RTEMS 5.2
Files | |
| file | shm.c |
| POSIX Shared Memory Information with Zero Objects. | |
| struct | POSIX_Shm_Object |
| Encapsulation for the storage and manipulation of shm objects. More... | |
| struct | POSIX_Shm_Object_operations |
| Operations on POSIX Shared Memory Objects. More... | |
| struct | POSIX_Shm_Control |
| Control for a POSIX Shared Memory Object. More... | |
| #define | POSIX_SHM_INFORMATION_DEFINE(max) |
| Macro to define the objects information for the POSIX Shared Memory objects. More... | |
Typedefs | |
| typedef struct POSIX_Shm_Object_operations | POSIX_Shm_Object_operations |
| int | _POSIX_Shm_Object_create_from_workspace (POSIX_Shm_Object *shm_obj, size_t size) |
| object_create operation for shm objects stored in RTEMS Workspace. | |
| int | _POSIX_Shm_Object_delete_from_workspace (POSIX_Shm_Object *shm_obj) |
| object_delete operation for shm objects stored in RTEMS Workspace. | |
| int | _POSIX_Shm_Object_resize_from_workspace (POSIX_Shm_Object *shm_obj, size_t size) |
| object_resize operation for shm objects stored in RTEMS Workspace. | |
| int | _POSIX_Shm_Object_read_from_workspace (POSIX_Shm_Object *shm_obj, void *buf, size_t count) |
| object_read operation for shm objects stored in RTEMS Workspace. | |
| void * | _POSIX_Shm_Object_mmap_from_workspace (POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off) |
| object_mmap operation for shm objects stored in RTEMS Workspace. | |
| int | _POSIX_Shm_Object_create_from_heap (POSIX_Shm_Object *shm_obj, size_t size) |
| object_create operation for shm objects stored in C program heap. | |
| int | _POSIX_Shm_Object_delete_from_heap (POSIX_Shm_Object *shm_obj) |
| object_delete operation for shm objects stored in C program heap. | |
| int | _POSIX_Shm_Object_resize_from_heap (POSIX_Shm_Object *shm_obj, size_t size) |
| object_resize operation for shm objects stored in C program heap. | |
| int | _POSIX_Shm_Object_read_from_heap (POSIX_Shm_Object *shm_obj, void *buf, size_t count) |
| object_read operation for shm objects stored in C program heap. | |
| void * | _POSIX_Shm_Object_mmap_from_heap (POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off) |
| object_mmap operation for shm objects stored in C program heap. | |
| const POSIX_Shm_Object_operations | _POSIX_Shm_Object_operations |
| Objects_Information | _POSIX_Shm_Information |
| The POSIX Shared Memory objects information. | |
| RTEMS_INLINE_ROUTINE POSIX_Shm_Control * | _POSIX_Shm_Allocate_unprotected (void) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Shm_Free (POSIX_Shm_Control *the_shm) |
| POSIX Shared Memory Free. More... | |
| RTEMS_INLINE_ROUTINE POSIX_Shm_Control * | _POSIX_Shm_Get_by_name (const char *name, size_t *name_length_p, Objects_Get_by_name_error *error) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Shm_Update_atime (POSIX_Shm_Control *shm) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Shm_Update_mtime_ctime (POSIX_Shm_Control *shm) |
Internal implementation support for POSIX shared memory.
| #define POSIX_SHM_INFORMATION_DEFINE | ( | max | ) |
This macro should only be used by <rtems/confdefs.h>.
| max | The configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set). |
| RTEMS_INLINE_ROUTINE void _POSIX_Shm_Free | ( | POSIX_Shm_Control * | the_shm | ) |
This routine frees a shm control block.
