pwm_init() : pwmout.h, pwmout.c
- pwm_period() : pwmout.h, pwmout.c
- pwm_pulsewidth() : pwmout.h, pwmout.c
- PWMC_ConfigureChannel() : pwmc.c, pwmc.h
- PWMC_ConfigureChannelExt() : pwmc.c, pwmc.h
- PWMC_ConfigureClocks() : pwmc.c, pwmc.h
- PWMC_ConfigureComparisonUnit() : pwmc.c, pwmc.h
- PWMC_ConfigureEventLineMode() : pwmc.c, pwmc.h
- PWMC_ConfigureSyncChannel() : pwmc.c, pwmc.h
- PWMC_DisableChannel() : pwmc.c, pwmc.h
- PWMC_DisableChannelIt() : pwmc.c, pwmc.h
- PWMC_DisableIt() : pwmc.c, pwmc.h
- PWMC_DisableOverrideOutput() : pwmc.c, pwmc.h
- PWMC_EnableChannel() : pwmc.c, pwmc.h
- PWMC_EnableChannelIt() : pwmc.c, pwmc.h
- PWMC_EnableFaultProtection() : pwmc.c, pwmc.h
- PWMC_EnableIt() : pwmc.c, pwmc.h
- PWMC_EnableOverrideOutput() : pwmc.c, pwmc.h
- PWMC_FaultClear() : pwmc.c, pwmc.h
- PWMC_GetStatus2() : pwmc.c, pwmc.h
- PWMC_OutputOverrideSelection() : pwmc.c, pwmc.h
- PWMC_SetDeadTime() : pwmc.c, pwmc.h
- PWMC_SetDutyCycle() : pwmc.c, pwmc.h
- PWMC_SetFaultMode() : pwmc.c, pwmc.h
- PWMC_SetFaultProtectionValue() : pwmc.c, pwmc.h
- PWMC_SetOverrideValue() : pwmc.c, pwmc.h
- PWMC_SetPeriod() : pwmc.c, pwmc.h
- PWMC_SetSyncChannelUpdatePeriod() : pwmc.c, pwmc.h
- PWMC_SetSyncChannelUpdateUnlock() : pwmc.c, pwmc.h
