RTEMS 5.2
Thread_Start_information Struct Reference
#include <thread.h>
Thread_Entry_information Entry
bool is_preemptible
Thread_CPU_budget_algorithms budget_algorithm
Thread_CPU_budget_algorithm_callout budget_callout
uint32_t isr_level
Priority_Control initial_priority
void * allocated_stack
 This field is a pointer to the allocated stack area, otherwise it is NULL.
Stack_Control Initial_stack
Context_Control_fpfp_context
void * tls_area
The following structure contains the information which defines the starting state of a thread.
Field Documentation
◆ budget_algorithm
Thread_CPU_budget_algorithms Thread_Start_information::budget_algorithm
This field indicates the CPU budget algorith.
◆ budget_callout
Thread_CPU_budget_algorithm_callout Thread_Start_information::budget_callout
This field is the routine to invoke when the CPU allotment is consumed.
◆ Entry
Thread_Entry_information Thread_Start_information::Entry
This field contains the thread entry information.
◆ fp_context
Context_Control_fp* Thread_Start_information::fp_context
This field is the initial FP context area address.
◆ initial_priority
Priority_Control Thread_Start_information::initial_priority
This field is the initial priority.
◆ Initial_stack
Stack_Control Thread_Start_information::Initial_stack
This field is the stack information.
◆ is_preemptible
bool Thread_Start_information::is_preemptible
This field indicates whether the thread was preemptible when it started.
◆ isr_level
uint32_t Thread_Start_information::isr_level
This field is the initial ISR disable level of this thread.
◆ tls_area
void* Thread_Start_information::tls_area
The thread-local storage (TLS) area
