RTEMS 5.2
powerpc.h File Reference
#include <rtems/score/powerpc.h>
#include <bspopts.h>
#define PPC_LOW_POWER_MODE_NONE   0
#define PPC_LOW_POWER_MODE_STANDARD   1
#define PPC_NO_CACHE_ALIGNMENT   4
 For boards with no cache set PPC_CACHE_ALIGNMENT to this value.
#define PPC_NO_CACHE_ALIGNMENT_POWER   2
 Used to define PPC_CACHE_ALIGN_POWER for boards with no cache (and PPC_NO_CACHE_ALIGNMENT defined).
#define PPC_INTERRUPT_MAX   16
#define PPC_CACHE_ALIGNMENT   PPC_DEFAULT_CACHE_LINE_SIZE
#define PPC_HAS_EXCEPTION_PREFIX   1
#define PPC_HAS_RI   1
#define PPC_HAS_EVPR   0
#define PPC_LOW_POWER_MODE   PPC_LOW_POWER_MODE_NONE
#define PPC_HAS_RFCI   0
#define PPC_USE_MULTIPLE   0
#define PPC_IRQ_SYSTEM_RESET   0 /* 0x00100 - System reset. */
#define PPC_IRQ_MCHECK   1 /* 0x00200 - Machine check */
#define PPC_IRQ_PROTECT   2 /* 0x00300 - Protection violation */
#define PPC_IRQ_ISI   3 /* 0x00400 - Instruction Fetch error */
#define PPC_IRQ_EXTERNAL   4 /* 0x00500 - External interrupt */
#define PPC_IRQ_ALIGNMENT   5 /* 0X00600 - Alignment exception */
#define PPC_IRQ_PROGRAM   6 /* 0x00700 - Program exception */
#define PPC_IRQ_NOFP   7 /* 0x00800 - Floating point unavailable */
#define PPC_IRQ_DECREMENTER   8 /* 0x00900 - Decrementer interrupt */
#define PPC_IRQ_RESERVED_A   9 /* 0x00a00 - Implementation Reserved */
#define PPC_IRQ_RESERVED_B   10 /* 0x00b00 - Implementation Reserved */
#define PPC_IRQ_SCALL   11 /* 0x00c00 - System call */
#define PPC_IRQ_TRACE   12 /* 0x00d00 - Trace Exception */
#define PPC_IRQ_FP_ASST   13 /* ox00e00 - Floating point assist */
#define PPC_STD_IRQ_LAST   PPC_IRQ_FP_ASST
#define PPC_IRQ_FIRST   PPC_IRQ_SYSTEM_RESET
#define PPC_MSR_RI   0x000000002 /* bit 30 - recoverable exception */
#define PPC_MSR_DR   0x000000010 /* bit 27 - data address translation */
#define PPC_MSR_IR   0x000000020 /* bit 26 - instruction addr translation*/
#define PPC_MSR_EP   0x000000040 /* bit 25 - exception prefix */
#define PPC_MSR_FP   0x000000000 /* bit 18 - floating point enable */
#define PPC_MSR_POW   0x000000000 /* bit 13 - power management enable */
#define PPC_MSR_ME   0x000001000 /* bit 19 - machine check enable */
#define PPC_MSR_EE   0x000008000 /* bit 16 - external interrupt enable */
#define PPC_MSR_CE   0x000000000 /* bit 14 - critical interrupt enable */
#define PPC_MSR_DISABLE_MASK   (PPC_MSR_ME|PPC_MSR_EE|PPC_MSR_CE)
#define PPC_MINIMUM_STACK_FRAME_SIZE   PPC_STACK_ALIGNMENT
