Watchdog_Control Struct Reference
The control block used to manage each watchdog timer. More...
#include <watchdog.h>
Collaboration diagram for Watchdog_Control:
Collaboration graph
[legend]
Chain_Node Node
 This field is a Chain Node structure and allows this to be placed on chains for set management.
Watchdog_States state
 This field is the state of the watchdog. More...
Watchdog_Interval initial
 This field is the initially requested interval. More...
Watchdog_Interval delta_interval
 This field is the remaining portion of the interval. More...
Watchdog_Interval start_time
 This field is the number of system clock ticks when this was scheduled. More...
Watchdog_Interval stop_time
 This field is the number of system clock ticks when this was suspended. More...
Watchdog_Service_routine_entry routine
 This field is the function to invoke. More...
Objects_Id id
 This field is the Id to pass as an argument to the routine. More...
void * user_data
 This field is an untyped pointer to user data that is passed to the watchdog handler routine.
The following record defines the control block used to manage each watchdog timer.
Field Documentation
◆ delta_interval
Watchdog_Interval Watchdog_Control::delta_interval
◆ id
Objects_Id Watchdog_Control::id
Referenced by _Watchdog_Initialize(), and _Watchdog_Preinitialize().
◆ initial
Watchdog_Interval Watchdog_Control::initial
Referenced by _Watchdog_Insert_seconds(), and _Watchdog_Insert_ticks().
◆ routine
Watchdog_Service_routine_entry Watchdog_Control::routine
◆ start_time
Watchdog_Interval Watchdog_Control::start_time
◆ state
Watchdog_States Watchdog_Control::state
◆ stop_time
Watchdog_Interval Watchdog_Control::stop_time
