From the highest level viewpoint, there are 2 types of context to save. More...
struct | Context_Control |
This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More... | |
struct | Context_Control_fp |
This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More... | |
struct | CPU_Interrupt_frame |
This defines the set of integer and processor state registers that must be saved during an interrupt. More... | |
#define | _CPU_Context_Get_SP(_context) (_context)->register_sp |
#define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
The size of the floating point context area. More... | |
#define | CPU_STACK_MINIMUM_SIZE (1024*8) |
Should be large enough to run all RTEMS tests. More... | |
#define | _CPU_Context_Fp_start(_base, _offset) ( (void *) _Addresses_Add_offset( (_base), (_offset) ) ) |
The purpose of this macro is to allow the initial pointer into a floating point context area (used to save the floating point context) to be at an arbitrary place in the floating point context area. More... | |
#define | _CPU_Context_Get_SP(_context) (_context)->sp |
This macro returns the stack pointer associated with _context. More... | |
#define | CPU_STACK_MINIMUM_SIZE (1024*4) |
#define | _CPU_Context_Fp_start(_base, _offset) |
#define | CPU_STACK_MINIMUM_SIZE (2048L) |
#define | _CPU_Context_Get_SP(_context) (_context)->r15_sp |
#define | CPU_STACK_MINIMUM_SIZE (1024) |
#define | _CPU_Context_Get_SP(_context) (_context)->stack_pointer |
#define | _CPU_Context_Initialize(_the_context, _stack_base, _size, _isr, _entry_point, _is_fp, _tls_area) |
Initialize the context to a state suitable for starting a task after a context restore operation. More... | |
#define | _CPU_Context_Get_SP(_context) (_context)->r3_stack_pointer |
#define | CPU_CONTEXT_FP_SIZE 0 |
void | _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
This routine switches from the run context to the heir context. More... | |
void | _CPU_Context_restore (Context_Control *new_context) |
This routine is generally used only to restart self in an efficient manner. More... | |
void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
This routine saves the floating point context passed to it. More... | |
void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
This routine restores the floating point context passed to it. More... | |
void | _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, size_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
SCORE_EXTERN Context_Control_fp | _CPU_Null_fp_context |
This variable is optional. More... | |
char | _gp [] |
Since RTEMS handles integer and floating point contexts separately, this means we have the following 3 context items:
On some processors, it is cost-effective to save only the callee preserved registers during a task context switch. This means that the ISR code needs to save those registers which do not persist across function calls. It is not mandatory to make this distinctions between the caller/callee saves registers for the purpose of minimizing context saved during task switch and on interrupts. If the cost of saving extra registers is minimal, simplicity is the choice. Save the same context on interrupt entry as for tasks in this case.
Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then care should be used in designing the context area.
On some CPUs with hardware floating point support, the Context_Control_fp structure will not be used or it simply consist of an array of a fixed number of bytes. This is done when the floating point context is dumped by a "FP save context" type instruction and the format is not really defined by the CPU. In this case, there is no need to figure out the exact format – only the size. Of course, although this is enough information for RTEMS, it is probably not enough for a debugger such as gdb. But that is another problem.
Port Specific Information:
XXX document implementation including references if appropriate
On the v850, this port saves special registers and those that are callee saved.
#define _CPU_Context_Fp_start | ( | _base, | |
_offset | |||
) | ( (void *) _Addresses_Add_offset( (_base), (_offset) ) ) |
This is necessary because some FP units are designed to have their context saved as a stack which grows into lower addresses. Other FP units can be saved by simply moving registers into offsets from the base of the context area. Finally some FP units provide a "dump context" instruction which could fill in from high to low or low to high based on the whim of the CPU designers.
[in] | _base | is the lowest physical address of the floating point context area |
[in] | _offset | is the offset into the floating point area |
_offset | |||
_offset | |||
_offset | |||
_offset | |||
#define _CPU_Context_Get_SP | ( | _context | ) | (_context)->r3_stack_pointer |
[in] | _context | is the thread context area to access |
#define _CPU_Context_Get_SP | ( | _context | ) | (_context)->sp |
#define _CPU_Context_Get_SP | ( | _context | ) | (_context)->r15_sp |
#define _CPU_Context_Get_SP | ( | _context | ) | (_context)->stack_pointer |
#define _CPU_Context_Initialize | ( | _the_context, | |
_stack_base, | |||
_size, | |||
_isr, | |||
_entry_point, | |||
_is_fp, | |||
_tls_area | |||
Generally, this involves:
This routine generally does not set any unnecessary register in the context. The state of the "general data" registers is undefined at task start time.
[in] | _the_context | is the context structure to be initialized |
[in] | _stack_base | is the lowest physical address of this task's stack |
[in] | _size | is the size of this task's stack |
[in] | _isr | is the interrupt disable level |
[in] | _entry_point | is the thread's entry point. This is always _Thread_Handler |
[in] | _is_fp | is TRUE if the thread is to be a floating point thread. This is typically only used on CPUs where the FPU may be easily disabled by software such as on the SPARC where the PSR contains an enable FPU bit. |
[in] | _tls_area | The thread-local storage (TLS) area. |
#define CPU_CONTEXT_FP_SIZE 0 |
On some CPUs this will not be a "sizeof" because the format of the floating point area is not defined – only the size is. This is usually on CPUs with a "floating point save context" instruction.
The v850 does not need a floating point context but this needs to be defined so confdefs.h.
#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
#define CPU_STACK_MINIMUM_SIZE (1024*4) |
This ensures that a "reasonable" small application should not have any problems.
This should be very conservative on the v850.
#define CPU_STACK_MINIMUM_SIZE (2048L) |
#define CPU_STACK_MINIMUM_SIZE (1024*8) |
#define CPU_STACK_MINIMUM_SIZE (1024) |
void _CPU_Context_Initialize | ( | Context_Control * | the_context, |
uint32_t * | stack_base, | ||
size_t | size, | ||
uint32_t | new_level, | ||
void * | entry_point, | ||
bool | is_fp, | ||
void * | tls_area | ||
Initialize CPU context.
[in] | tls_area | is the thread-local storage (TLS) area |
Initialize the context to a state suitable for starting a task after a context restore operation. Generally, this involves:
uint32_t | size, | ||
bool | is_fp, | ||
See implementation in cpu.c
This method is implemented in C on the v850.
void _CPU_Context_restore | ( | Context_Control * | new_context | ) |
It may simply be a label in _CPU_Context_switch.
[in] | new_context | points to the context to be restored. |
NOTE: May be unnecessary to reload some registers.
This is implemented in assembly on the v850.
void _CPU_Context_restore_fp | ( | Context_Control_fp ** | fp_context_ptr | ) |
[in] | fp_context_ptr | is a pointer to a pointer to a floating point context area to restore |
void _CPU_Context_save_fp | ( | Context_Control_fp ** | fp_context_ptr | ) |
[in] | fp_context_ptr | is a pointer to a pointer to a floating point context area |
void _CPU_Context_switch | ( | Context_Control * | run, |
Context_Control * | heir | ||
[in] | run | points to the context of the currently executing task |
[in] | heir | points to the context of the heir task |
SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context |
It is used on CPUs on which it is difficult to generate an "uninitialized" FP context. It is filled in by _CPU_Initialize and copied into the task's FP context area during _CPU_Context_Initialize.
char _gp[] |
