This encapsulates functionality related to the application's configuration of the Classic API including the maximum number of each class of objects. More...
struct | posix_initialization_threads_table |
For now, we are only allowing the user to specify the entry point and stack size for POSIX initialization threads. More... | |
struct | posix_api_configuration_table |
The following records define the POSIX Configuration Table. More... | |
struct | rtems_api_configuration_table |
The following records define the Configuration Table. More... | |
posix_api_configuration_table | Configuration_POSIX_API |
POSIX API configuration table. More... | |
rtems_api_configuration_table | Configuration_RTEMS_API |
RTEMS API Configuration Table. More... | |
This include file contains the table of user defined configuration parameters specific for the RTEMS API.
posix_api_configuration_table Configuration_POSIX_API |
This is the POSIX API Configuration Table expected to be generated by confdefs.h.
Referenced by _POSIX_signals_Manager_Initialization(), and _Thread_Global_construction().
rtems_api_configuration_table Configuration_RTEMS_API |
This is the RTEMS API Configuration Table expected to be generated by confdefs.h.
Referenced by _Thread_Global_construction().
