RTEMS 5.2
watchdogimpl.h
1
12/*
13 * COPYRIGHT (c) 1989-2004.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef _RTEMS_SCORE_WATCHDOGIMPL_H
22#define _RTEMS_SCORE_WATCHDOGIMPL_H
23
26#include <rtems/score/assert.h>
27#include <rtems/score/isrlock.h>
28#include <rtems/score/percpu.h>
30
31#include <sys/types.h>
32#include <sys/timespec.h>
33
34#ifdef __cplusplus
35extern "C" {
36#endif
37
47typedef enum {
52
57
62
70
78#if defined(RTEMS_SMP)
79 #define WATCHDOG_INITIALIZER( routine ) \
80 { \
81 { { { NULL, NULL, NULL, WATCHDOG_INACTIVE } } }, \
82 &_Per_CPU_Information[ 0 ].per_cpu, \
83 ( routine ), \
84 0 \
85 }
86#else
87 #define WATCHDOG_INITIALIZER( routine ) \
88 { \
89 { { { NULL, NULL, NULL, WATCHDOG_INACTIVE } } }, \
90 ( routine ), \
91 0 \
92 }
93#endif
94
101 Watchdog_Header *header
102)
103{
105 header->first = NULL;
106}
107
116 const Watchdog_Header *header
117)
118{
119 return (Watchdog_Control *) header->first;
120}
121
128 Watchdog_Header *header
129)
130{
131 /* Do nothing */
132 (void) header;
133}
134
140void _Watchdog_Tick( struct Per_CPU_Control *cpu );
141
150 const Watchdog_Control *the_watchdog
151)
152{
153 return (Watchdog_State) RB_COLOR( &the_watchdog->Node.RBTree, Node );
154}
155
163 Watchdog_Control *the_watchdog,
164 Watchdog_State state
165)
166{
167 RB_COLOR( &the_watchdog->Node.RBTree, Node ) = state;
168}
169
178 const Watchdog_Control *the_watchdog
179)
180{
181#if defined(RTEMS_SMP)
182 return the_watchdog->cpu;
183#else
184 return _Per_CPU_Get_by_index( 0 );
185#endif
186}
187
195 Watchdog_Control *the_watchdog,
196 Per_CPU_Control *cpu
197)
198{
199#if defined(RTEMS_SMP)
200 the_watchdog->cpu = cpu;
201#else
202 (void) cpu;
203#endif
204}
205
215 Watchdog_Control *the_watchdog,
216 Per_CPU_Control *cpu
217)
218{
219 _Watchdog_Set_CPU( the_watchdog, cpu );
220 _Watchdog_Set_state( the_watchdog, WATCHDOG_INACTIVE );
221
222#if defined(RTEMS_DEBUG)
223 the_watchdog->routine = NULL;
224 the_watchdog->expire = 0;
225#endif
226}
227
237 Watchdog_Control *the_watchdog,
239)
240{
241 _Assert( _Watchdog_Get_state( the_watchdog ) == WATCHDOG_INACTIVE );
242 the_watchdog->routine = routine;
243}
244
257 Watchdog_Header *header,
258 Watchdog_Control *first,
259 uint64_t now,
260#if defined(RTEMS_SMP)
261 ISR_lock_Control *lock,
262#endif
263 ISR_lock_Context *lock_context
264);
265
266#if defined(RTEMS_SMP)
267 #define _Watchdog_Tickle( header, first, now, lock, lock_context ) \
268 _Watchdog_Do_tickle( header, first, now, lock, lock_context )
269#else
270 #define _Watchdog_Tickle( header, first, now, lock, lock_context ) \
271 _Watchdog_Do_tickle( header, first, now, lock_context )
272#endif
273
285 Watchdog_Header *header,
286 Watchdog_Control *the_watchdog,
287 uint64_t expire
288);
289
300 Watchdog_Header *header,
301 Watchdog_Control *the_watchdog
302);
303
319 Watchdog_Header *header,
320 Watchdog_Control *the_watchdog,
321 uint64_t now
322)
323{
324 uint64_t expire;
325 uint64_t remaining;
326
327 expire = the_watchdog->expire;
328
329 if ( now < expire ) {
330 remaining = expire - now;
331 } else {
332 remaining = 0;
333 }
334
335 _Watchdog_Remove( header, the_watchdog );
336
337 return remaining;
338}
339
349 const Watchdog_Control *the_watchdog
350)
351{
352 return _Watchdog_Get_state( the_watchdog ) < WATCHDOG_INACTIVE;
353}
354
367 Watchdog_Header *header,
368 Watchdog_Control *the_watchdog
369)
370{
371 RBTree_Node *node = _RBTree_Right( &the_watchdog->Node.RBTree );
372
373 if ( node != NULL ) {
374 RBTree_Node *left;
375
376 while ( ( left = _RBTree_Left( node ) ) != NULL ) {
377 node = left;
378 }
379
380 header->first = node;
381 } else {
382 header->first = _RBTree_Parent( &the_watchdog->Node.RBTree );
383 }
384}
385
389#define WATCHDOG_MAXIMUM_TICKS UINT64_MAX
390
391#define WATCHDOG_NANOSECONDS_PER_SECOND 1000000000
392
401#define WATCHDOG_BITS_FOR_1E9_NANOSECONDS 30
402
409#define WATCHDOG_MAX_SECONDS 0x3ffffffff
410
420 const struct timespec *ts
421)
422{
423 return ts != NULL
424 && (unsigned long) ts->tv_nsec < WATCHDOG_NANOSECONDS_PER_SECOND;
425}
426
436 const struct timespec *ts
437)
438{
439 return _Watchdog_Is_valid_timespec( ts ) && ts->tv_sec >= 0;
440}
441
453 struct timespec *now,
454 const struct timespec *delta
455)
456{
457 uint64_t sec;
458
459 if ( !_Watchdog_Is_valid_interval_timespec( delta ) ) {
460 return NULL;
461 }
462
463 sec = (uint64_t) now->tv_sec;
464 sec += (uint64_t) delta->tv_sec;
465 now->tv_nsec += delta->tv_nsec;
466
467 /* We have 2 * (2**63 - 1) + 1 == UINT64_MAX */
468 if ( now->tv_nsec >= WATCHDOG_NANOSECONDS_PER_SECOND ) {
469 now->tv_nsec -= WATCHDOG_NANOSECONDS_PER_SECOND;
470 ++sec;
471 }
472
473 if ( sec <= INT64_MAX ) {
474 now->tv_sec = sec;
475 } else {
476 now->tv_sec = INT64_MAX;
477 }
478
479 return now;
480}
481
491 const struct timespec *ts
492)
493{
494 return ts->tv_sec > WATCHDOG_MAX_SECONDS;
495}
496
505 uint32_t seconds
506)
507{
508 uint64_t ticks = seconds;
509
511
512 return ticks;
513}
514
523 const struct timespec *ts
524)
525{
526 uint64_t ticks;
527
529 _Assert( ts->tv_sec >= 0 );
531
532 ticks = (uint64_t) ts->tv_sec;
534 ticks |= (uint32_t) ts->tv_nsec;
535
536 return ticks;
537}
538
547{
548 uint64_t ticks = ( sbt >> 32 ) << WATCHDOG_BITS_FOR_1E9_NANOSECONDS;
549
550 ticks |= ( (uint64_t) 1000000000 * (uint32_t) sbt ) >> 32;
551
552 return ticks;
553}
554
562 Per_CPU_Control *cpu,
563 ISR_lock_Context *lock_context
564)
565{
566 _ISR_lock_Acquire( &cpu->Watchdog.Lock, lock_context );
567}
568
576 Per_CPU_Control *cpu,
577 ISR_lock_Context *lock_context
578)
579{
580 _ISR_lock_Release( &cpu->Watchdog.Lock, lock_context );
581}
582
594 Watchdog_Control *the_watchdog,
595 Per_CPU_Control *cpu,
597)
598{
599 ISR_lock_Context lock_context;
600 Watchdog_Header *header;
601 uint64_t expire;
602
603 header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ];
604
605 _Watchdog_Set_CPU( the_watchdog, cpu );
606
607 _Watchdog_Per_CPU_acquire_critical( cpu, &lock_context );
608 expire = ticks + cpu->Watchdog.ticks;
609 _Watchdog_Insert(header, the_watchdog, expire);
610 _Watchdog_Per_CPU_release_critical( cpu, &lock_context );
611 return expire;
612}
613
626 Watchdog_Control *the_watchdog,
627 Per_CPU_Control *cpu,
628 Watchdog_Header *header,
629 uint64_t expire
630)
631{
632 ISR_lock_Context lock_context;
633
634 _Watchdog_Set_CPU( the_watchdog, cpu );
635
636 _Watchdog_Per_CPU_acquire_critical( cpu, &lock_context );
637 _Watchdog_Insert( header, the_watchdog, expire );
638 _Watchdog_Per_CPU_release_critical( cpu, &lock_context );
639 return expire;
640}
641
650 Watchdog_Control *the_watchdog,
651 Per_CPU_Control *cpu,
652 Watchdog_Header *header
653)
654{
655 ISR_lock_Context lock_context;
656
657 _Watchdog_Per_CPU_acquire_critical( cpu, &lock_context );
659 header,
660 the_watchdog
661 );
662 _Watchdog_Per_CPU_release_critical( cpu, &lock_context );
663}
664
671 Watchdog_Control *the_watchdog
672)
673{
674 Per_CPU_Control *cpu;
675
676 cpu = _Watchdog_Get_CPU( the_watchdog );
678 the_watchdog,
679 cpu,
681 );
682}
683
686#ifdef __cplusplus
687}
688#endif
689
690#endif
691/* end of include file */
Information for the Assert Handler.
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Constants and Structures Associated with Watchdog Timers.
@ PER_CPU_WATCHDOG_TICKS
Index for tick clock per-CPU watchdog header.
Definition: percpu.h:316
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
#define _ISR_lock_Release(_lock, _context)
Releases an ISR lock inside an ISR disabled section.
Definition: isrlock.h:316
#define _ISR_lock_Acquire(_lock, _context)
Acquires an ISR lock inside an ISR disabled section.
Definition: isrlock.h:293
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Parent(const RBTree_Node *the_node)
Returns a pointer to the parent of this node.
Definition: rbtree.h:295
RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty(RBTree_Control *the_rbtree)
Initializes this RBTree as empty.
Definition: rbtree.h:410
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Right(const RBTree_Node *the_node)
Returns pointer to the right of this node.
Definition: rbtree.h:342
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Left(const RBTree_Node *the_node)
Returns pointer to the left of this node.
Definition: rbtree.h:311
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec(const struct timespec *ts)
Converts the timespec in ticks.
Definition: watchdogimpl.h:522
Watchdog_State
Watchdog states.
Definition: watchdogimpl.h:47
RTEMS_INLINE_ROUTINE void _Watchdog_Set_state(Watchdog_Control *the_watchdog, Watchdog_State state)
Sets the state of the watchdog.
Definition: watchdogimpl.h:162
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_ticks(Watchdog_Control *the_watchdog)
Removes the watchdog from the cpu and the scheduled watchdogs.
Definition: watchdogimpl.h:670
The bits necessary to store 1000000000 (= WATCHDOG_NANOSECONDS_PER_SECOND) nanoseconds.
Definition: watchdogimpl.h:401
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_acquire_critical(Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
Acquires the per cpu watchdog lock in a critical section.
Definition: watchdogimpl.h:561
RTEMS_INLINE_ROUTINE void _Watchdog_Initialize(Watchdog_Control *the_watchdog, Watchdog_Service_routine_entry routine)
Initializes a watchdog with a new service routine.
Definition: watchdogimpl.h:236
void _Watchdog_Insert(Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t expire)
Inserts a watchdog into the set of scheduled watchdogs according to the specified expiration time.
Definition: watchdoginsert.c:29
RTEMS_INLINE_ROUTINE void _Watchdog_Set_CPU(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu)
Sets the cpu for the watchdog.
Definition: watchdogimpl.h:194
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_far_future_timespec(const struct timespec *ts)
Checks if the timespec is too far in the future.
Definition: watchdogimpl.h:490
void _Watchdog_Remove(Watchdog_Header *header, Watchdog_Control *the_watchdog)
In the case the watchdog is scheduled, then it is removed from the set of scheduled watchdogs.
Definition: watchdogremove.c:29
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header)
Definition: watchdogimpl.h:649
RTEMS_INLINE_ROUTINE Watchdog_Control * _Watchdog_Header_first(const Watchdog_Header *header)
Returns the first of the watchdog header.
Definition: watchdogimpl.h:115
RTEMS_INLINE_ROUTINE void _Watchdog_Header_initialize(Watchdog_Header *header)
Initializes the watchdog header.
Definition: watchdogimpl.h:100
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_sbintime(int64_t sbt)
Converts the sbintime in ticks.
Definition: watchdogimpl.h:546
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_release_critical(Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
Releases the per cpu watchdog lock in a critical section.
Definition: watchdogimpl.h:575
RTEMS_INLINE_ROUTINE void _Watchdog_Header_destroy(Watchdog_Header *header)
Destroys the watchdog header.
Definition: watchdogimpl.h:127
void _Watchdog_Tick(struct Per_CPU_Control *cpu)
Performs a watchdog tick.
Definition: watchdogtick.c:54
RTEMS_INLINE_ROUTINE const struct timespec * _Watchdog_Future_timespec(struct timespec *now, const struct timespec *delta)
Adds the delta timespec to the current time if the delta is a valid interval timespec.
Definition: watchdogimpl.h:452
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdogticks.h:38
The maximum number of seconds representable in the nanoseconds watchdog format.
Definition: watchdogimpl.h:409
RTEMS_INLINE_ROUTINE void _Watchdog_Next_first(Watchdog_Header *header, Watchdog_Control *the_watchdog)
Sets the first node of the header.
Definition: watchdogimpl.h:366
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_scheduled(const Watchdog_Control *the_watchdog)
Checks if the watchdog is scheduled.
Definition: watchdogimpl.h:348
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Cancel(Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t now)
Definition: watchdogimpl.h:318
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_valid_timespec(const struct timespec *ts)
Checks if the timespec is a valid timespec for a watchdog.
Definition: watchdogimpl.h:419
RTEMS_INLINE_ROUTINE Watchdog_State _Watchdog_Get_state(const Watchdog_Control *the_watchdog)
Gets the state of the watchdog.
Definition: watchdogimpl.h:149
void _Watchdog_Do_tickle(Watchdog_Header *header, Watchdog_Control *first, uint64_t now, ISR_lock_Context *lock_context)
Calls the routine of each not expired watchdog control node.
Definition: watchdogtick.c:24
RTEMS_INLINE_ROUTINE void _Watchdog_Preinitialize(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu)
Pre-initializes a watchdog.
Definition: watchdogimpl.h:214
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_seconds(uint32_t seconds)
Converts the seconds to ticks.
Definition: watchdogimpl.h:504
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_ticks(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Interval ticks)
Sets the watchdog's cpu to the given instance and sets its expiration time to the watchdog expiration...
Definition: watchdogimpl.h:593
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Watchdog_Get_CPU(const Watchdog_Control *the_watchdog)
Gets the watchdog's cpu.
Definition: watchdogimpl.h:177
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_valid_interval_timespec(const struct timespec *ts)
Checks if the timespec is a valid interval timespec for a watchdog.
Definition: watchdogimpl.h:435
Watchdog_Service_routine(* Watchdog_Service_routine_entry)(Watchdog_Control *)
Pointer to a watchdog service routine.
Definition: watchdog.h:66
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header, uint64_t expire)
Sets the watchdog's cpu and inserts it with the given expiration time in the scheduled watchdogs.
Definition: watchdogimpl.h:625
@ WATCHDOG_SCHEDULED_BLACK
The watchdog is scheduled and a black node in the red-black tree.
Definition: watchdogimpl.h:51
@ WATCHDOG_INACTIVE
The watchdog is inactive.
Definition: watchdogimpl.h:61
@ WATCHDOG_PENDING
The watchdog is on a chain of pending watchdogs.
Definition: watchdogimpl.h:68
@ WATCHDOG_SCHEDULED_RED
The watchdog is scheduled and a red node in the red-black tree.
ISR Locks.
Inlined Routines Associated with Red-Black Trees.
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
ISR lock control.
Definition: isrlock.h:56
Per CPU Core Structure.
Definition: percpu.h:347
Watchdog_Header Header[PER_CPU_WATCHDOG_COUNT]
Header for watchdogs.
Definition: percpu.h:474
uint64_t ticks
Protects all watchdog operations on this processor.
Definition: percpu.h:467
struct Per_CPU_Control::@3978 Watchdog
Watchdog state for this processor.
Red-black tree node.
Definition: rbtree.h:55
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
RBTree_Node RBTree
this field is a red-black tree node structure and allows this to be placed on a red-black tree used t...
Definition: watchdog.h:99
uint64_t expire
This field is the expiration time point.
Definition: watchdog.h:117
union Watchdog_Control::@3988 Node
Nodes for the watchdog.
This field is the function to invoke.
Definition: watchdog.h:114
The watchdog header to manage scheduled watchdogs.
Definition: watchdog.h:71
RBTree_Node * first
The scheduled watchdog with the earliest expiration time or NULL in case no watchdog is scheduled.
Definition: watchdog.h:81
RBTree_Control Watchdogs
Red-black tree of scheduled watchdogs sorted by expiration time.
Definition: watchdog.h:75
Constants for the watchdog ticks.
