Modules | Files | Data Structures | Macros | Typedefs | Functions | Variables
CPU CPU
Provides CPU architecture dependent services. More...
Collaboration diagram for CPU CPU:
 ARM Assembler Support
 ARM Assembler Support.
 Object Handler
file  arm_exc_handler_high.c
 ARM exception support implementation.
file  cpu.c
 ARM architecture support implementation.
file  cpu_asm.h
 ARM Assembler Support API.
file  epiphany-utility.h
 This include file contains macros pertaining to the Epiphany processor family.
file  objectshrinkinformation.c
 Shrink an Object Class Information Record.
struct  Context_Control
 This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More...
struct  Context_Control_fp
 This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More...
struct  CPU_Interrupt_frame
 This defines the set of integer and processor state registers that must be saved during an interrupt. More...
union  Objects_Name
 The following type defines the control block used to manage object names. More...
#define CPU_MODEL_NAME   "ARMv4"
#define ARM_MULTILIB_ARCH_V4
#define CPU_NAME   "ARM"
#define CPU_INLINE_ENABLE_DISPATCH   TRUE
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_HAS_SOFTWARE_INTERRUPT_STACK   FALSE
#define CPU_HAS_HARDWARE_INTERRUPT_STACK   FALSE
#define CPU_ALLOCATE_INTERRUPT_STACK   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   0
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   FALSE
#define CPU_PROVIDES_IDLE_THREAD_BODY   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_STRUCTURE_ALIGNMENT   __attribute__ ((aligned ( 32 )))
#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC   TRUE
#define CPU_MODES_INTERRUPT_MASK   0x1
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   (1024 * 4)
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   8
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_PARTITION_ALIGNMENT   4
#define CPU_STACK_ALIGNMENT   8
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_USE_GENERIC_BITFIELD_DATA   TRUE
#define CPU_PER_CPU_CONTROL_SIZE   0
#define _CPU_ISR_Disable(_isr_cookie)
#define _CPU_ISR_Enable(_isr_cookie)   arm_interrupt_enable( _isr_cookie )
#define _CPU_ISR_Flash(_isr_cookie)   arm_interrupt_flash( _isr_cookie )
#define _CPU_Context_Get_SP(_context)   (_context)->register_sp
#define _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Fp_start(_base, _offset)   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
#define _CPU_Context_Initialize_fp(_destination)
#define _CPU_Fatal_halt(_source, _err)
#define CPU_INLINE_ENABLE_DISPATCH   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   1
#define CPU_ALL_TASKS_ARE_FP   CPU_HARDWARE_FP
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
#define CPU_PROVIDES_IDLE_THREAD_BODY   TRUE
#define CPU_TIMESTAMP_USE_INT64_INLINE   TRUE
#define CPU_MODES_INTERRUPT_MASK   0x000000ff
#define _CPU_Context_Get_SP(_context)   (uintptr_t) (_context)->sp
#define CPU_STACK_MINIMUM_SIZE   (8 * 1024)
#define CPU_PARTITION_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   CPU_ALIGNMENT
#define _CPU_ISR_Disable(_level)
#define _CPU_ISR_Enable(_level)
#define _CPU_ISR_Flash(_xlevel)
#define _CPU_Fatal_halt(_source, _error)
#define _CPU_Bitfield_Find_first_bit(_value, _output)
#define _CPU_Priority_Mask(_bit_number)   ( 1 << (_bit_number) )
#define _CPU_Priority_bits_index(_priority)   (_priority)
#define CPU_swap_u16(value)   (((value&0xff) << 8) | ((value >> 8)&0xff))
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
 Type that can store a 32-bit integer or a pointer. More...
typedef uint16_t Priority_bit_map_Word
typedef void epiphany_isr
typedef void(* epiphany_isr_entry) (void)
typedef CPU_Interrupt_frame CPU_Exception_frame
typedef void or1k_isr
typedef void(* or1k_isr_entry) (void)
void _CPU_ISR_Set_level (uint32_t level)
 Sets the hardware interrupt level by the level value. More...
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
void _CPU_Initialize (void)
 CPU initialization. More...
CPU_Counter_ticks _CPU_Counter_read (void)
CPU_Counter_ticks _CPU_Counter_difference (CPU_Counter_ticks second, CPU_Counter_ticks first)
 Returns the difference between the second and first CPU counter value. More...
void * _CPU_Thread_Idle_body (uintptr_t ignored)
void mips_vector_exceptions (CPU_Interrupt_frame *frame)
uint32_t mips_interrupt_mask (void)
void _CPU_Context_Initialize (Context_Control *the_context, uintptr_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
void mips_break (int error)
void _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs a "raw" interrupt handler directly into the processor's vector table. More...
void _CPU_Install_interrupt_stack (void)
 This routine installs the hardware interrupt stack pointer. More...
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
 This routine saves the floating point context passed to it. More...
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
 This routine restores the floating point context passed to it. More...
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
uint32_t arm_cpu_mode
SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context
◆ _CPU_Bitfield_Find_first_bit
#define _CPU_Bitfield_Find_first_bit (   _value,
  _output
Value:
(_output) = 0; /* do something to prevent warnings */ \
◆ _CPU_Context_Initialize_fp [1/2]
#define _CPU_Context_Initialize_fp (   _destination)
Value:
do { \
*(*(_destination)) = _CPU_Null_fp_context; \
} while (0)
This variable is optional.
Definition: cpu.h:494
◆ _CPU_Context_Initialize_fp [2/2]
Value:
◆ _CPU_Fatal_halt [1/2]
#define _CPU_Fatal_halt (   _source,
  _err
Value:
do { \
uint32_t _level; \
uint32_t _error = _err; \
_CPU_ISR_Disable( _level ); \
(void) _level; \
__asm__ volatile ("mov r0, %0\n" \
: "=r" (_error) \
: "0" (_error) \
: "r0" ); \
while (1); \
} while (0);
◆ _CPU_Fatal_halt [2/2]
  _error
Value:
do { \
unsigned int _level; \
_CPU_ISR_Disable(_level); \
(void)_level; \
loop: goto loop; \
} while (0)
◆ _CPU_ISR_Disable [1/2]
#define _CPU_ISR_Disable (   _isr_cookie)
Value:
do { \
_isr_cookie = arm_interrupt_disable(); \
} while (0)
◆ _CPU_ISR_Disable [2/2]
#define _CPU_ISR_Disable (   _level)
Value:
do { \
unsigned int _scratch; \
mips_get_sr( _scratch ); \
mips_set_sr( _scratch & ~SR_INTERRUPT_ENABLE_BITS ); \
_level = _scratch & SR_INTERRUPT_ENABLE_BITS; \
} while(0)
◆ _CPU_ISR_Enable
#define _CPU_ISR_Enable (   _level)
Value:
do { \
mips_set_sr( (_scratch & ~SR_INTERRUPT_ENABLE_BITS) | (_level & SR_INTERRUPT_ENABLE_BITS) ); \
} while(0)
◆ _CPU_ISR_Flash
#define _CPU_ISR_Flash (   _xlevel)
Value:
do { \
unsigned int _scratch2 = _xlevel; \
_CPU_ISR_Enable( _scratch2 ); \
_CPU_ISR_Disable( _scratch2 ); \
_xlevel = _scratch2; \
} while(0)
Typedef Documentation
◆ CPU_Uint32ptr [1/3]
◆ CPU_Uint32ptr [2/3]
◆ CPU_Uint32ptr [3/3]
◆ _CPU_Context_restore_fp()
void _CPU_Context_restore_fp ( Context_Control_fp **  fp_context_ptr)
Parameters
[in]fp_context_ptris a pointer to a pointer to a floating point context area to restore
Returns
on output *fp_context_ptr will contain the address that should be used with _CPU_Context_save_fp to save this context.
Port Specific Information:
XXX document implementation including references if appropriate
◆ _CPU_Context_save_fp()
void _CPU_Context_save_fp ( Context_Control_fp **  fp_context_ptr)
Parameters
Returns
on output *fp_context_ptr will contain the address that should be used with _CPU_Context_restore_fp to restore this context.
◆ _CPU_Counter_difference()
static CPU_Counter_ticks _CPU_Counter_difference ( CPU_Counter_ticks  second,
inline
This operation may be carried out as a modulo operation depending on the range of the CPU counter device.
Parameters
[in]secondThe second CPU counter value.
[in]firstThe first CPU counter value.
Returns
Returns second minus first modulo counter period.
◆ _CPU_Exception_frame_print()
void _CPU_Exception_frame_print ( const CPU_Exception_frame frame)
This method prints the CPU exception frame.
See also
rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
◆ _CPU_Initialize()
void _CPU_Initialize ( void  )
CPU initialization.
CPU initialization.
◆ _CPU_Install_interrupt_stack()
void _CPU_Install_interrupt_stack ( void  )
NOTE: It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK is TRUE.
◆ _CPU_ISR_install_raw_handler()
void _CPU_ISR_install_raw_handler ( uint32_t  vector,
proc_ptr old_handler
Parameters
[in]vectoris the vector number
[in]new_handleris the raw ISR handler to install
[in]old_handleris the previously installed ISR Handler
◆ _CPU_ISR_Set_level()
void _CPU_ISR_Set_level ( uint32_t  level)
Parameters
[in]levelfor or1k can only range over two values: 0 (enable interrupts) and 1 (disable interrupts). In future implementations if fast context switch is implemented, the level can range from 0 to 15.
See also
OpenRISC architecture manual.
