RTEMS 5.2
Helpers for Manipulating Timestamps. More...
| RTEMS_INLINE_ROUTINE void | _Timestamp_Set (Timestamp_Control *_time, time_t _seconds, long _nanoseconds) |
| Sets timestamp to specified seconds and nanoseconds. More... | |
| RTEMS_INLINE_ROUTINE void | _Timestamp_Set_to_zero (Timestamp_Control *_time) |
| Sets the timestamp to zero. More... | |
| RTEMS_INLINE_ROUTINE bool | _Timestamp_Less_than (const Timestamp_Control *_lhs, const Timestamp_Control *_rhs) |
| Checks if the left hand side timestamp is less than the right one. More... | |
| RTEMS_INLINE_ROUTINE bool | _Timestamp_Greater_than (const Timestamp_Control *_lhs, const Timestamp_Control *_rhs) |
| Checks if the left hand side timestamp is greater than the right one. More... | |
| RTEMS_INLINE_ROUTINE bool | _Timestamp_Equal_to (const Timestamp_Control *_lhs, const Timestamp_Control *_rhs) |
| Checks if the timestamps are equal. More... | |
| RTEMS_INLINE_ROUTINE void | _Timestamp_Add_to (Timestamp_Control *_time, const Timestamp_Control *_add) |
| Adds two timestamps. More... | |
| RTEMS_INLINE_ROUTINE void | _Timestamp_Subtract (const Timestamp_Control *_start, const Timestamp_Control *_end, Timestamp_Control *_result) |
| Subtracts two timestamps. More... | |
| RTEMS_INLINE_ROUTINE void | _Timestamp_Divide (const Timestamp_Control *_lhs, const Timestamp_Control *_rhs, uint32_t *_ival_percentage, uint32_t *_fval_percentage) |
| Divides a timestamp by another timestamp. More... | |
| RTEMS_INLINE_ROUTINE time_t | _Timestamp_Get_seconds (const Timestamp_Control *_time) |
| Gets seconds portion of timestamp. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Timestamp_Get_nanoseconds (const Timestamp_Control *_time) |
| Gets nanoseconds portion of timestamp. More... | |
| RTEMS_INLINE_ROUTINE uint64_t | _Timestamp_Get_as_nanoseconds (const Timestamp_Control *_time) |
| Gets the timestamp as nanoseconds. More... | |
| RTEMS_INLINE_ROUTINE void | _Timestamp_To_timespec (const Timestamp_Control *_timestamp, struct timespec *_timespec) |
| Converts timestamp to struct timespec. More... | |
| RTEMS_INLINE_ROUTINE void | _Timestamp_To_timeval (const Timestamp_Control *_timestamp, struct timeval *_timeval) |
| Converts timestamp to struct timeval. More... | |
This include file contains helpers for manipulating timestamps.
