Processor Dependent Endianness Support
This group assists in issues related to processor endianness. More...
#define CPU_BIG_ENDIAN   FALSE
 Define what is required to specify how the network to host conversion routines are handled. More...
#define CPU_LITTLE_ENDIAN   TRUE
#define CPU_swap_u16(value)   (((value&0xff) << 8) | ((value >> 8)&0xff))
 This routine swaps a 16 bir quantity. More...
#define CPU_BIG_ENDIAN   TRUE
#define CPU_LITTLE_ENDIAN   FALSE
◆ CPU_BIG_ENDIAN [1/6]
NOTE: CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN should NOT have the same values.
See also
CPU_LITTLE_ENDIAN
Port Specific Information:
XXX document implementation including references if appropriate
◆ CPU_BIG_ENDIAN [2/6]
Note
See also
CPU_LITTLE_ENDIAN
The v850 is little endian.
◆ CPU_BIG_ENDIAN [3/6]
Note
See also
CPU_LITTLE_ENDIAN
◆ CPU_BIG_ENDIAN [4/6]
See also
CPU_LITTLE_ENDIAN
◆ CPU_BIG_ENDIAN [5/6]
See also
CPU_LITTLE_ENDIAN
◆ CPU_BIG_ENDIAN [6/6]
See also
CPU_LITTLE_ENDIAN
◆ CPU_LITTLE_ENDIAN [1/6]
See also
CPU_BIG_ENDIAN
◆ CPU_LITTLE_ENDIAN [2/6]
Note
See also
CPU_BIG_ENDIAN
◆ CPU_LITTLE_ENDIAN [3/6]
Note
See also
CPU_BIG_ENDIAN
◆ CPU_LITTLE_ENDIAN [4/6]
See also
CPU_BIG_ENDIAN
◆ CPU_LITTLE_ENDIAN [5/6]
See also
CPU_BIG_ENDIAN
◆ CPU_LITTLE_ENDIAN [6/6]
See also
CPU_BIG_ENDIAN
◆ CPU_swap_u16 [1/4]
#define CPU_swap_u16 (   value)    (((value&0xff) << 8) | ((value >> 8)&0xff))
Parameters
[in]valueis the value to be swapped
Returns
the value after being endian swapped
◆ CPU_swap_u16 [2/4]
Parameters
Returns
◆ CPU_swap_u16 [3/4]
Parameters
Returns
◆ CPU_swap_u16 [4/4]
Parameters
Returns
