- u -
uid :
rtems_shell_env_t
rtems_user_env_t
umask :
rtems_user_env_t
unallocated :
rtems_object_api_class_information
unavail_blocks :
rtems_flashdisk
rtems_flashdisk_config
unblock :
Scheduler_Operations
unified_work_area :
rtems_configuration_table
unite :
drvmgr_bus_ops
unload :
rtems_rtl_loader_table_s
unmount_task :
rtems_filesystem_mount_table_entry_tt
unresolved :
rtems_rtl_data_s
rtems_rtl_obj_s
update_priority :
usage_count :
rtems_profiling_smp_lock
use_pec :
i2c_bus
used :
rtems_flashdisk
used_blocks :
Heap_Statistics
user :
_rtems_rfs_file_system
rtems_bdbuf_buffer
rtems_blkdev_sg_buffer
user_data :
Watchdog_Control
User_initialization_tasks_table :
rtems_api_configuration_table
User_initialization_threads_table :
posix_api_configuration_table
users :
CORE_spinlock_Control
rtems_bdbuf_group
rtems_rtl_obj_s
uses :
rtems_disk_device
