#define | TRUE 1 |
This ensures that RTEMS has TRUE defined in all situations. | |
#define | SCORE_EXTERN extern |
The following ensures that all data is declared in the space of the initialization routine for either the Initialization Manager or the initialization file for the appropriate API. More... | |
#define | SAPI_EXTERN extern |
#define | RTEMS_EXTERN extern |
#define | POSIX_EXTERN extern |
#define | RTEMS_INLINE_ROUTINE static inline |
The following (in conjunction with compiler arguments) are used to choose between the use of static inline functions and macro functions. More... | |
#define | RTEMS_COMPILER_MEMORY_BARRIER() |
The following macro is a compiler specific way to ensure that memory writes are not reordered around certian points. More... | |
#define | RTEMS_COMPILER_NO_RETURN_ATTRIBUTE |
The following macro is a compiler specific way to indicate that the method will NOT return to the caller. More... | |
#define | RTEMS_COMPILER_PURE_ATTRIBUTE |
The following defines a compiler specific attribute which informs the compiler that the method has no effect except the return value and that the return value depends only on parameters and/or global variables. | |
#define | RTEMS_COMPILER_DEPRECATED_ATTRIBUTE |
Instructs the compiler to issue a warning whenever a variable or function with this attribute will be used. | |
#define | RTEMS_COMPILER_UNUSED_ATTRIBUTE |
Instructs the compiler that a specific variable is deliberately unused. More... | |
#define | RTEMS_COMPILER_PACKED_ATTRIBUTE |
Instructs the compiler that a specific structure or union members will be placed so that the least memory is used. | |
#define | RTEMS_STATIC_ASSERT(cond, msg) typedef int rtems_static_assert_ ## msg [(cond) ? 1 : -1] |
#define | RTEMS_ARRAY_SIZE(array) (sizeof(array) / sizeof((array)[0])) |
#define | RTEMS_ZERO_LENGTH_ARRAY 0 |
#define | RTEMS_CONTAINER_OF(_m, _type, _member_name) ( (_type *) ( (uintptr_t) ( _m ) - offsetof( _type, _member_name ) ) ) |
Returns a pointer to the container of a specified member pointer. More... | |
#define | RTEMS_TYPEOF_REFX(_ptr_level, _ptr_type) typeof(_ptr_level(union { int z; typeof(_ptr_type) x; }){0}.x) |
#define | RTEMS_DECONST(_type, _var) ((_type)(uintptr_t)(const void *) ( _var )) |
Removes the const qualifier from a type of a variable. More... | |
#define | RTEMS_DEVOLATILE(_type, _var) ((_type)(uintptr_t)(volatile void *) ( _var )) |
Removes the volatile qualifier from a type of a variable. More... | |
#define | RTEMS_DEQUALIFY(_type, _var) ((_type)(uintptr_t)(const volatile void *) ( _var )) |
Removes the all qualifiers from a type of a variable. More... | |
Typedefs | |
typedef void * | proc_ptr |
XXX: Eventually proc_ptr needs to disappear!!! | |
#define POSIX_EXTERN extern |
It is referenced as "external" in every other file.
#define RTEMS_COMPILER_MEMORY_BARRIER | ( | ) |
This specifically can impact interrupt disable and thread dispatching critical sections.
Referenced by _Thread_Disable_dispatch(), and _Thread_Unnest_dispatch().
#define RTEMS_COMPILER_NO_RETURN_ATTRIBUTE |
This can assist the compiler in code generation and avoid unreachable paths. This can impact the code generated following calls to rtems_fatal_error_occurred and _Terminate.
#define RTEMS_COMPILER_UNUSED_ATTRIBUTE |
This can occur when reading volatile device memory or skipping arguments in a variable argument method.
#define RTEMS_CONTAINER_OF | ( | _m, | |
_type, | |||
_member_name | |||
) | ( (_type *) ( (uintptr_t) ( _m ) - offsetof( _type, _member_name ) ) ) |
[in] | _m | The pointer to a member of the container. |
[in] | _type | The type of the container. |
[in] | _member_name | The designator name of the container member. |
#define RTEMS_DECONST | ( | _type, | |
_var | |||
) | ((_type)(uintptr_t)(const void *) ( _var )) |
[in] | _type | The target type for the variable. |
[in] | _var | The variable. |
#define RTEMS_DEQUALIFY | ( | _type, | |
_var | |||
) | ((_type)(uintptr_t)(const volatile void *) ( _var )) |
#define RTEMS_DEVOLATILE | ( | _type, | |
_var | |||
) | ((_type)(uintptr_t)(volatile void *) ( _var )) |
#define RTEMS_EXTERN extern |
#define RTEMS_INLINE_ROUTINE static inline |
The static inline implementation allows better type checking with no cost in code size or execution speed.
Referenced by _ASR_Initialize(), _ASR_Post_signals(), _Attributes_Is_floating_point(), _CORE_message_queue_Is_priority(), _CORE_message_queue_Set_message_priority(), _Heap_Block_at(), _Heap_Get_size(), _Heap_Protection_set_delayed_free_fraction(), _Message_queue_Get(), _POSIX_Message_queue_Get(), _POSIX_Message_queue_Namespace_remove(), _POSIX_Semaphore_Get(), _POSIX_Threads_Initialize_attributes(), _Priority_bit_map_Add(), _Priority_Bits_index(), _Scheduler_Is_priority_higher_than(), _Scheduler_Start_idle(), _Thread_Disable_dispatch(), _Thread_Is_allocated_fp(), _Thread_Is_proxy_blocking(), _Thread_Wait_set_timeout_code(), _Watchdog_Insert_seconds(), and _Watchdog_Last().
#define SAPI_EXTERN extern |
#define SCORE_EXTERN extern |
