rtems_api_configuration_table Struct Reference
The following records define the Configuration Table. More...
#include <config.h>
Collaboration diagram for rtems_api_configuration_table:
Collaboration graph
[legend]
uint32_t maximum_tasks
 This field contains the maximum number of Classic API Tasks which are configured for this application.
bool notepads_enabled
 This field indicates whether Classic API notepads are enabled or disabled.
uint32_t maximum_timers
 This field contains the maximum number of Classic API Timers which are configured for this application.
uint32_t maximum_semaphores
 This field contains the maximum number of Classic API Semaphores which are configured for this application.
uint32_t maximum_message_queues
 This field contains the maximum number of Classic API Message Queues which are configured for this application.
uint32_t maximum_partitions
 This field contains the maximum number of Classic API Partitions which are configured for this application.
uint32_t maximum_regions
 This field contains the maximum number of Classic API Regions which are configured for this application.
uint32_t maximum_ports
 This field contains the maximum number of Classic API Dual Ported Memory Areas which are configured for this application.
uint32_t maximum_periods
 This field contains the maximum number of Classic API Rate Monotonic Periods which are configured for this application.
uint32_t maximum_barriers
 This field contains the maximum number of Classic API Barriers which are configured for this application.
uint32_t number_of_initialization_tasks
 This field contains the number of Classic API Initialization Tasks which are configured for this application.
rtems_initialization_tasks_tableUser_initialization_tasks_table
 This field is the set of Classic API Initialization Tasks which are configured for this application.
The information contained in this table is required in all RTEMS systems, whether single or multiprocessor. This table primarily defines the following:
