RTEMS 5.2
cpu.h
1
7/*
8 * This include file contains information pertaining to the ARM
9 * processor.
10 *
11 * Copyright (c) 2009, 2017 embedded brains GmbH
12 *
13 * Copyright (c) 2007 Ray Xu <Rayx.cn@gmail.com>
14 *
15 * Copyright (c) 2006 OAR Corporation
16 *
17 * Copyright (c) 2002 Advent Networks, Inc.
18 * Jay Monkman <jmonkman@adventnetworks.com>
19 *
20 * COPYRIGHT (c) 2000 Canon Research Centre France SA.
21 * Emmanuel Raguet, mailto:raguet@crf.canon.fr
22 *
23 * The license and distribution terms for this file may be
24 * found in the file LICENSE in this distribution or at
25 * http://www.rtems.org/license/LICENSE.
26 *
27 */
28
29#ifndef _RTEMS_SCORE_CPU_H
30#define _RTEMS_SCORE_CPU_H
31
33#if defined(RTEMS_PARAVIRT)
34#include <rtems/score/paravirt.h>
35#endif
36#include <rtems/score/arm.h>
37
44#if defined(ARM_MULTILIB_ARCH_V4)
45
46#if defined(__thumb__) && !defined(__thumb2__)
47 #define ARM_SWITCH_REGISTERS uint32_t arm_switch_reg
48 #define ARM_SWITCH_TO_ARM ".align 2\nbx pc\n.arm\n"
49 #define ARM_SWITCH_BACK "add %[arm_switch_reg], pc, #1\nbx %[arm_switch_reg]\n.thumb\n"
50 #define ARM_SWITCH_OUTPUT [arm_switch_reg] "=&r" (arm_switch_reg)
51 #define ARM_SWITCH_ADDITIONAL_OUTPUT , ARM_SWITCH_OUTPUT
52#else
53 #define ARM_SWITCH_REGISTERS
54 #define ARM_SWITCH_TO_ARM
55 #define ARM_SWITCH_BACK
56 #define ARM_SWITCH_OUTPUT
57 #define ARM_SWITCH_ADDITIONAL_OUTPUT
58#endif
59
65#define ARM_PSR_N (1 << 31)
66#define ARM_PSR_Z (1 << 30)
67#define ARM_PSR_C (1 << 29)
68#define ARM_PSR_V (1 << 28)
69#define ARM_PSR_Q (1 << 27)
70#define ARM_PSR_J (1 << 24)
71#define ARM_PSR_GE_SHIFT 16
72#define ARM_PSR_GE_MASK (0xf << ARM_PSR_GE_SHIFT)
73#define ARM_PSR_E (1 << 9)
74#define ARM_PSR_A (1 << 8)
75#define ARM_PSR_I (1 << 7)
76#define ARM_PSR_F (1 << 6)
77#define ARM_PSR_T (1 << 5)
78#define ARM_PSR_M_SHIFT 0
79#define ARM_PSR_M_MASK (0x1f << ARM_PSR_M_SHIFT)
80#define ARM_PSR_M_USR 0x10
81#define ARM_PSR_M_FIQ 0x11
82#define ARM_PSR_M_IRQ 0x12
83#define ARM_PSR_M_SVC 0x13
84#define ARM_PSR_M_ABT 0x17
85#define ARM_PSR_M_HYP 0x1a
86#define ARM_PSR_M_UND 0x1b
87#define ARM_PSR_M_SYS 0x1f
88
91#endif /* defined(ARM_MULTILIB_ARCH_V4) */
92
93/*
94 * The ARM uses the PIC interrupt model.
95 */
96#define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
97
98#define CPU_ISR_PASSES_FRAME_POINTER FALSE
99
100#define CPU_HARDWARE_FP FALSE
101
102#define CPU_SOFTWARE_FP FALSE
103
104#define CPU_ALL_TASKS_ARE_FP FALSE
105
106#define CPU_IDLE_TASK_IS_FP FALSE
107
108#define CPU_USE_DEFERRED_FP_SWITCH FALSE
109
110#define CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE
111
112#define CPU_STACK_GROWS_UP FALSE
113
114#if defined(ARM_MULTILIB_CACHE_LINE_MAX_64)
115 #define CPU_CACHE_LINE_BYTES 64
116#else
117 #define CPU_CACHE_LINE_BYTES 32
118#endif
119
120#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
121
122#define CPU_MODES_INTERRUPT_MASK 0x1
123
124#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
125
126#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
127
128#define CPU_STACK_MINIMUM_SIZE (1024 * 4)
129
130/* AAPCS, section 4.1, Fundamental Data Types */
131#define CPU_SIZEOF_POINTER 4
132
133/* AAPCS, section 4.1, Fundamental Data Types */
134#define CPU_ALIGNMENT 8
135
136#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
137
138/* AAPCS, section 5.2.1.2, Stack constraints at a public interface */
139#define CPU_STACK_ALIGNMENT 8
140
141#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
142
143/*
144 * Bitfield handler macros.
145 *
146 * If we had a particularly fast function for finding the first
147 * bit set in a word, it would go here. Since we don't (*), we'll
148 * just use the universal macros.
149 *
150 * (*) On ARM V5 and later, there's a CLZ function which could be
151 * used to implement much quicker than the default macro.
152 */
153
154#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
155
156#define CPU_MAXIMUM_PROCESSORS 32
157
158#ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
159 #define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44
160#endif
161
162#ifdef ARM_MULTILIB_VFP
163 #define ARM_CONTEXT_CONTROL_D8_OFFSET 48
164#endif
165
166#ifdef ARM_MULTILIB_ARCH_V4
167 #define ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 40
168#endif
169
170#ifdef RTEMS_SMP
171 #if defined(ARM_MULTILIB_VFP)
172 #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
173 #elif defined(ARM_MULTILIB_HAS_THREAD_ID_REGISTER)
174 #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
175 #else
176 #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 44
177 #endif
178#endif
179
180#define ARM_EXCEPTION_FRAME_SIZE 80
181
182#define ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET 52
183
184#define ARM_EXCEPTION_FRAME_VFP_CONTEXT_OFFSET 72
185
186#define ARM_VFP_CONTEXT_SIZE 264
187
188#ifndef ASM
189
190#ifdef __cplusplus
191extern "C" {
192#endif
193
194typedef struct {
195#if defined(ARM_MULTILIB_ARCH_V4)
196 uint32_t register_r4;
197 uint32_t register_r5;
198 uint32_t register_r6;
199 uint32_t register_r7;
200 uint32_t register_r8;
201 uint32_t register_r9;
202 uint32_t register_r10;
203 uint32_t register_fp;
204 uint32_t register_sp;
205 uint32_t register_lr;
206 uint32_t isr_dispatch_disable;
207#elif defined(ARM_MULTILIB_ARCH_V6M) || defined(ARM_MULTILIB_ARCH_V7M)
208 uint32_t register_r4;
209 uint32_t register_r5;
210 uint32_t register_r6;
211 uint32_t register_r7;
212 uint32_t register_r8;
213 uint32_t register_r9;
214 uint32_t register_r10;
215 uint32_t register_r11;
216 void *register_lr;
217 void *register_sp;
218 uint32_t isr_nest_level;
219#else
220 void *register_sp;
221#endif
222#ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
223 uint32_t thread_id;
224#endif
225#ifdef ARM_MULTILIB_VFP
226 uint64_t register_d8;
227 uint64_t register_d9;
228 uint64_t register_d10;
229 uint64_t register_d11;
230 uint64_t register_d12;
231 uint64_t register_d13;
232 uint64_t register_d14;
233 uint64_t register_d15;
234#endif
235#ifdef RTEMS_SMP
236 volatile bool is_executing;
237#endif
239
240static inline void _ARM_Data_memory_barrier( void )
241{
242#ifdef ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
243 __asm__ volatile ( "dmb" : : : "memory" );
244#else
246#endif
247}
248
249static inline void _ARM_Data_synchronization_barrier( void )
250{
251#ifdef ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
252 __asm__ volatile ( "dsb" : : : "memory" );
253#else
255#endif
256}
257
258static inline void _ARM_Instruction_synchronization_barrier( void )
259{
260#ifdef ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
261 __asm__ volatile ( "isb" : : : "memory" );
262#else
264#endif
265}
266
267#if defined(ARM_DISABLE_INLINE_ISR_DISABLE_ENABLE)
268uint32_t arm_interrupt_disable( void );
269void arm_interrupt_enable( uint32_t level );
270void arm_interrupt_flash( uint32_t level );
271#else
272static inline uint32_t arm_interrupt_disable( void )
273{
274 uint32_t level;
275
276#if defined(ARM_MULTILIB_ARCH_V4)
277 uint32_t arm_switch_reg;
278
279 /*
280 * Disable only normal interrupts (IRQ).
281 *
282 * In order to support fast interrupts (FIQ) such that they can do something
283 * useful, we have to disable the operating system support for FIQs. Having
284 * operating system support for them would require that FIQs are disabled
285 * during critical sections of the operating system and application. At this
286 * level IRQs and FIQs would be equal. It is true that FIQs could interrupt
287 * the non critical sections of IRQs, so here they would have a small
288 * advantage. Without operating system support, the FIQs can execute at any
289 * time (of course not during the service of another FIQ). If someone needs
290 * operating system support for a FIQ, she can trigger a software interrupt and
291 * service the request in a two-step process.
292 */
293 __asm__ volatile (
294 ARM_SWITCH_TO_ARM
295 "mrs %[level], cpsr\n"
296 "orr %[arm_switch_reg], %[level], #0x80\n"
297 "msr cpsr, %[arm_switch_reg]\n"
298 ARM_SWITCH_BACK
299 : [arm_switch_reg] "=&r" (arm_switch_reg), [level] "=&r" (level)
300 );
301#elif defined(ARM_MULTILIB_ARCH_V7M)
302 uint32_t basepri = 0x80;
303
304 __asm__ volatile (
305 "mrs %[level], basepri\n"
306 "msr basepri_max, %[basepri]\n"
307 : [level] "=&r" (level)
308 : [basepri] "r" (basepri)
309 );
310#endif
311
312 return level;
313}
314
315static inline void arm_interrupt_enable( uint32_t level )
316{
317#if defined(ARM_MULTILIB_ARCH_V4)
318 ARM_SWITCH_REGISTERS;
319
320 __asm__ volatile (
321 ARM_SWITCH_TO_ARM
322 "msr cpsr, %[level]\n"
323 ARM_SWITCH_BACK
324 : ARM_SWITCH_OUTPUT
325 : [level] "r" (level)
326 );
327#elif defined(ARM_MULTILIB_ARCH_V7M)
328 __asm__ volatile (
329 "msr basepri, %[level]\n"
330 :
331 : [level] "r" (level)
332 );
333#endif
334}
335
336static inline void arm_interrupt_flash( uint32_t level )
337{
338#if defined(ARM_MULTILIB_ARCH_V4)
339 uint32_t arm_switch_reg;
340
341 __asm__ volatile (
342 ARM_SWITCH_TO_ARM
343 "mrs %[arm_switch_reg], cpsr\n"
344 "msr cpsr, %[level]\n"
345 "msr cpsr, %[arm_switch_reg]\n"
346 ARM_SWITCH_BACK
347 : [arm_switch_reg] "=&r" (arm_switch_reg)
348 : [level] "r" (level)
349 );
350#elif defined(ARM_MULTILIB_ARCH_V7M)
351 uint32_t basepri;
352
353 __asm__ volatile (
354 "mrs %[basepri], basepri\n"
355 "msr basepri, %[level]\n"
356 "msr basepri, %[basepri]\n"
357 : [basepri] "=&r" (basepri)
358 : [level] "r" (level)
359 );
360#endif
361}
362#endif /* !ARM_DISABLE_INLINE_ISR_DISABLE_ENABLE */
363
364#define _CPU_ISR_Disable( _isr_cookie ) \
365 do { \
366 _isr_cookie = arm_interrupt_disable(); \
367 } while (0)
368
369#define _CPU_ISR_Enable( _isr_cookie ) \
370 arm_interrupt_enable( _isr_cookie )
371
372#define _CPU_ISR_Flash( _isr_cookie ) \
373 arm_interrupt_flash( _isr_cookie )
374
376{
377#if defined(ARM_MULTILIB_ARCH_V4)
378 return ( level & 0x80 ) == 0;
379#elif defined(ARM_MULTILIB_ARCH_V7M)
380 return level == 0;
381#endif
382}
383
384void _CPU_ISR_Set_level( uint32_t level );
385
386uint32_t _CPU_ISR_Get_level( void );
387
389 Context_Control *the_context,
390 void *stack_area_begin,
391 size_t stack_area_size,
392 uint32_t new_level,
393 void (*entry_point)( void ),
394 bool is_fp,
395 void *tls_area
396);
397
398#define _CPU_Context_Get_SP( _context ) \
399 (_context)->register_sp
400
401#ifdef RTEMS_SMP
402 static inline bool _CPU_Context_Get_is_executing(
404 )
405 {
406 return context->is_executing;
407 }
408
409 static inline void _CPU_Context_Set_is_executing(
411 bool is_executing
412 )
413 {
414 context->is_executing = is_executing;
415 }
416#endif
417
418#define _CPU_Context_Restart_self( _the_context ) \
419 _CPU_Context_restore( (_the_context) );
420
421#define _CPU_Context_Initialize_fp( _destination ) \
422 do { \
423 *(*(_destination)) = _CPU_Null_fp_context; \
424 } while (0)
425
426#define _CPU_Fatal_halt( _source, _err ) \
427 do { \
428 uint32_t _level; \
429 uint32_t _error = _err; \
430 _CPU_ISR_Disable( _level ); \
431 (void) _level; \
432 __asm__ volatile ("mov r0, %0\n" \
433 : "=r" (_error) \
434 : "0" (_error) \
435 : "r0" ); \
436 while (1); \
437 } while (0);
438
442void _CPU_Initialize( void );
443
444typedef void ( *CPU_ISR_handler )( void );
445
447 uint32_t vector,
448 CPU_ISR_handler new_handler,
449 CPU_ISR_handler *old_handler
450);
451
456
457void _CPU_Context_restore( Context_Control *new_context )
459
460#if defined(ARM_MULTILIB_ARCH_V7M)
461 void _ARMV7M_Start_multitasking( Context_Control *heir )
463 #define _CPU_Start_multitasking _ARMV7M_Start_multitasking
464#endif
465
466#ifdef RTEMS_SMP
467 uint32_t _CPU_SMP_Initialize( void );
468
469 bool _CPU_SMP_Start_processor( uint32_t cpu_index );
470
471 void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
472
473 void _CPU_SMP_Prepare_start_multitasking( void );
474
475 static inline uint32_t _CPU_SMP_Get_current_processor( void )
476 {
477 uint32_t mpidr;
478
479 /* Use ARMv7 Multiprocessor Affinity Register (MPIDR) */
480 __asm__ volatile (
481 "mrc p15, 0, %[mpidr], c0, c0, 5\n"
482 : [mpidr] "=&r" (mpidr)
483 );
484
485 return mpidr & 0xffU;
486 }
487
488 void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
489
490 static inline void _ARM_Send_event( void )
491 {
492 __asm__ volatile ( "sev" : : : "memory" );
493 }
494
495 static inline void _ARM_Wait_for_event( void )
496 {
497 __asm__ volatile ( "wfe" : : : "memory" );
498 }
499
500 static inline void _CPU_SMP_Processor_event_broadcast( void )
501 {
502 _ARM_Data_synchronization_barrier();
503 _ARM_Send_event();
504 }
505
506 static inline void _CPU_SMP_Processor_event_receive( void )
507 {
508 _ARM_Wait_for_event();
509 _ARM_Data_memory_barrier();
510 }
511#endif
512
513
514static inline uint32_t CPU_swap_u32( uint32_t value )
515{
516#if defined(__thumb2__)
517 __asm__ volatile (
518 "rev %0, %0"
519 : "=r" (value)
520 : "0" (value)
521 );
522 return value;
523#elif defined(__thumb__)
524 uint32_t byte1, byte2, byte3, byte4, swapped;
525
526 byte4 = (value >> 24) & 0xff;
527 byte3 = (value >> 16) & 0xff;
528 byte2 = (value >> 8) & 0xff;
529 byte1 = value & 0xff;
530
531 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
532 return swapped;
533#else
534 uint32_t tmp = value; /* make compiler warnings go away */
535 __asm__ volatile ("EOR %1, %0, %0, ROR #16\n"
536 "BIC %1, %1, #0xff0000\n"
537 "MOV %0, %0, ROR #8\n"
538 "EOR %0, %0, %1, LSR #8\n"
539 : "=r" (value), "=r" (tmp)
540 : "0" (value), "1" (tmp));
541 return value;
542#endif
543}
544
545static inline uint16_t CPU_swap_u16( uint16_t value )
546{
547#if defined(__thumb2__)
548 __asm__ volatile (
549 "rev16 %0, %0"
550 : "=r" (value)
551 : "0" (value)
552 );
553 return value;
554#else
555 return (uint16_t) (((value & 0xffU) << 8) | ((value >> 8) & 0xffU));
556#endif
557}
558
559typedef uint32_t CPU_Counter_ticks;
560
561uint32_t _CPU_Counter_frequency( void );
562
563CPU_Counter_ticks _CPU_Counter_read( void );
564
565static inline CPU_Counter_ticks _CPU_Counter_difference(
566 CPU_Counter_ticks second,
567 CPU_Counter_ticks first
568)
569{
570 return second - first;
571}
572
573void *_CPU_Thread_Idle_body( uintptr_t ignored );
574
575#if defined(ARM_MULTILIB_ARCH_V4)
576
577typedef enum {
578 ARM_EXCEPTION_RESET = 0,
579 ARM_EXCEPTION_UNDEF = 1,
580 ARM_EXCEPTION_SWI = 2,
581 ARM_EXCEPTION_PREF_ABORT = 3,
582 ARM_EXCEPTION_DATA_ABORT = 4,
583 ARM_EXCEPTION_RESERVED = 5,
584 ARM_EXCEPTION_IRQ = 6,
585 ARM_EXCEPTION_FIQ = 7,
586 MAX_EXCEPTIONS = 8,
587 ARM_EXCEPTION_MAKE_ENUM_32_BIT = 0xffffffff
588} Arm_symbolic_exception_name;
589
590#endif /* defined(ARM_MULTILIB_ARCH_V4) */
591
592typedef struct {
593 uint32_t register_fpexc;
594 uint32_t register_fpscr;
595 uint64_t register_d0;
596 uint64_t register_d1;
597 uint64_t register_d2;
598 uint64_t register_d3;
599 uint64_t register_d4;
600 uint64_t register_d5;
601 uint64_t register_d6;
602 uint64_t register_d7;
603 uint64_t register_d8;
604 uint64_t register_d9;
605 uint64_t register_d10;
606 uint64_t register_d11;
607 uint64_t register_d12;
608 uint64_t register_d13;
609 uint64_t register_d14;
610 uint64_t register_d15;
611 uint64_t register_d16;
612 uint64_t register_d17;
613 uint64_t register_d18;
614 uint64_t register_d19;
615 uint64_t register_d20;
616 uint64_t register_d21;
617 uint64_t register_d22;
618 uint64_t register_d23;
619 uint64_t register_d24;
620 uint64_t register_d25;
621 uint64_t register_d26;
622 uint64_t register_d27;
623 uint64_t register_d28;
624 uint64_t register_d29;
625 uint64_t register_d30;
626 uint64_t register_d31;
628
629typedef struct {
630 uint32_t register_r0;
631 uint32_t register_r1;
632 uint32_t register_r2;
633 uint32_t register_r3;
634 uint32_t register_r4;
635 uint32_t register_r5;
636 uint32_t register_r6;
637 uint32_t register_r7;
638 uint32_t register_r8;
639 uint32_t register_r9;
640 uint32_t register_r10;
641 uint32_t register_r11;
642 uint32_t register_r12;
643 uint32_t register_sp;
644 void *register_lr;
645 void *register_pc;
646#if defined(ARM_MULTILIB_ARCH_V4)
647 uint32_t register_cpsr;
648 Arm_symbolic_exception_name vector;
649#elif defined(ARM_MULTILIB_ARCH_V6M) || defined(ARM_MULTILIB_ARCH_V7M)
650 uint32_t register_xpsr;
651 uint32_t vector;
652#endif
653 const ARM_VFP_context *vfp_context;
654 uint32_t reserved_for_stack_alignment;
656
658
659void _ARM_Exception_default( CPU_Exception_frame *frame );
660
662typedef uintptr_t CPU_Uint32ptr;
663
664#ifdef __cplusplus
665}
666#endif
667
668#endif /* ASM */
669
672#endif /* _RTEMS_SCORE_CPU_H */
ARM Assembler Support API.
Basic Definitions.
#define RTEMS_COMPILER_MEMORY_BARRIER()
Definition: basedefs.h:77
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
void _CPU_ISR_Set_level(uint32_t level)
Sets the hardware interrupt level by the level value.
Definition: cpu.c:57
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:45
Definition: cpu.h:662
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
#define CPU_swap_u16(value)
Definition: cpu.h:642
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
Definition: cpu.h:592
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Thread register context.
Definition: cpu.h:194
unsigned context
Definition: tlb.h:1
