29 #ifndef _RTEMS_SCORE_CPU_H 30 #define _RTEMS_SCORE_CPU_H 32 #include <rtems/score/types.h> 35 #if defined(ARM_MULTILIB_ARCH_V4) 46 #if defined(__thumb__) && !defined(__thumb2__) 47 #define ARM_SWITCH_REGISTERS uint32_t arm_switch_reg 48 #define ARM_SWITCH_TO_ARM ".align 2\nbx pc\n.arm\n" 49 #define ARM_SWITCH_BACK "add %[arm_switch_reg], pc, #1\nbx %[arm_switch_reg]\n.thumb\n" 50 #define ARM_SWITCH_OUTPUT [arm_switch_reg] "=&r" (arm_switch_reg) 51 #define ARM_SWITCH_ADDITIONAL_OUTPUT , ARM_SWITCH_OUTPUT 53 #define ARM_SWITCH_REGISTERS 54 #define ARM_SWITCH_TO_ARM 55 #define ARM_SWITCH_BACK 56 #define ARM_SWITCH_OUTPUT 57 #define ARM_SWITCH_ADDITIONAL_OUTPUT 65 #define ARM_PSR_N (1 << 31) 66 #define ARM_PSR_Z (1 << 30) 67 #define ARM_PSR_C (1 << 29) 68 #define ARM_PSR_V (1 << 28) 69 #define ARM_PSR_Q (1 << 27) 70 #define ARM_PSR_J (1 << 24) 71 #define ARM_PSR_GE_SHIFT 16 72 #define ARM_PSR_GE_MASK (0xf << ARM_PSR_GE_SHIFT) 73 #define ARM_PSR_E (1 << 9) 74 #define ARM_PSR_A (1 << 8) 75 #define ARM_PSR_I (1 << 7) 76 #define ARM_PSR_F (1 << 6) 77 #define ARM_PSR_T (1 << 5) 78 #define ARM_PSR_M_SHIFT 0 79 #define ARM_PSR_M_MASK (0x1f << ARM_PSR_M_SHIFT) 80 #define ARM_PSR_M_USR 0x10 81 #define ARM_PSR_M_FIQ 0x11 82 #define ARM_PSR_M_IRQ 0x12 83 #define ARM_PSR_M_SVC 0x13 84 #define ARM_PSR_M_ABT 0x17 85 #define ARM_PSR_M_HYP 0x1a 86 #define ARM_PSR_M_UND 0x1b 87 #define ARM_PSR_M_SYS 0x1f 102 #define CPU_INLINE_ENABLE_DISPATCH FALSE 104 #define CPU_INLINE_ENABLE_DISPATCH TRUE 107 #if defined(__ARMEL__) 108 #define CPU_BIG_ENDIAN FALSE 109 #define CPU_LITTLE_ENDIAN TRUE 110 #elif defined(__ARMEB__) 111 #define CPU_BIG_ENDIAN TRUE 112 #define CPU_LITTLE_ENDIAN FALSE 114 #error "unknown endianness" 120 #define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE 122 #define CPU_HAS_SOFTWARE_INTERRUPT_STACK FALSE 124 #define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE 126 #define CPU_ALLOCATE_INTERRUPT_STACK FALSE 128 #define CPU_ISR_PASSES_FRAME_POINTER 0 130 #define CPU_HARDWARE_FP FALSE 132 #define CPU_SOFTWARE_FP FALSE 134 #define CPU_ALL_TASKS_ARE_FP FALSE 136 #define CPU_IDLE_TASK_IS_FP FALSE 138 #define CPU_USE_DEFERRED_FP_SWITCH FALSE 140 #if defined(ARM_MULTILIB_HAS_WFI) 141 #define CPU_PROVIDES_IDLE_THREAD_BODY TRUE 143 #define CPU_PROVIDES_IDLE_THREAD_BODY FALSE 146 #define CPU_STACK_GROWS_UP FALSE 148 #if defined(ARM_MULTILIB_CACHE_LINE_MAX_64) 149 #define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned ( 64 ))) 151 #define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned ( 32 ))) 154 #define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE 170 #define CPU_MODES_INTERRUPT_MASK 0x1 172 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) 174 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 176 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE 178 #define CPU_STACK_MINIMUM_SIZE (1024 * 4) 181 #define CPU_SIZEOF_POINTER 4 184 #define CPU_ALIGNMENT 8 186 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT 189 #define CPU_PARTITION_ALIGNMENT 4 192 #define CPU_STACK_ALIGNMENT 8 205 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE 207 #define CPU_USE_GENERIC_BITFIELD_DATA TRUE 209 #define CPU_PER_CPU_CONTROL_SIZE 0 213 #ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER 214 #define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44 217 #ifdef ARM_MULTILIB_VFP 218 #define ARM_CONTEXT_CONTROL_D8_OFFSET 48 222 #ifdef ARM_MULTILIB_VFP 223 #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112 225 #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48 229 #define ARM_EXCEPTION_FRAME_SIZE 80 231 #define ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET 52 233 #define ARM_EXCEPTION_FRAME_VFP_CONTEXT_OFFSET 72 235 #define ARM_VFP_CONTEXT_SIZE 264 249 #if defined(ARM_MULTILIB_ARCH_V4) 250 uint32_t register_cpsr;
251 uint32_t register_r4;
252 uint32_t register_r5;
253 uint32_t register_r6;
254 uint32_t register_r7;
255 uint32_t register_r8;
256 uint32_t register_r9;
257 uint32_t register_r10;
258 uint32_t register_fp;
259 uint32_t register_sp;
260 uint32_t register_lr;
261 #elif defined(ARM_MULTILIB_ARCH_V6M) || defined(ARM_MULTILIB_ARCH_V7M) 262 uint32_t register_r4;
263 uint32_t register_r5;
264 uint32_t register_r6;
265 uint32_t register_r7;
266 uint32_t register_r8;
267 uint32_t register_r9;
268 uint32_t register_r10;
269 uint32_t register_r11;
272 uint32_t isr_nest_level;
276 #ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER 279 #ifdef ARM_MULTILIB_VFP 280 uint64_t register_d8;
281 uint64_t register_d9;
282 uint64_t register_d10;
283 uint64_t register_d11;
284 uint64_t register_d12;
285 uint64_t register_d13;
286 uint64_t register_d14;
287 uint64_t register_d15;
290 volatile bool is_executing;
298 extern uint32_t arm_cpu_mode;
300 static inline void _ARM_Data_memory_barrier(
void )
302 #ifdef ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS 303 __asm__ volatile (
"dmb" : : :
"memory" );
309 static inline void _ARM_Data_synchronization_barrier(
void )
311 #ifdef ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS 312 __asm__ volatile (
"dsb" : : :
"memory" );
318 static inline void _ARM_Instruction_synchronization_barrier(
void )
320 #ifdef ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS 321 __asm__ volatile (
"isb" : : :
"memory" );
327 static inline uint32_t arm_interrupt_disable(
void )
331 #if defined(ARM_MULTILIB_ARCH_V4) 332 uint32_t arm_switch_reg;
336 "mrs %[level], cpsr\n" 337 "orr %[arm_switch_reg], %[level], #0x80\n" 338 "msr cpsr, %[arm_switch_reg]\n" 340 : [arm_switch_reg]
"=&r" (arm_switch_reg), [level]
"=&r" (level)
342 #elif defined(ARM_MULTILIB_ARCH_V7M) 343 uint32_t basepri = 0x80;
346 "mrs %[level], basepri\n" 347 "msr basepri_max, %[basepri]\n" 348 : [level]
"=&r" (level)
349 : [basepri]
"r" (basepri)
358 static inline void arm_interrupt_enable( uint32_t level )
360 #if defined(ARM_MULTILIB_ARCH_V4) 361 ARM_SWITCH_REGISTERS;
365 "msr cpsr, %[level]\n" 368 : [level]
"r" (level)
370 #elif defined(ARM_MULTILIB_ARCH_V7M) 372 "msr basepri, %[level]\n" 374 : [level]
"r" (level)
379 static inline void arm_interrupt_flash( uint32_t level )
381 #if defined(ARM_MULTILIB_ARCH_V4) 382 uint32_t arm_switch_reg;
386 "mrs %[arm_switch_reg], cpsr\n" 387 "msr cpsr, %[level]\n" 388 "msr cpsr, %[arm_switch_reg]\n" 390 : [arm_switch_reg]
391 : [level]
"r" (level)
393 #elif defined(ARM_MULTILIB_ARCH_V7M) 397 "mrs %[basepri], basepri\n" 398 "msr basepri, %[level]\n" 399 "msr basepri, %[basepri]\n" 400 : [basepri]
"=&r" (basepri)
401 : [level]
"r" (level)
406 #define _CPU_ISR_Disable( _isr_cookie ) \ 408 _isr_cookie = arm_interrupt_disable(); \ 411 #define _CPU_ISR_Enable( _isr_cookie ) \ 412 arm_interrupt_enable( _isr_cookie ) 414 #define _CPU_ISR_Flash( _isr_cookie ) \ 415 arm_interrupt_flash( _isr_cookie ) 423 void *stack_area_begin,
424 size_t stack_area_size,
426 void (*entry_point)(
void ),
431 #define _CPU_Context_Get_SP( _context ) \ 432 (_context)->register_sp 435 static inline bool _CPU_Context_Get_is_executing(
439 return context->is_executing;
442 static inline void _CPU_Context_Set_is_executing(
447 context->is_executing = is_executing;
451 #define _CPU_Context_Restart_self( _the_context ) \ 452 _CPU_Context_restore( (_the_context) ); 454 #define _CPU_Context_Fp_start( _base, _offset ) \ 455 ( (void *) _Addresses_Add_offset( (_base), (_offset) ) ) 457 #define _CPU_Context_Initialize_fp( _destination ) \ 459 *(*(_destination)) = _CPU_Null_fp_context; \ 462 #define _CPU_Fatal_halt( _source, _err ) \ 465 uint32_t _error = _err; \ 466 _CPU_ISR_Disable( _level ); \ 468 __asm__ volatile ("mov r0, %0\n" \ 494 #if defined(ARM_MULTILIB_ARCH_V7M) 497 #define _CPU_Start_multitasking _ARMV7M_Start_multitasking 505 uint32_t _CPU_SMP_Initialize(
void );
507 bool _CPU_SMP_Start_processor( uint32_t cpu_index );
509 void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
511 void _CPU_SMP_Prepare_start_multitasking(
void );
513 static inline uint32_t _CPU_SMP_Get_current_processor(
void )
519 "mrc p15, 0, %[mpidr], c0, c0, 5\n" 520 : [mpidr]
"=&r" (mpidr)
523 return mpidr & 0xffU;
526 void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
528 static inline void _ARM_Send_event(
void )
530 __asm__ volatile (
"sev" : : :
"memory" );
533 static inline void _ARM_Wait_for_event(
void )
535 __asm__ volatile (
"wfe" : : :
"memory" );
538 static inline void _CPU_SMP_Processor_event_broadcast(
void )
540 _ARM_Data_synchronization_barrier();
544 static inline void _CPU_SMP_Processor_event_receive(
void )
546 _ARM_Wait_for_event();
547 _ARM_Data_memory_barrier();
552 static inline uint32_t CPU_swap_u32( uint32_t value )
554 #if defined(__thumb2__) 561 #elif defined(__thumb__) 562 uint32_t byte1, byte2, byte3, byte4, swapped;
564 byte4 = (value >> 24) & 0xff;
565 byte3 = (value >> 16) & 0xff;
566 byte2 = (value >> 8) & 0xff;
567 byte1 = value & 0xff;
569 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
572 uint32_t tmp = value;
573 __asm__ volatile (
"EOR %1, %0, %0, ROR #16\n" 574 "BIC %1, %1, #0xff0000\n" 575 "MOV %0, %0, ROR #8\n" 576 "EOR %0, %0, %1, LSR #8\n" 577 :
"=r" (value),
"=r" (tmp)
578 :
"0" (value),
"1" (tmp));
585 #if defined(__thumb2__) 593 return (uint16_t) (((value & 0xffU) << 8) | ((value >> 8) & 0xffU));
602 CPU_Counter_ticks second,
603 CPU_Counter_ticks first
606 #if CPU_PROVIDES_IDLE_THREAD_BODY == TRUE 617 #if defined(ARM_MULTILIB_ARCH_V4) 620 ARM_EXCEPTION_RESET = 0,
621 ARM_EXCEPTION_UNDEF = 1,
622 ARM_EXCEPTION_SWI = 2,
623 ARM_EXCEPTION_PREF_ABORT = 3,
624 ARM_EXCEPTION_DATA_ABORT = 4,
625 ARM_EXCEPTION_RESERVED = 5,
626 ARM_EXCEPTION_IRQ = 6,
627 ARM_EXCEPTION_FIQ = 7,
629 ARM_EXCEPTION_MAKE_ENUM_32_BIT = 0xffffffff
630 } Arm_symbolic_exception_name;
635 uint32_t register_fpexc;
636 uint32_t register_fpscr;
637 uint64_t register_d0;
638 uint64_t register_d1;
639 uint64_t register_d2;
640 uint64_t register_d3;
641 uint64_t register_d4;
642 uint64_t register_d5;
643 uint64_t register_d6;
644 uint64_t register_d7;
645 uint64_t register_d8;
646 uint64_t register_d9;
647 uint64_t register_d10;
648 uint64_t register_d11;
649 uint64_t register_d12;
650 uint64_t register_d13;
651 uint64_t register_d14;
652 uint64_t register_d15;
653 uint64_t register_d16;
654 uint64_t register_d17;
655 uint64_t register_d18;
656 uint64_t register_d19;
657 uint64_t register_d20;
658 uint64_t register_d21;
659 uint64_t register_d22;
660 uint64_t register_d23;
661 uint64_t register_d24;
662 uint64_t register_d25;
663 uint64_t register_d26;
664 uint64_t register_d27;
665 uint64_t register_d28;
666 uint64_t register_d29;
667 uint64_t register_d30;
668 uint64_t register_d31;
672 uint32_t register_r0;
673 uint32_t register_r1;
674 uint32_t register_r2;
675 uint32_t register_r3;
676 uint32_t register_r4;
677 uint32_t register_r5;
678 uint32_t register_r6;
679 uint32_t register_r7;
680 uint32_t register_r8;
681 uint32_t register_r9;
682 uint32_t register_r10;
683 uint32_t register_r11;
684 uint32_t register_r12;
685 uint32_t register_sp;
688 #if defined(ARM_MULTILIB_ARCH_V4) 689 uint32_t register_cpsr;
690 Arm_symbolic_exception_name vector;
691 #elif defined(ARM_MULTILIB_ARCH_V6M) || defined(ARM_MULTILIB_ARCH_V7M) 692 uint32_t register_xpsr;
696 uint32_t reserved_for_stack_alignment;
709 void rtems_exception_init_mngt(
void );
void _CPU_ISR_install_vector(uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
This routine installs an interrupt vector.
Definition: cpu.c:69
void _CPU_Context_validate(uintptr_t pattern)
Initializes and validates the CPU context with values derived from the pattern parameter.
Definition: cpu.h:1109
uint32_t _CPU_ISR_Get_level(void)
Return the current interrupt disable level for this task in the format used by the interrupt level po...
Definition: cpu.c:39
void _CPU_Context_restore(Context_Control *new_context)
This routine is generally used only to restart self in an efficient manner.
Definition: cpu_asm.c:112
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:92
void _CPU_Context_volatile_clobber(uintptr_t pattern)
Clobbers all volatile registers with values derived from the pattern parameter.
Definition: cpu.h:1104
This defines the minimal set of integer and processor state registers that must be saved during a vol...
Definition: cpu.h:248
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:26
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: cpu.h:1461
This defines the set of integer and processor state registers that must be saved during an interrupt...
Definition: cpu.h:425
void _CPU_ISR_Set_level(uint32_t level)
Sets the hardware interrupt level by the level value.
Definition: cpu.c:62
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
void _CPU_Context_Initialize(Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
Initialize the context to a state suitable for starting a task after a context restore operation...
Definition: cpu.c:183
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: cpu.c:96
CPU_Counter_ticks _CPU_Counter_difference(CPU_Counter_ticks second, CPU_Counter_ticks first)
Returns the difference between the second and first CPU counter value.
Definition: cpu.h:1160
This defines the complete set of floating point registers that must be saved during any context switc...
Definition: cpu.h:294
#define CPU_swap_u16(value)
This routine swaps a 16 bir quantity.
Definition: cpu.h:1253
#define RTEMS_COMPILER_NO_RETURN_ATTRIBUTE
The following macro is a compiler specific way to indicate that the method will NOT return to the cal...
Definition: basedefs.h:162
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: arm-exception-frame-print.c:46
void * _CPU_Thread_Idle_body(uintptr_t ignored)
This routine is the CPU dependent IDLE thread body.
Definition: cpu.c:125
The set of registers that specifies the complete processor state.
Definition: cpu.h:671
void * proc_ptr
XXX: Eventually proc_ptr needs to disappear!!!
Definition: basedefs.h:329
ARM Assembler Support API.
#define RTEMS_COMPILER_MEMORY_BARRIER()
The following macro is a compiler specific way to ensure that memory writes are not reordered around ...
Definition: basedefs.h:146
