RTEMS 5.2
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
thread.h File Reference
Constants and Structures Related with the Thread Control Block. More...
#include <rtems/score/atomic.h>
#include <rtems/score/context.h>
#include <rtems/score/freechain.h>
#include <rtems/score/isrlock.h>
#include <rtems/score/objectdata.h>
#include <rtems/score/priority.h>
#include <rtems/score/schedulernode.h>
#include <rtems/score/stack.h>
#include <rtems/score/states.h>
#include <rtems/score/threadq.h>
#include <rtems/score/timestamp.h>
struct  Thread_Entry_idle
 Data for idle thread entry. More...
struct  Thread_Entry_numeric
 Data for thread entry with one numeric argument and no return value. More...
struct  Thread_Entry_pointer
 Data for thread entry with one pointer argument and a pointer return value. More...
struct  Thread_Entry_information
 Thread entry information. More...
struct  Thread_Start_information
struct  Thread_Scheduler_control
 Thread scheduler control. More...
union  Thread_Wait_information_Object_argument_type
 Union type to hold a pointer to an immutable or a mutable object. More...
struct  Thread_Wait_information
 Information required to manage a thread while it is blocked. More...
struct  Thread_Timer_information
 Information required to manage a thread timer. More...
struct  Thread_Proxy_control
struct  Thread_Action
 Thread action. More...
struct  Thread_Keys_information
 Per-thread information for POSIX Keys. More...
struct  Thread_Action_control
 Control block to manage thread actions. More...
struct  Thread_Life_control
 Thread life control. More...
struct  Thread_Capture_control
struct  _Thread_Control
struct  Thread_Control_add_on
 Thread control add-on. More...
struct  Thread_Information
 The thread object information. More...
#define RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE
#define RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT
#define THREAD_API_FIRST   THREAD_API_RTEMS
#define THREAD_API_LAST   THREAD_API_POSIX
#define THREAD_DEFAULT_MAXIMUM_NAME_SIZE   16
 The default maximum size of a thread name in characters (including the terminating '\0' character). More...
#define _Thread_queue_Heads_size   sizeof(Thread_queue_Heads)
 Size of the thread queue heads of a particular application. More...
#define THREAD_INFORMATION_DEFINE_ZERO(name, api, cls)
#define THREAD_INFORMATION_DEFINE(name, api, cls, max)
typedef void *Thread RTEMS_DEPRECATED
typedef CPU_Uint32ptr Thread_Entry_numeric_type
 Type of the numeric argument of a thread entry function with at least one numeric argument. More...
typedef void(* Thread_CPU_budget_algorithm_callout) (Thread_Control *)
typedef unsigned int Thread_Wait_flags
 This type is able to contain several flags used to control the wait class and state of a thread. More...
typedef struct Thread_Action Thread_Action
typedef void(* Thread_Action_handler) (Thread_Control *the_thread, Thread_Action *action, ISR_lock_Context *lock_context)
 Thread action handler. More...
typedef void(* rtems_per_thread_routine) (Thread_Control *)
typedef struct Thread_Configured_control Thread_Configured_control
 The configured thread control block. More...
typedef Thread_queue_Heads Thread_queue_Configured_heads
 The configured thread queue heads. More...
enum  Thread_CPU_budget_algorithms { THREAD_CPU_BUDGET_ALGORITHM_NONE , THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE , THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE , THREAD_CPU_BUDGET_ALGORITHM_CALLOUT }
enum  Thread_APIs { THREAD_API_RTEMS , THREAD_API_POSIX }
enum  Thread_Life_state {
  THREAD_LIFE_PROTECTED = 0x1 , THREAD_LIFE_RESTARTING = 0x2 , THREAD_LIFE_TERMINATING = 0x4 , THREAD_LIFE_CHANGE_DEFERRED = 0x8 ,
  THREAD_LIFE_DETACHED = 0x10
 Thread life states. More...
void rtems_iterate_over_all_threads (rtems_per_thread_routine routine) RTEMS_DEPRECATED
 Deprecated, use rtems_task_iterate() instead. More...
Objects_Control_Thread_Allocate_unlimited (Objects_Information *information)
 Return an inactive thread object or NULL. More...
const Thread_Control_add_on _Thread_Control_add_ons []
 Thread control add-ons. More...
const size_t _Thread_Control_add_on_count
 Thread control add-on count. More...
const size_t _Thread_Initial_thread_count
 Count of configured threads. More...
const size_t _Thread_Maximum_name_size
 Maximum size of a thread name in characters (including the terminating '\0' character). More...
Thread_Information _Thread_Information
 The internal thread objects information.
char _Thread_Idle_stacks []
 The idle thread stacks. More...
This include file contains all constants and structures associated with the thread control block.
