RTEMS 5.2
Macros | Functions
pmc.c File Reference
#include "chip.h"
#include <assert.h>
#define MASK_STATUS0   0xFFFFFFFC
#define MASK_STATUS1   0xFFFFFFFF
void PMC_EnablePeripheral (uint32_t dwId)
 Enables the clock of a peripheral. The peripheral ID is used to identify which peripheral is targeted. More...
void PMC_DisablePeripheral (uint32_t dwId)
 Disables the clock of a peripheral. The peripheral ID is used to identify which peripheral is targeted. More...
void PMC_EnableAllPeripherals (void)
 Enable all the periph clock via PMC.
void PMC_DisableAllPeripherals (void)
 Disable all the periph clock via PMC.
uint32_t PMC_IsPeriphEnabled (uint32_t dwId)
 Get Periph Status for the given peripheral ID. More...
void PMC_EnableExtOsc (void)
 Enable external oscillator as main clock input.
void PMC_DisableExtOsc (void)
 Disable external 12MHz oscillator.
void PMC_SelectExtOsc (void)
 Select external OSC.
void PMC_SelectExtBypassOsc (void)
void PMC_EnableIntRC4_8_12MHz (uint32_t freqSelect)
 Enable internal 4/8/12MHz fast RC as main clock input. More...
void PMC_DisableIntRC4_8_12MHz (void)
 Disable internal 4/8/12MHz fast RC.
void PMC_SetPllaClock (uint32_t mul, uint32_t div)
 Configure PLLA clock by giving MUL and DIV. Disable PLLA when 'mul' set to 0. More...
void PMC_SetMckSelection (uint32_t clockSource, uint32_t prescaler)
 Selection of Master Clock. More...
void PMC_DisableAllClocks (void)
 Disable all clocks.
void PMC_ConfigureMckWithPlla (uint32_t mul, uint32_t div, uint32_t prescaler)
 Configure PLLA as clock input for MCK. More...
void PMC_EnableXT32KFME (void)
void PMC_ConfigurePCK0 (uint32_t MasterClk, uint32_t prescaler)
void PMC_ConfigurePCK1 (uint32_t MasterClk, uint32_t prescaler)
void PMC_ConfigurePCK2 (uint32_t MasterClk, uint32_t prescaler)
Purpose
Interface for configuring and using Power Management Controller (PMC) peripherals.
Implementation of Power Management Controller (PMC).
◆ PMC_ConfigureMckWithPlla()
void PMC_ConfigureMckWithPlla ( uint32_t  mul,
uint32_t  div,
uint32_t  prescaler
Parameters
mulPLL multiplier factor (not shifted, don't minus 1).
divPLL divider factor (not shifted).
prescalerMaster Clock prescaler (shifted as in register).
◆ PMC_ConfigurePCK0()
void PMC_ConfigurePCK0 ( uint32_t  MasterClk,
uint32_t  prescaler
Parameters
◆ PMC_ConfigurePCK1()
void PMC_ConfigurePCK1 ( uint32_t  MasterClk,
uint32_t  prescaler
Parameters
◆ PMC_ConfigurePCK2()
void PMC_ConfigurePCK2 ( uint32_t  MasterClk,
uint32_t  prescaler
Parameters
◆ PMC_DisablePeripheral()
void PMC_DisablePeripheral ( uint32_t  dwId)
Note
The ID must NOT be shifted (i.e. 1 << ID_xxx).
Parameters
idPeripheral ID (ID_xxx).
◆ PMC_EnableIntRC4_8_12MHz()
void PMC_EnableIntRC4_8_12MHz ( uint32_t  freqSelect)
Parameters
freqSelectfast RC frequency (FAST_RC_4MHZ, FAST_RC_8MHZ, FAST_RC_12MHZ).
◆ PMC_EnablePeripheral()
void PMC_EnablePeripheral ( uint32_t  dwId)
Note
Parameters
◆ PMC_EnableXT32KFME()
void PMC_EnableXT32KFME ( void  )
Parameters
◆ PMC_IsPeriphEnabled()
uint32_t PMC_IsPeriphEnabled ( uint32_t  dwId)
Parameters
◆ PMC_SetMckSelection()
void PMC_SetMckSelection ( uint32_t  clockSource,
uint32_t  prescaler
Parameters
clockSourceMaster Clock source.
prescalerMaster Clock prescaler.
Note
The PMC_MCKR register must not be programmed in a single write operation (see. Product Data Sheet).
◆ PMC_SetPllaClock()
void PMC_SetPllaClock ( uint32_t  mul,
uint32_t  div
Parameters
mulPLL multiplier factor.
divPLL divider factor.
