This handler encapsulates functionality related to the management of threads. More...
Files | |
file | iterateoverthreads.c |
Iterates Over All Threads. | |
file | thread.c |
Initialize Thread Handler. | |
file | threadchangepriority.c |
Changes the Priority of a Thread. | |
file | threadclearstate.c |
Clear Thread state. | |
file | threadcreateidle.c |
Create Idle Thread. | |
file | threaddisabledispatch.c |
Disaable Thread Dispatching. | |
file | threaddispatch.c |
Dispatch Thread. | |
file | threaddispatchdisablelevel.c |
Thread Dispatch Disable Functions. | |
file | threadenabledispatch.c |
Enable Dispatching of Threads. | |
file | threadget.c |
Maps Thread IDs to TCB Pointer. | |
file | threadglobalconstruction.c |
Thread Global Construction. | |
file | threadhandler.c |
Thread Handler. | |
file | threadinitialize.c |
Initialize Thread. | |
file | threadloadenv.c |
Initializes Enviroment for A Thread. | |
file | threadrestart.c |
Restart Thread. | |
file | threadsetpriority.c |
Set Thread Priority. | |
file | threadsetstate.c |
Sets States for a Thread. | |
file | threadstackallocate.c |
Stack Allocate Helper. | |
file | threadstackfree.c |
Deallocate Thread Stack. | |
file | threadstart.c |
Initializes Thread and Executes it. | |
file | threadstartmultitasking.c |
Start Thread Multitasking. | |
file | threadtimeout.c |
Thread Wait Timeout. | |
file | threadyield.c |
Thread Yield. | |
struct | rtems_task_variable_t |
Internal structure used to manager per task variables. More... | |
struct | Thread_Start_information |
The following structure contains the information which defines the starting state of a thread. More... | |
union | Thread_Wait_information_Object_argument_type |
Union type to hold a pointer to an immutable or a mutable object. More... | |
struct | Thread_Wait_information |
Information required to manage a thread while it is blocked. More... | |
struct | Thread_Proxy_control |
The following defines the control block used to manage each thread proxy. More... | |
struct | Thread_Action |
Thread action. More... | |
struct | Thread_Action_control |
Control block to manage thread actions. More... | |
struct | Thread_Life_control |
Thread life control. More... | |
struct | Thread_Scheduler_control |
Thread scheduler control. More... | |
struct | Thread_Capture_control |
struct | Thread_Control |
This structure defines the Thread Control Block (TCB). More... | |
struct | Thread_Control_add_on |
Thread control add-on. More... | |
#define | RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT |
#define | THREAD_API_FIRST THREAD_API_RTEMS |
This macro defines the first API which has threads. More... | |
#define | THREAD_API_LAST THREAD_API_POSIX |
This macro defines the last API which has threads. More... | |
#define | THREAD_STATUS_PROXY_BLOCKING 0x1111111 |
The following structure contains the information necessary to manage a thread which it is waiting for a resource. | |
#define | THREAD_CHAIN_NODE_TO_THREAD(node) RTEMS_CONTAINER_OF( node, Thread_Control, Wait.Node.Chain ) |
#define | THREAD_RBTREE_NODE_TO_THREAD(node) RTEMS_CONTAINER_OF( node, Thread_Control, Wait.Node.RBTree ) |
#define | _Thread_Lock_set(the_thread, new_lock) do { } while ( 0 ) |
Sets a new thread lock. More... | |
#define | _Thread_Lock_restore_default(the_thread) do { } while ( 0 ) |
Restores the default thread lock. More... | |
#define | THREAD_WAIT_FLAGS_INITIAL 0x0U |
The initial thread wait flags value set by _Thread_Initialize(). | |
#define | THREAD_WAIT_STATE_MASK 0xffU |
Mask to get the thread wait state flags. | |
#define | THREAD_WAIT_STATE_INTEND_TO_BLOCK 0x1U |
Indicates that the thread begins with the blocking operation. More... | |
#define | THREAD_WAIT_STATE_BLOCKED 0x2U |
Indicates that the thread completed the blocking operation. | |
#define | THREAD_WAIT_STATE_READY_AGAIN 0x4U |
Indicates that a condition to end the thread wait occurred. More... | |
#define | THREAD_WAIT_CLASS_MASK 0xff00U |
Mask to get the thread wait class flags. | |
#define | THREAD_WAIT_CLASS_EVENT 0x100U |
Indicates that the thread waits for an event. | |
#define | THREAD_WAIT_CLASS_SYSTEM_EVENT 0x200U |
Indicates that the thread waits for a system event. | |
#define | THREAD_WAIT_CLASS_OBJECT 0x400U |
Indicates that the thread waits for a object. | |
Typedefs | |
typedef Timestamp_Control | Thread_CPU_usage_t |
typedef void * | Thread |
The following defines the "return type" of a thread. More... | |
typedef CPU_Uint32ptr | Thread_Entry_numeric_type |
Type of the numeric argument of a thread entry function with at least one numeric argument. More... | |
typedef Thread(* | Thread_Entry) (void) |
This type corresponds to a very simple style thread entry point. More... | |
typedef Thread(* | Thread_Entry_numeric) (Thread_Entry_numeric_type) |
This type corresponds to a thread entry point which takes a single unsigned thirty-two bit integer as an argument. | |
typedef Thread(* | Thread_Entry_pointer) (void *) |
This type corresponds to a thread entry point which takes a single untyped pointer as an argument. | |
typedef Thread(* | Thread_Entry_both_pointer_first) (void *, Thread_Entry_numeric_type) |
This type corresponds to a thread entry point which takes a single untyped pointer and an unsigned thirty-two bit integer as arguments. | |
typedef Thread(* | Thread_Entry_both_numeric_first) (Thread_Entry_numeric_type, void *) |
This type corresponds to a thread entry point which takes a single unsigned thirty-two bit integer and an untyped pointer and an as arguments. | |
typedef void(* | Thread_CPU_budget_algorithm_callout) (Thread_Control *) |
This defines thes the entry point for the thread specific timeslice budget management algorithm. | |
typedef unsigned int | Thread_Wait_flags |
This type is able to contain several flags used to control the wait class and state of a thread. More... | |
typedef struct Thread_Action | Thread_Action |
typedef void(* | Thread_Action_handler) (Thread_Control *thread, Thread_Action *action, struct Per_CPU_Control *cpu, ISR_Level level) |
Thread action handler. More... | |
typedef void(* | rtems_per_thread_routine) (Thread_Control *) |
This defines the type for a method which operates on a single thread. | |
typedef bool(* | Thread_Change_priority_filter) (Thread_Control *the_thread, Priority_Control *new_priority, void *arg) |
Filters a thread priority change. More... | |
Enumerations | |
enum | Thread_Start_types { THREAD_START_NUMERIC, THREAD_START_POINTER } |
The following defines the ways in which the entry point for a thread can be invoked. More... | |
enum | Thread_CPU_budget_algorithms { THREAD_CPU_BUDGET_ALGORITHM_NONE, THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE, THREAD_CPU_BUDGET_ALGORITHM_CALLOUT } |
The following lists the algorithms used to manage the thread cpu budget. More... | |
enum | Thread_APIs { THREAD_API_RTEMS, THREAD_API_POSIX } |
The following record defines the control block used to manage each thread. More... | |
enum | Thread_Life_state { THREAD_LIFE_NORMAL = 0x0, THREAD_LIFE_PROTECTED = 0x1, THREAD_LIFE_RESTARTING = 0x2, THREAD_LIFE_PROTECTED_RESTARTING = 0x3, THREAD_LIFE_TERMINATING = 0x4, THREAD_LIFE_PROTECTED_TERMINATING = 0x5, THREAD_LIFE_RESTARTING_TERMINATING = 0x6, THREAD_LIFE_PROTECTED_RESTARTING_TERMINATING = 0x7 } |
Thread life states. More... | |
void * | _Thread_Idle_body (uintptr_t ignored) |
This routine is the body of the system idle thread. More... | |
void | rtems_iterate_over_all_threads (rtems_per_thread_routine routine) |
Iterates over all threads. More... | |
RTEMS_INLINE_ROUTINE bool | _Thread_Dispatch_is_enabled (void) |
Indicates if the executing thread is inside a thread dispatch critical section. More... | |
RTEMS_INLINE_ROUTINE uint32_t | _Thread_Dispatch_get_disable_level (void) |
Gets thread dispatch disable level. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Dispatch_initialization (void) |
Thread dispatch initialization. More... | |
RTEMS_INLINE_ROUTINE uint32_t | _Thread_Dispatch_increment_disable_level (void) |
Increase thread dispatch disable level. More... | |
RTEMS_INLINE_ROUTINE uint32_t | _Thread_Dispatch_decrement_disable_level (void) |
Decrease thread dispatch disable level. More... | |
RTEMS_INLINE_ROUTINE void | _Giant_Acquire (Per_CPU_Control *cpu_self) |
RTEMS_INLINE_ROUTINE void | _Giant_Release (Per_CPU_Control *cpu_self) |
void | _Thread_Dispatch (void) |
Performs a thread dispatch if necessary. More... | |
void | _Thread_Do_dispatch (Per_CPU_Control *cpu_self, ISR_Level level) |
Performs a thread dispatch on the current processor. More... | |
RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Dispatch_disable_critical (const ISR_lock_Context *lock_context) |
Disables thread dispatching inside a critical section (interrupts disabled). More... | |
RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Dispatch_disable (void) |
Disables thread dispatching. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Dispatch_enable (Per_CPU_Control *cpu_self) |
Enables thread dispatching. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Disable_dispatch (void) |
Disables thread dispatching and acquires the Giant lock. | |
RTEMS_INLINE_ROUTINE void | _Thread_Enable_dispatch_body (void) |
void | _Thread_Enable_dispatch (void) |
Enables thread dispatching and releases the Giant lock. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Unnest_dispatch (void) |
void | _Thread_Handler_initialization (void) |
Initialize thread handler. More... | |
void | _Thread_Create_idle (void) |
Create idle thread. More... | |
void | _Thread_Start_multitasking (void) |
Start thread multitasking. More... | |
size_t | _Thread_Stack_Allocate (Thread_Control *the_thread, size_t stack_size) |
Allocate the requested stack space for the thread. More... | |
void | _Thread_Stack_Free (Thread_Control *the_thread) |
Deallocate thread stack. More... | |
bool | _Thread_Initialize (Objects_Information *information, Thread_Control *the_thread, const struct Scheduler_Control *scheduler, void *stack_area, size_t stack_size, bool is_fp, Priority_Control priority, bool is_preemptible, Thread_CPU_budget_algorithms budget_algorithm, Thread_CPU_budget_algorithm_callout budget_callout, uint32_t isr_level, Objects_Name name) |
Initialize thread. More... | |
bool | _Thread_Start (Thread_Control *the_thread, Thread_Start_types the_prototype, void *entry_point, void *pointer_argument, Thread_Entry_numeric_type numeric_argument, Per_CPU_Control *cpu) |
Initializes thread and executes it. More... | |
bool | _Thread_Restart (Thread_Control *the_thread, Thread_Control *executing, void *pointer_argument, Thread_Entry_numeric_type numeric_argument) |
void | _Thread_Yield (Thread_Control *executing) |
bool | _Thread_Set_life_protection (bool protect) |
void | _Thread_Life_action_handler (Thread_Control *executing, Thread_Action *action, Per_CPU_Control *cpu, ISR_Level level) |
void | _Thread_Kill_zombies (void) |
Kills all zombie threads in the system. More... | |
void | _Thread_Close (Thread_Control *the_thread, Thread_Control *executing) |
Closes the thread. More... | |
States_Control | _Thread_Clear_state (Thread_Control *the_thread, States_Control state) |
Clears the specified thread state. More... | |
States_Control | _Thread_Set_state (Thread_Control *the_thread, States_Control state) |
Sets the specified thread state. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Ready (Thread_Control *the_thread) |
Clears all thread states. More... | |
void | _Thread_Load_environment (Thread_Control *the_thread) |
Initializes enviroment for a thread. More... | |
void | _Thread_Handler (void) |
Wrapper function for all threads. More... | |
void * | _Thread_Global_construction (void) |
Executes the global constructors and then restarts itself as the first initialization thread. More... | |
void | _Thread_Delay_ended (Objects_Id id, void *ignored) |
Ended the delay of a thread. More... | |
RTEMS_INLINE_ROUTINE bool | _Thread_Priority_less_than (Priority_Control left, Priority_Control right) |
Returns true if the left thread priority is less than the right thread priority in the intuitive sense of priority and false otherwise. | |
RTEMS_INLINE_ROUTINE Priority_Control | _Thread_Priority_highest (Priority_Control left, Priority_Control right) |
Returns the highest priority of the left and right thread priorities in the intuitive sense of priority. | |
void | _Thread_Change_priority (Thread_Control *the_thread, Priority_Control new_priority, void *arg, Thread_Change_priority_filter filter, bool prepend_it) |
Changes the priority of a thread if allowed by the filter function. More... | |
void | _Thread_Raise_priority (Thread_Control *the_thread, Priority_Control new_priority) |
Raises the priority of a thread. More... | |
void | _Thread_Restore_priority (Thread_Control *the_thread) |
Sets the current to the real priority of a thread. More... | |
void | _Thread_Set_priority (Thread_Control *the_thread, Priority_Control new_priority, Priority_Control *old_priority, bool prepend_it) |
Sets the priority of a thread. More... | |
Thread_Control * | _Thread_Get (Objects_Id id, Objects_Locations *location) |
Maps thread Id to a TCB pointer. More... | |
Thread_Control * | _Thread_Get_interrupt_disable (Objects_Id id, Objects_Locations *location, ISR_lock_Context *lock_context) |
Gets a thread by its identifier. More... | |
RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Get_CPU (const Thread_Control *thread) |
RTEMS_INLINE_ROUTINE void | _Thread_Set_CPU (Thread_Control *thread, Per_CPU_Control *cpu) |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_executing (const Thread_Control *the_thread) |
This function returns true if the_thread is the currently executing thread, and false otherwise. | |
RTEMS_INLINE_ROUTINE bool | _Thread_Get_time_of_last_context_switch (Thread_Control *the_thread, Timestamp_Control *time_of_context_switch) |
Returns true and sets time_of_context_switch to the time of the last context switch when the thread is currently executing in the system, otherwise false. | |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_heir (const Thread_Control *the_thread) |
This function returns true if the_thread is the heir thread, and false otherwise. | |
RTEMS_INLINE_ROUTINE void | _Thread_Unblock (Thread_Control *the_thread) |
This routine clears any blocking state for the_thread. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Restart_self (Thread_Control *executing) |
This routine resets the current context of the calling thread to that of its initial state. | |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_allocated_fp (const Thread_Control *the_thread) |
This function returns true if the floating point context of the_thread is currently loaded in the floating point unit, and false otherwise. | |
RTEMS_INLINE_ROUTINE void | _Thread_Save_fp (Thread_Control *executing) |
RTEMS_INLINE_ROUTINE void | _Thread_Restore_fp (Thread_Control *executing) |
RTEMS_INLINE_ROUTINE void | _Thread_Deallocate_fp (void) |
This routine is invoked when the currently loaded floating point context is now longer associated with an active thread. | |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_context_switch_necessary (void) |
This function returns true if dispatching is disabled, and false otherwise. | |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_null (const Thread_Control *the_thread) |
This function returns true if the_thread is NULL and false otherwise. | |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_proxy_blocking (uint32_t code) |
Is proxy blocking. More... | |
RTEMS_INLINE_ROUTINE uint32_t | _Thread_Get_maximum_internal_threads (void) |
RTEMS_INLINE_ROUTINE Thread_Control * | _Thread_Internal_allocate (void) |
RTEMS_INLINE_ROUTINE Thread_Control * | _Thread_Get_heir_and_make_it_executing (Per_CPU_Control *cpu_self) |
Gets the heir of the processor and makes it executing. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Update_cpu_time_used (Thread_Control *executing, Timestamp_Control *time_of_last_context_switch) |
RTEMS_INLINE_ROUTINE void | _Thread_Action_control_initialize (Thread_Action_control *action_control) |
RTEMS_INLINE_ROUTINE void | _Thread_Action_initialize (Thread_Action *action, Thread_Action_handler handler) |
RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Action_ISR_disable_and_acquire_for_executing (ISR_Level *level) |
RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_Action_ISR_disable_and_acquire (Thread_Control *thread, ISR_Level *level) |
RTEMS_INLINE_ROUTINE void | _Thread_Action_release_and_ISR_enable (Per_CPU_Control *cpu, ISR_Level level) |
RTEMS_INLINE_ROUTINE void | _Thread_Add_post_switch_action (Thread_Control *thread, Thread_Action *action) |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_life_restarting (Thread_Life_state life_state) |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_life_terminating (Thread_Life_state life_state) |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_life_protected (Thread_Life_state life_state) |
RTEMS_INLINE_ROUTINE bool | _Thread_Is_life_changing (Thread_Life_state life_state) |
RTEMS_INLINE_ROUTINE bool | _Thread_Owns_resources (const Thread_Control *the_thread) |
Returns true if the thread owns resources, and false otherwise. More... | |
RTEMS_INLINE_ROUTINE Thread_Control * | _Thread_Lock_acquire_default_for_executing (ISR_lock_Context *lock_context) |
Acquires the default thread lock and returns the executing thread. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Lock_acquire_default_critical (Thread_Control *the_thread, ISR_lock_Context *lock_context) |
Acquires the default thread lock inside a critical section (interrupts disabled). More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Lock_acquire_default (Thread_Control *the_thread, ISR_lock_Context *lock_context) |
Acquires the default thread lock. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Lock_release_critical (ISR_lock_Control *lock, ISR_lock_Context *lock_context) |
Releases the thread lock inside a critical section (interrupts disabled). More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Lock_release (ISR_lock_Control *lock, ISR_lock_Context *lock_context) |
Releases the thread lock. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Lock_release_default_critical (Thread_Control *the_thread, ISR_lock_Context *lock_context) |
Releases the default thread lock inside a critical section (interrupts disabled). More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Lock_release_default (Thread_Control *the_thread, ISR_lock_Context *lock_context) |
Releases the default thread lock. More... | |
RTEMS_INLINE_ROUTINE ISR_lock_Control * | _Thread_Lock_acquire (Thread_Control *the_thread, ISR_lock_Context *lock_context) |
Acquires the thread lock. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Wait_flags_set (Thread_Control *the_thread, Thread_Wait_flags flags) |
RTEMS_INLINE_ROUTINE Thread_Wait_flags | _Thread_Wait_flags_get (const Thread_Control *the_thread) |
RTEMS_INLINE_ROUTINE bool | _Thread_Wait_flags_try_change_critical (Thread_Control *the_thread, Thread_Wait_flags expected_flags, Thread_Wait_flags desired_flags) |
Tries to change the thread wait flags inside a critical section (interrupts disabled). More... | |
RTEMS_INLINE_ROUTINE bool | _Thread_Wait_flags_try_change (Thread_Control *the_thread, Thread_Wait_flags expected_flags, Thread_Wait_flags desired_flags) |
Tries to change the thread wait flags. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Wait_set_queue (Thread_Control *the_thread, Thread_queue_Control *new_queue) |
Sets the thread queue. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Wait_set_operations (Thread_Control *the_thread, const Thread_queue_Operations *new_operations) |
Sets the thread queue operations. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Wait_restore_default_operations (Thread_Control *the_thread) |
Restores the default thread queue operations. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Wait_set_timeout_code (Thread_Control *the_thread, uint32_t timeout_code) |
Sets the thread wait timeout code. More... | |
void | _Thread_Timeout (Objects_Id id, void *arg) |
General purpose thread wait timeout. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_Debug_set_real_processor (Thread_Control *the_thread, Per_CPU_Control *cpu) |
RTEMS_INLINE_ROUTINE struct _reent ** | _Thread_Get_libc_reent (void) |
This routine returns the C library re-enterant pointer. | |
RTEMS_INLINE_ROUTINE void | _Thread_Set_libc_reent (struct _reent **libc_reent) |
This routine set the C library re-enterant pointer. | |
const Thread_Control_add_on | _Thread_Control_add_ons [] |
Thread control add-ons. More... | |
const size_t | _Thread_Control_add_on_count |
Thread control add-on count. More... | |
const size_t | _Thread_Control_size |
Size of the thread control block of a particular application. More... | |
SCORE_EXTERN void * | rtems_ada_self |
Self for the GNU Ada Run-Time. | |
SCORE_EXTERN Objects_Information | _Thread_Internal_information |
The following defines the information control block used to manage this class of objects. | |
SCORE_EXTERN Thread_Control * | _Thread_Allocated_fp |
The following points to the thread whose floating point context is currently loaded. | |
SCORE_EXTERN struct _reent ** | _Thread_libc_reent |
The C library re-enter-rant global pointer. More... | |
This includes the creation, deletion, and scheduling of threads.
The following variables are maintained as part of the per cpu data structure.
#define _Thread_Lock_restore_default | ( | the_thread | ) | do { } while ( 0 ) |
The caller must be the owner of the current thread lock.
[in] | the_thread | The thread. |
Referenced by _Thread_queue_Extract_locked().
#define _Thread_Lock_set | ( | the_thread, | |
new_lock | |||
The caller must not be the owner of the default thread lock. The caller must be the owner of the new lock.
[in] | new_lock | The new thread lock. |
#define THREAD_API_FIRST THREAD_API_RTEMS |
#define THREAD_API_LAST THREAD_API_POSIX |
#define THREAD_WAIT_STATE_INTEND_TO_BLOCK 0x1U |
A blocking operation consists of an optional watchdog initialization and the setting of the appropriate thread blocking state with the corresponding scheduler block operation.
#define THREAD_WAIT_STATE_READY_AGAIN 0x4U |
This could be a timeout, a signal, an event or a resource availability.
typedef void* Thread |
typedef void( * Thread_Action_handler) (Thread_Control *thread, Thread_Action *action, struct Per_CPU_Control *cpu, ISR_Level level) |
The thread action handler will be called with interrupts disabled and the thread action lock acquired. The handler must release the thread action lock with _Thread_Action_release_and_ISR_enable(). So the thread action lock can be used to protect private data fields of the particular action.
Since the action is passed to the handler private data fields can be added below the common thread action fields.
[in] | thread | The thread performing the action. |
[in] | action | The thread action. |
[in] | cpu | The processor of the thread. |
[in] | level | The ISR level for _Thread_Action_release_and_ISR_enable(). |
typedef bool( * Thread_Change_priority_filter) (Thread_Control *the_thread, Priority_Control *new_priority, void *arg) |
Called by _Thread_Change_priority() under the protection of the thread lock.
[in,out] | new_priority | The new priority of the thread. The filter may alter this value. |
[in] | arg | The argument passed to _Thread_Change_priority(). |
true | Change the current priority. |
false | Otherwise. |
typedef Thread( * Thread_Entry) (void) |
This numeric argument type designates an unsigned integer type with the property that any valid pointer to void can be converted to this type and then converted back to a pointer to void. The result will compare equal to the original pointer.
typedef unsigned int Thread_Wait_flags |
The mutually exclusive wait class flags are
The mutually exclusive wait state flags are
enum Thread_APIs |
Reset Timeslice: At each context switch, reset the time quantum. Exhaust Timeslice: Only reset the quantum once it is consumed. Callout: Execute routine when budget is consumed.
enum Thread_Life_state |
Thread life states.
The thread life states are orthogonal to the thread states used for synchronization primitives and blocking operations. They reflect the state changes triggered with thread restart and delete requests.
enum Thread_Start_types |
Basically, it can be passed any combination/permutation of a pointer and an uint32_t value.
void _Thread_Change_priority | ( | Thread_Control * | the_thread, |
Priority_Control | new_priority, | ||
void * | arg, | ||
Thread_Change_priority_filter | filter, | ||
bool | prepend_it | ||
It changes current priority of the thread to the new priority in case the filter function returns true. In this case the scheduler is notified of the priority change as well.
[in] | new_priority | The new priority of the thread. |
[in] | arg | The argument for the filter function. |
[in] | filter | The filter function to determine if a priority change is allowed and optionally perform other actions under the protection of the thread lock simultaneously with the update of the current priority. |
[in] | prepend_it | In case this is true, then the thread is prepended to its priority group in its scheduler instance, otherwise it is appended. |
Referenced by _POSIX_Threads_Sporadic_budget_callout(), _POSIX_Threads_Sporadic_budget_TSR(), _Thread_Raise_priority(), _Thread_Restore_priority(), and _Thread_Set_priority().
States_Control _Thread_Clear_state | ( | Thread_Control * | the_thread, |
States_Control | state | ||
In case the previous state is a non-ready state and the next state is the ready state, then the thread is unblocked by the scheduler.
[in] | state | The state to clear. It must not be zero. |
Referenced by _Thread_Ready(), and _Thread_Unblock().
void _Thread_Close | ( | Thread_Control * | the_thread, |
Thread_Control * | executing | ||
Closes the thread.
Closes the thread object and starts the thread termination sequence. In case the executing thread is not terminated, then this function waits until the terminating thread reached the zombie state.
References _Assert.
void _Thread_Create_idle | ( | void | ) |
Create idle thread.
This routine creates the idle thread.
void _Thread_Delay_ended | ( | Objects_Id | id, |
void * | ignored | ||
This routine is invoked when a thread must be unblocked at the end of a time based delay (i.e. wake after or wake when). It is called by the watchdog handler.
[in] | id | is the thread id |
[in] | ignored | is not used |
Referenced by _Thread_Ready().
void _Thread_Dispatch | ( | void | ) |
This routine is responsible for transferring control of the processor from the executing thread to the heir thread. Once the heir is running an attempt is made to run the pending post-switch thread actions.
As part of this process, it is responsible for the following actions
On entry the thread dispatch level must be equal to zero.
Referenced by _Watchdog_Tick().
RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_decrement_disable_level | ( | void | ) |
This routine decrements the thread dispatch level.
Referenced by _Thread_Unnest_dispatch().
RTEMS_INLINE_ROUTINE Per_CPU_Control* _Thread_Dispatch_disable | ( | void | ) |
This function does not acquire the Giant lock.
References _ISR_lock_ISR_disable, _ISR_lock_ISR_enable, and _Thread_Dispatch_disable_critical().
Referenced by _CORE_mutex_Initialize(), and rtems_task_wake_after().
RTEMS_INLINE_ROUTINE Per_CPU_Control* _Thread_Dispatch_disable_critical | ( | const ISR_lock_Context * | lock_context | ) |
[in] | lock_context | The lock context of the corresponding _ISR_lock_ISR_disable() that started the critical section. |
Referenced by _Thread_Dispatch_disable().
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable | ( | Per_CPU_Control * | cpu_self | ) |
May perfrom a thread dispatch if necessary as a side-effect.
This function does not release the Giant lock.
[in] | cpu_self | The current processor. |
References Per_CPU_Control::thread_dispatch_disable_level.
Referenced by _CORE_mutex_Initialize().
RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_get_disable_level | ( | void | ) |
RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_increment_disable_level | ( | void | ) |
This rountine increments the thread dispatch level
Referenced by _Thread_Disable_dispatch().
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_initialization | ( | void | ) |
This routine initializes the thread dispatching subsystem.
RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled | ( | void | ) |
true | Thread dispatching is enabled. |
false | The executing thread is inside a thread dispatch critical section and dispatching is not allowed. |
void _Thread_Do_dispatch | ( | Per_CPU_Control * | cpu_self, |
ISR_Level | level | ||
On entry the thread dispatch disable level must be equal to one and interrupts must be disabled.
This function assumes that a thread dispatch is necessary.
[in] | level | The previous interrupt level. |
References _Assert, _Thread_Get_heir_and_make_it_executing(), Thread_Control::budget_algorithm, Per_CPU_Control::executing, rtems_ada_self, and Per_CPU_Control::thread_dispatch_disable_level.
void _Thread_Enable_dispatch | ( | void | ) |
Referenced by _Objects_Put(), _POSIX_Threads_cancel_run(), rtems_rate_monotonic_reset_all_statistics(), and rtems_signal_catch().
Thread_Control* _Thread_Get | ( | Objects_Id | id, |
Objects_Locations * | location | ||
This function maps thread IDs to thread control blocks. If ID corresponds to a local thread, then it returns the_thread control pointer which maps to ID and location is set to OBJECTS_LOCAL. If the thread ID is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_thread is undefined. Otherwise, location is set to OBJECTS_ERROR and the_thread is undefined.
[in] | id | is the id of the thread. |
[in] | location | is the location of the block. |
References _Objects_Are_ids_equal(), _Thread_Disable_dispatch(), and OBJECTS_ID_OF_SELF.
Referenced by _MPCI_Process_response(), pthread_detach(), rtems_signal_send(), rtems_task_get_note(), rtems_task_get_scheduler(), rtems_task_is_suspended(), rtems_task_restart(), rtems_task_resume(), rtems_task_set_note(), rtems_task_set_priority(), rtems_task_start(), rtems_task_suspend(), rtems_task_variable_add(), rtems_task_variable_delete(), and rtems_task_variable_get().
RTEMS_INLINE_ROUTINE Thread_Control* _Thread_Get_heir_and_make_it_executing | ( | Per_CPU_Control * | cpu_self | ) |
The thread dispatch necessary indicator is cleared as a side-effect.
References Per_CPU_Control::dispatch_necessary.
Referenced by _Thread_Do_dispatch().
Thread_Control* _Thread_Get_interrupt_disable | ( | Objects_Id | id, |
Objects_Locations * | location, | ||
ISR_lock_Context * | lock_context | ||
References _Objects_Are_ids_equal(), and OBJECTS_ID_OF_SELF.
Referenced by rtems_event_send(), and rtems_event_system_send().
void* _Thread_Global_construction | ( | void | ) |
The first initialization thread is the first RTEMS initialization task or the first POSIX initialization thread in case no RTEMS initialization tasks are present.
References _Thread_Disable_dispatch(), Configuration_POSIX_API, Configuration_RTEMS_API, rtems_initialization_tasks_table::entry_point, rtems_api_configuration_table::number_of_initialization_tasks, and rtems_api_configuration_table::User_initialization_tasks_table.
void _Thread_Handler | ( | void | ) |
This routine is the wrapper function for all threads. It is the starting point for all threads. The user provided thread entry point is invoked by this routine. Operations which must be performed immediately before and after the user's thread executes are found here.
void _Thread_Handler_initialization | ( | void | ) |
This routine performs the initialization necessary for this handler.
void* _Thread_Idle_body | ( | uintptr_t | ignored | ) |
NOTE: This routine is actually instantiated by confdefs.h when needed.
bool _Thread_Initialize | ( | Objects_Information * | information, |
Thread_Control * | the_thread, | ||
const struct Scheduler_Control * | scheduler, | ||
void * | stack_area, | ||
size_t | stack_size, | ||
bool | is_fp, | ||
Priority_Control | priority, | ||
bool | is_preemptible, | ||
Thread_CPU_budget_algorithms | budget_algorithm, | ||
Thread_CPU_budget_algorithm_callout | budget_callout, | ||
uint32_t | isr_level, | ||
Objects_Name | name | ||
Initialize thread.
This routine initializes the specified the thread. It allocates all memory associated with this thread. It completes by adding the thread to the local object table so operations on this thread id are allowed.
RTEMS_INLINE_ROUTINE bool _Thread_Is_proxy_blocking | ( | uint32_t | code | ) |
Is proxy blocking.
status which indicates that a proxy is blocking, and false otherwise.
References RTEMS_INLINE_ROUTINE, and THREAD_STATUS_PROXY_BLOCKING.
void _Thread_Kill_zombies | ( | void | ) |
Threads change into the zombie state as the last step in the thread termination sequence right before a context switch to the heir thread is initiated. Since the thread stack is still in use during this phase we have to postpone the thread stack reclamation until this point. On SMP configurations we may have to busy wait for context switch completion here.
void _Thread_Load_environment | ( | Thread_Control * | the_thread | ) |
This routine initializes the context of the_thread to its appropriate starting state.
[in] | the_thread | is the pointer to the thread control block. |
References _Context_Initialize_fp, Thread_Start_information::budget_algorithm, Thread_Control::budget_algorithm, Thread_Start_information::budget_callout, Thread_Control::budget_callout, Thread_Start_information::fp_context, Thread_Control::fp_context, Thread_Start_information::is_preemptible, Thread_Control::is_preemptible, and Thread_Control::Start.
Referenced by _Thread_Ready(), and _Thread_Start().
RTEMS_INLINE_ROUTINE ISR_lock_Control* _Thread_Lock_acquire | ( | Thread_Control * | the_thread, |
[in] | lock_context | The lock context for _Thread_Lock_release(). |
RTEMS_INLINE_ROUTINE void _Thread_Lock_acquire_default | ( | Thread_Control * | the_thread, |
[in] | lock_context | The lock context used for the corresponding lock release. |
References _ISR_lock_ISR_disable_and_acquire.
RTEMS_INLINE_ROUTINE void _Thread_Lock_acquire_default_critical | ( | Thread_Control * | the_thread, |
References _Assert, _ISR_Get_level, and _ISR_lock_Acquire.
RTEMS_INLINE_ROUTINE Thread_Control* _Thread_Lock_acquire_default_for_executing | ( | ISR_lock_Context * | lock_context | ) |
References _ISR_lock_ISR_disable.
Referenced by rtems_event_receive(), and rtems_event_system_receive().
RTEMS_INLINE_ROUTINE void _Thread_Lock_release | ( | ISR_lock_Control * | lock, |
[in] | lock | The lock returned by _Thread_Lock_acquire(). |
[in] | lock_context | The lock context used for _Thread_Lock_acquire(). |
RTEMS_INLINE_ROUTINE void _Thread_Lock_release_critical | ( | ISR_lock_Control * | lock, |
The previous interrupt status is not restored.
[in] | lock | The lock. |
[in] | lock_context | The lock context used for the corresponding lock acquire. |
Referenced by _Thread_Lock_release_default_critical().
RTEMS_INLINE_ROUTINE void _Thread_Lock_release_default | ( | Thread_Control * | the_thread, |
References _ISR_lock_ISR_enable, and _Thread_Lock_release_default_critical().
RTEMS_INLINE_ROUTINE void _Thread_Lock_release_default_critical | ( | Thread_Control * | the_thread, |
References _Thread_Lock_release_critical().
Referenced by _Thread_Lock_release_default().
RTEMS_INLINE_ROUTINE bool _Thread_Owns_resources | ( | const Thread_Control * | the_thread | ) |
Resources are accounted with the Thread_Control::resource_count resource counter. This counter is used by semaphore objects for example.
In addition to the resource counter there is a resource dependency tree available on SMP configurations. In case this tree is non-empty, then the thread owns resources.
References Thread_Control::resource_count.
void _Thread_Raise_priority | ( | Thread_Control * | the_thread, |
Priority_Control | new_priority | ||
It changes the current priority of the thread to the new priority if the new priority is higher than the current priority. In this case the thread is appended to its new priority group in its scheduler instance.
References _Thread_Change_priority().
RTEMS_INLINE_ROUTINE void _Thread_Ready | ( | Thread_Control * | the_thread | ) |
In case the previous state is a non-ready state, then the thread is unblocked by the scheduler.
References _Thread_Clear_state(), _Thread_Delay_ended(), _Thread_Global_construction(), _Thread_Handler(), _Thread_Load_environment(), and STATES_ALL_SET.
Referenced by _Thread_Start().
void _Thread_Restore_priority | ( | Thread_Control * | the_thread | ) |
Sets the priority restore hint to false.
void _Thread_Set_priority | ( | Thread_Control * | the_thread, |
Priority_Control * | old_priority, | ||
It sets the real priority of the thread. In addition it changes the current priority of the thread if the new priority is higher than the current priority or the thread owns no resources.
[out] | old_priority | The old real priority of the thread. This pointer must not be NULL . |
Referenced by _Scheduler_EDF_Release_job().
States_Control _Thread_Set_state | ( | Thread_Control * | the_thread, |
In case the previous state is the ready state, then the thread is blocked by the scheduler.
[in] | state | The state to set. It must not be zero. |
size_t _Thread_Stack_Allocate | ( | Thread_Control * | the_thread, |
size_t | stack_size | ||
Allocate the requested stack space for the thread. Set the Start.stack field to the address of the stack.
[in] | the_thread | is the thread where the stack space is requested |
[in] | stack_size | is the stack space is requested |
actual | size allocated after any adjustment |
zero | if the allocation failed |
void _Thread_Stack_Free | ( | Thread_Control * | the_thread | ) |
Deallocate the Thread's stack.
bool _Thread_Start | ( | Thread_Control * | the_thread, |
Thread_Start_types | the_prototype, | ||
void * | entry_point, | ||
void * | pointer_argument, | ||
Thread_Entry_numeric_type | numeric_argument, | ||
Per_CPU_Control * | cpu | ||
This routine initializes the executable information for a thread and makes it ready to execute. After this routine executes, the thread competes with all other threads for CPU time.
the_thread | is the thread to be initialized | |
the_prototype | ||
entry_point | ||
pointer_argument | ||
numeric_argument | ||
[in,out] | cpu | The processor if used to start an idle thread during system initialization. Must be set to NULL to start a normal thread. |
References _States_Is_dormant(), _Thread_Load_environment(), _Thread_Ready(), Thread_Control::current_state, Thread_Start_information::entry_point, Thread_Start_information::numeric_argument, Thread_Start_information::pointer_argument, Thread_Start_information::prototype, and Thread_Control::Start.
void _Thread_Start_multitasking | ( | void | ) |
This routine initiates multitasking. It is invoked only as part of initialization and its invocation is the last act of the non-multitasking part of the system initialization.
void _Thread_Timeout | ( | Objects_Id | id, |
void * | arg | ||
[in] | id | Unused. |
[in] | arg | The thread. |
Referenced by _Thread_Wait_set_timeout_code().
RTEMS_INLINE_ROUTINE void _Thread_Unblock | ( | Thread_Control * | the_thread | ) |
It performs any necessary scheduling operations including the selection of a new heir thread.
References _Thread_Clear_state(), and STATES_BLOCKED.
RTEMS_INLINE_ROUTINE void _Thread_Unnest_dispatch | ( | void | ) |
References _Thread_Dispatch_decrement_disable_level(), and RTEMS_COMPILER_MEMORY_BARRIER.
Referenced by _Objects_Put_without_thread_dispatch(), and _POSIX_Thread_Evaluate_cancellation_and_enable_dispatch().
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change | ( | Thread_Control * | the_thread, |
Thread_Wait_flags | expected_flags, | ||
Thread_Wait_flags | desired_flags | ||
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change_critical | ( | Thread_Control * | the_thread, |
In case the wait flags are equal to the expected wait flags, then the wait flags are set to the desired wait flags.
[in] | expected_flags | The expected wait flags. |
[in] | desired_flags | The desired wait flags. |
true | The wait flags were equal to the expected wait flags. |
RTEMS_INLINE_ROUTINE void _Thread_Wait_restore_default_operations | ( | Thread_Control * | the_thread | ) |
The caller must be the owner of the thread lock.
References Thread_Wait_information::operations, and Thread_Control::Wait.
RTEMS_INLINE_ROUTINE void _Thread_Wait_set_operations | ( | Thread_Control * | the_thread, |
const Thread_queue_Operations * | new_operations | ||
[in] | new_operations | The new queue operations. |
RTEMS_INLINE_ROUTINE void _Thread_Wait_set_queue | ( | Thread_Control * | the_thread, |
Thread_queue_Control * | new_queue | ||
[in] | new_queue | The new queue. |
References Thread_Wait_information::queue, and Thread_Control::Wait.
RTEMS_INLINE_ROUTINE void _Thread_Wait_set_timeout_code | ( | Thread_Control * | the_thread, |
uint32_t | timeout_code | ||
[in] | timeout_code | The new thread wait timeout code. |
References _Thread_Timeout(), RTEMS_INLINE_ROUTINE, Thread_Wait_information::timeout_code, and Thread_Control::Wait.
void rtems_iterate_over_all_threads | ( | rtems_per_thread_routine | routine | ) |
This routine iterates over all threads regardless of API and invokes the specified routine.
References _Objects_Information_table, Objects_Information::local_table, Objects_Information::maximum, and OBJECTS_APIS_LAST.
const size_t _Thread_Control_add_on_count |
Count of entries in _Thread_Control_add_ons.
This value is provided via <rtems/confdefs.h>.
const Thread_Control_add_on _Thread_Control_add_ons[] |
The thread control block contains fields that point to application configuration dependent memory areas, like the scheduler information, the API control blocks, the user extension context table, the RTEMS notepads and the Newlib re-entrancy support. Account for these areas in the configuration and avoid extra workspace allocations for these areas.
This array is provided via <rtems/confdefs.h>.
const size_t _Thread_Control_size |
SCORE_EXTERN struct _reent** _Thread_libc_reent |
Some C library implementations such as newlib have a single global pointer that changed during a context switch. The pointer points to that global pointer. The Thread control block holds a pointer to the task specific data.
Referenced by _Thread_Get_libc_reent().
