This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More...
#include <cpu.h>
void * register_sp
uint16_t stack_pointer
uint8_t status
uint32_t register_r4
uint32_t register_r5
uint32_t register_r6
uint32_t register_r7
uint32_t register_p3
uint32_t register_p4
uint32_t register_p5
uint32_t register_fp
uint32_t register_sp
uint32_t register_rets
uint32_t imask
uint32_t r [64]
uint32_t status
uint32_t config
uint32_t iret
uint16_t ccr nogap
void *er7 nogap
void *er6 nogap
uint32_t er5 nogap
uint32_t er4 nogap
uint32_t er3 nogap
uint32_t er2 nogap
uint32_t er1 nogap
uint32_t er0 nogap
uint32_t xxx nogap
uint32_t eflags
void * esp
void * ebp
uint32_t ebx
uint32_t esi
uint32_t edi
uint32_t r11
 r11 – temporary register
uint32_t r12
 r12 – may be global pointer
uint32_t r13
uint32_t r14
uint32_t r15
uint32_t r16
uint32_t r17
uint32_t r18
uint32_t r19
uint32_t r20
uint32_t r21
uint32_t r22
uint32_t r23
uint32_t r24
uint32_t r25
uint32_t gp
uint32_t fp
uint32_t sp
 This will contain the stack pointer. More...
uint32_t ra
uint32_t ie
uint32_t epc
uint32_t fb
 This will contain the frame base pointer. More...
uint32_t r8
 r8 – temporary register
uint32_t r9
 r9 – temporary register
uint32_t r10
 r10 – temporary register
uint32_t r13_fp
 r13 – frame pointer
uint32_t r14_lr
 r14 – link register (aka return pointer
uint32_t r15_sp
 r15 – stack pointer
uint32_t acc_low
 dsp accumulator low order 32-bits
uint32_t acc_high
 dsp accumulator high order 32-bits
uint32_t sr
uint32_t d2
uint32_t d3
uint32_t d4
uint32_t d5
uint32_t d6
uint32_t d7
void * a2
void * a3
void * a4
void * a5
void * a6
void * a7_msp
__MIPS_REGISTER_TYPE s0
__MIPS_REGISTER_TYPE s1
__MIPS_REGISTER_TYPE s2
__MIPS_REGISTER_TYPE s3
__MIPS_REGISTER_TYPE s4
__MIPS_REGISTER_TYPE s5
__MIPS_REGISTER_TYPE s6
__MIPS_REGISTER_TYPE s7
__MIPS_REGISTER_TYPE sp
__MIPS_REGISTER_TYPE fp
__MIPS_REGISTER_TYPE ra
__MIPS_REGISTER_TYPE c0_sr
__MIPS_REGISTER_TYPE c0_epc
void *fp nogap
void *sp nogap
uint32_t r0 nogap
uint32_t r1 nogap
uint32_t r2 nogap
uint32_t r3 nogap
uint32_t r4 nogap
uint32_t r5 nogap
uint32_t r6 nogap
uint32_t r7 nogap
uint32_t r8 nogap
uint32_t r9 nogap
uint32_t r10 nogap
uint32_t r11 nogap
uint32_t r12 nogap
uint32_t r13 nogap
uint32_t thread_dispatch_disabled
uint32_t stack_mpubase
uint32_t stack_mpuacc
uint32_t some_integer_register
 This field is a hint that a port will have a number of integer registers that need to be saved at a context switch.
uint32_t some_system_register
 This field is a hint that a port will have a number of system registers that need to be saved at a context switch.
uint32_t stack_pointer
 This field is a hint that a port will have a register that is the stack pointer.
uint32_t r1
uint32_t r2
uint32_t r3
uint32_t r4
uint32_t r5
uint32_t r6
uint32_t r7
uint32_t r26
uint32_t r27
uint32_t r28
uint32_t r29
uint32_t r30
uint32_t r31
uint32_t epcr
uint32_t eear
uint32_t esr
uint8_t context [PPC_DEFAULT_CACHE_LINE_SIZE+sizeof(ppc_context)+(sizeof(ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE==0 ? 0 :PPC_DEFAULT_CACHE_LINE_SIZE - sizeof(ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE)]
uint32_t * r15
uint32_t macl
uint32_t mach
uint32_t * pr
uint32_t * r14
uint32_t * r7
uint32_t * r6
uint32_t * r3
uint32_t * r2
uint32_t * r1
uint32_t * r0
uint32_t gbr
uint32_t g5
 This will contain the contents of the g5 register. More...
uint32_t g7
 This will contain the contents of the g7 register. More...
double l0_and_l1
 This will contain the contents of the l0 and l1 registers. More...
uint32_t l2
 This will contain the contents of the l2 register. More...
uint32_t l3
 This will contain the contents of the l3 register. More...
uint32_t l4
 This will contain the contents of the l4 register. More...
uint32_t l5
 This will contain the contents of the l5 registeer. More...
uint32_t l6
 This will contain the contents of the l6 register. More...
uint32_t l7
 This will contain the contents of the l7 register. More...
uint32_t i0
 This will contain the contents of the i0 register. More...
uint32_t i1
 This will contain the contents of the i1 register. More...
uint32_t i2
 This will contain the contents of the i2 register. More...
uint32_t i3
 This will contain the contents of the i3 register. More...
uint32_t i4
 This will contain the contents of the i4 register. More...
uint32_t i5
 This will contain the contents of the i5 register. More...
uint32_t i6_fp
 This will contain the contents of the i6 (e.g. More...
uint32_t i7
 This will contain the contents of the i7 register. More...
uint32_t o6_sp
 This will contain the contents of the o6 (e.g. More...
uint32_t o7
 This will contain the contents of the o7 (e.g. More...
uint32_t psr
 This will contain the contents of the processor status register. More...
uint32_t isr_dispatch_disable
 This field is used to prevent heavy nesting of calls to _Thread_Dispatch on an interrupted task's stack. More...
uint64_t g1
uint64_t g2
uint64_t g3
uint64_t g4
uint64_t g5
uint64_t g6
uint64_t g7
uint64_t l0
uint64_t l1
uint64_t l2
uint64_t l3
uint64_t l4
uint64_t l5
uint64_t l6
uint64_t l7
uint64_t i0
uint64_t i1
uint64_t i2
uint64_t i3
uint64_t i4
uint64_t i5
uint64_t i6_fp
uint64_t i7
uint64_t o0
uint64_t o1
uint64_t o2
uint64_t o3
uint64_t o4
uint64_t o5
uint64_t o6_sp
uint64_t o7
uint32_t pad
uint32_t r3_stack_pointer
 This field is the stack pointer (e.g. More...
uint32_t psw
SPARC basic context.
Thread register context.
The thread register context covers the non-volatile registers, the thread stack pointer, the return address, and the processor status.
There is no need to save the global pointer (gp) since it is a system wide constant and set-up with the C runtime environment.
The thread_dispatch_disabled field is used for the external interrupt controller (EIC) support.
See also
_Nios2_Thread_dispatch_disabled
This structure defines the non-volatile integer and processor state context for the SPARC architecture according to "SYSTEM V APPLICATION BINARY INTERFACE - SPARC Processor Supplement", Third Edition.
The registers g2 through g4 are reserved for applications. GCC uses them as volatile registers by default. So they are treated like volatile registers in RTEMS as well.
The register g6 contains the per-CPU control of the current processor. It is an invariant of the processor context. This register must not be saved and restored during context switches or interrupt services.
Field Documentation
◆ fb
uint32_t Context_Control::fb
◆ g5
uint32_t Context_Control::g5
◆ g7
uint32_t Context_Control::g7
◆ i0
uint32_t Context_Control::i0
◆ i1
uint32_t Context_Control::i1
◆ i2
uint32_t Context_Control::i2
◆ i3
uint32_t Context_Control::i3
◆ i4
uint32_t Context_Control::i4
◆ i5
uint32_t Context_Control::i5
◆ i6_fp
uint32_t Context_Control::i6_fp
frame pointer) register.
◆ i7
uint32_t Context_Control::i7
◆ isr_dispatch_disable
uint32_t Context_Control::isr_dispatch_disable
This is problematic on the slower SPARC CPU models at high interrupt rates.
◆ l0_and_l1
double Context_Control::l0_and_l1
Using a double l0_and_l1 will put everything in this structure on a double word boundary which allows us to use double word loads and stores safely in the context switch.
◆ l2
uint32_t Context_Control::l2
◆ l3
uint32_t Context_Control::l3
◆ l4
uint32_t Context_Control::l4
◆ l5
uint32_t Context_Control::l5
◆ l6
uint32_t Context_Control::l6
◆ l7
uint32_t Context_Control::l7
◆ o6_sp
uint32_t Context_Control::o6_sp
◆ o7
uint32_t Context_Control::o7
address of CALL instruction) register.
◆ psr
uint32_t Context_Control::psr
◆ r3_stack_pointer
uint32_t Context_Control::r3_stack_pointer
r3).
◆ sp
uint32_t Context_Control::sp
