RTEMS 5.2
Inlined Routines from the POSIX Timer Manager. More...
#include <rtems/posix/timer.h>#include <rtems/score/objectimpl.h>#include <rtems/score/watchdogimpl.h>Go to the source code of this file.
| #define | POSIX_TIMER_STATE_FREE 0x01 |
| #define | POSIX_TIMER_STATE_CREATE_NEW 0x02 |
| #define | POSIX_TIMER_STATE_CREATE_RUN 0x03 |
| #define | POSIX_TIMER_STATE_CREATE_STOP 0x04 |
| #define | POSIX_TIMER_RELATIVE 0 |
| RTEMS_INLINE_ROUTINE POSIX_Timer_Control * | _POSIX_Timer_Allocate (void) |
| POSIX Timer Allocate. More... | |
| RTEMS_INLINE_ROUTINE void | _POSIX_Timer_Free (POSIX_Timer_Control *the_timer) |
| POSIX Timer Free. More... | |
| void | _POSIX_Timer_TSR (Watchdog_Control *the_watchdog) |
| RTEMS_INLINE_ROUTINE POSIX_Timer_Control * | _POSIX_Timer_Get (timer_t id, ISR_lock_Context *lock_context) |
| POSIX Timer Get. More... | |
| RTEMS_INLINE_ROUTINE Per_CPU_Control * | _POSIX_Timer_Acquire_critical (POSIX_Timer_Control *ptimer, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Timer_Release (Per_CPU_Control *cpu, ISR_lock_Context *lock_context) |
This file contains the static inline implementation of the inlined routines from the POSIX Timer Manager.
| #define POSIX_TIMER_RELATIVE 0 |
Indicates that the fire time is relative to the current one
| #define POSIX_TIMER_STATE_CREATE_NEW 0x02 |
Created timer but not running
| #define POSIX_TIMER_STATE_CREATE_RUN 0x03 |
Created timer and running
| #define POSIX_TIMER_STATE_CREATE_STOP 0x04 |
Created, ran and stopped timer
| #define POSIX_TIMER_STATE_FREE 0x01 |
Timer is free
| RTEMS_INLINE_ROUTINE POSIX_Timer_Control * _POSIX_Timer_Allocate | ( | void | ) |
This function allocates a timer control block from the inactive chain of free timer control blocks.
| RTEMS_INLINE_ROUTINE void _POSIX_Timer_Free | ( | POSIX_Timer_Control * | the_timer | ) |
POSIX Timer Free.
This routine frees a timer control block to the inactive chain of free timer control blocks.
| RTEMS_INLINE_ROUTINE POSIX_Timer_Control * _POSIX_Timer_Get | ( | timer_t | id, |
| ISR_lock_Context * | lock_context | ||
POSIX Timer Get.
This function maps timer IDs to timer control blocks. If ID corresponds to a local timer, then it returns the timer control pointer which maps to ID and location is set to OBJECTS_LOCAL. Otherwise, location is set to OBJECTS_ERROR and the returned value is undefined.
