This handler encapsulates functionality related to managing sets of threads that are ready for execution. More...
Modules | |
| CBS Scheduler | |
| EDF Scheduler | |
| Deterministic Priority Scheduler | |
| Simple Priority Scheduler | |
| SMP Scheduler | |
| The scheduler nodes can be in four states. | |
Files | |
| file | scheduler.c |
| Scheduler Initialize. | |
| file | schedulercbs.c |
| CBS Scheduler Budget Handler. | |
| file | schedulercbsattachthread.c |
| Attach Scheduler CBS Thread. | |
| file | schedulercbscleanup.c |
| Scheduler CBS Cleanup. | |
| file | schedulercbscreateserver.c |
| Scheduler CBS Create Server. | |
| file | schedulercbsdestroyserver.c |
| Scheduler CBS Destroy Server. | |
| file | schedulercbsdetachthread.c |
| Detach from the CBS Server. | |
| file | schedulercbsgetapprovedbudget.c |
| Scheduler CBS Get Approved Budget. | |
| file | schedulercbsgetexecutiontime.c |
| Get Thread Execution Info. | |
| file | schedulercbsgetparameters.c |
| _Scheduler_CBS_Get_parameters | |
| file | schedulercbsgetremainingbudget.c |
| Scheduler CBS Get Remaining Budget. | |
| file | schedulercbsgetserverid.c |
| Scheduler CBS Get Server id. | |
| file | schedulercbsreleasejob.c |
| Scheduler CBS Release Job. | |
| file | schedulercbssetparameters.c |
| Set Parameters for CBS Scheduling. | |
| file | schedulercbsunblock.c |
| Unblocks a Thread from the Queue. | |
| file | schedulerdefaultgetaffinity.c |
| Scheduler Default Get Affinity Operation. | |
| file | schedulerdefaultnodedestroy.c |
| Scheduler Default Node Destruction Operation. | |
| file | schedulerdefaultnodeinit.c |
| Scheduler Default Node Initialization Operation. | |
| file | schedulerdefaultreleasejob.c |
| Default Scheduler Release Job Operation. | |
| file | schedulerdefaultsetaffinity.c |
| Scheduler Default Set Affinity Operation. | |
| file | schedulerdefaulttick.c |
| Default Scheduler At Tick Handler. | |
| file | schedulerdefaultupdate.c |
| Scheduler Default Update Operation. | |
| file | scheduleredf.c |
| Scheduler EDF Initialize and Support. | |
| file | scheduleredfblock.c |
| Removes the Thread from Ready Queue. | |
| file | scheduleredfchangepriority.c |
| Scheduler EDF Extract. | |
| file | scheduleredfnodeinit.c |
| Scheduler EDF Allocate. | |
| file | scheduleredfprioritycompare.c |
| Compares Priorities of Threads. | |
| file | scheduleredfreleasejob.c |
| Scheduler EDF Release Job. | |
| file | scheduleredfschedule.c |
| file | scheduleredfunblock.c |
| Scheduler EDF Unblock. | |
| file | scheduleredfupdate.c |
| Scheduler EDF Update. | |
| file | scheduleredfyield.c |
| Scheduler EDF Yield. | |
| file | schedulerpriorityblock.c |
| Scheduler Priority Block. | |
| file | schedulerprioritychangepriority.c |
| Removes Thread from Thread Queue. | |
| file | schedulerpriorityprioritycompare.c |
| Scheduler Priority Compare Two Priorities. | |
| file | schedulerpriorityschedule.c |
| Priority Scheduler Schedule Method. | |
| file | schedulerpriorityunblock.c |
| Scheduler Priority Unblock. | |
| file | schedulerpriorityupdate.c |
| Update Scheduler Priority. | |
| file | schedulerpriorityyield.c |
| Scheduler Priority Yield. | |
| file | schedulersimple.c |
| Scheduler Simple Functions. | |
| file | schedulersimpleblock.c |
| Simple Scheduler Block a Thread. | |
| file | schedulersimplechangepriority.c |
| Removes a Thread from the Simple Queue. | |
| file | schedulersimpleschedule.c |
| Simple Schedule Determine Heir. | |
| file | schedulersimpleunblock.c |
| Scheduler Simple Handler / Unblock. | |
| file | schedulersimpleyield.c |
| Simple Schedule Yield CPU. | |
| file | schedulersmpdebug.c |
| Scheduler SMP Debug Implementation. | |
| struct | Scheduler_Operations |
| The scheduler operations. More... | |
| struct | Scheduler_Context |
| Scheduler context. More... | |
| struct | Scheduler_Control |
| Scheduler control. More... | |
| struct | Scheduler_Node |
| Scheduler node for per-thread data. More... | |
| #define | SCHEDULER_RETURN_VOID_OR_NULL return |
| #define | _Scheduler_Count ( (size_t) 1 ) |
| Count of registered schedulers. More... | |
| #define | SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP |
| #define | SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY |
Typedefs | |
| typedef struct Scheduler_Control | Scheduler_Control |
| typedef struct Scheduler_Node | Scheduler_Node |
| typedef void | Scheduler_Void_or_thread |
| typedef struct Scheduler_Context | Scheduler_Context |
| void | _Scheduler_default_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Does nothing. More... | |
| void | _Scheduler_default_Node_initialize (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| void | _Scheduler_default_Node_destroy (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| void | _Scheduler_default_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Control new_priority) |
| void | _Scheduler_default_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, uint32_t deadline) |
| void | _Scheduler_default_Tick (const Scheduler_Control *scheduler, Thread_Control *executing) |
| Performs tick operations depending on the CPU budget algorithm for each executing thread. More... | |
| void | _Scheduler_default_Start_idle (const Scheduler_Control *scheduler, Thread_Control *the_thread, struct Per_CPU_Control *cpu) |
| Starts an idle thread. More... | |
| void | _Scheduler_Handler_initialization (void) |
| Initializes the scheduler to the policy chosen by the user. More... | |
| RTEMS_INLINE_ROUTINE Scheduler_Context * | _Scheduler_Get_context (const Scheduler_Control *scheduler) |
| RTEMS_INLINE_ROUTINE const Scheduler_Control * | _Scheduler_Get (const Thread_Control *the_thread) |
| RTEMS_INLINE_ROUTINE const Scheduler_Control * | _Scheduler_Get_own (const Thread_Control *the_thread) |
| RTEMS_INLINE_ROUTINE const Scheduler_Control * | _Scheduler_Get_by_CPU_index (uint32_t cpu_index) |
| RTEMS_INLINE_ROUTINE const Scheduler_Control * | _Scheduler_Get_by_CPU (const Per_CPU_Control *cpu) |
| RTEMS_INLINE_ROUTINE Scheduler_Node * | _Scheduler_Thread_get_own_node (const Thread_Control *the_thread) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Schedule (Thread_Control *the_thread) |
| The preferred method to add a new scheduler is to define the jump table entries and add a case to the _Scheduler_Initialize routine. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Yield (Thread_Control *the_thread) |
| Scheduler yield with a particular thread. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Block (Thread_Control *the_thread) |
| Blocks a thread with respect to the scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Unblock (Thread_Control *the_thread) |
| Unblocks a thread with respect to the scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Change_priority (Thread_Control *the_thread, Priority_Control new_priority, bool prepend_it) |
| Propagates a priority change of a thread to the scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Node_initialize (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Initializes a scheduler node. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Node_destroy (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Destroys a scheduler node. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Update_priority (Thread_Control *the_thread, Priority_Control new_priority) |
| Updates the scheduler about a priority change of a not ready thread. More... | |
| RTEMS_INLINE_ROUTINE int | _Scheduler_Priority_compare (const Scheduler_Control *scheduler, Priority_Control p1, Priority_Control p2) |
| Compares two priority values. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Release_job (Thread_Control *the_thread, uint32_t length) |
| Releases a job of a thread with respect to the scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Tick (void) |
| Scheduler method invoked at each clock tick. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Start_idle (const Scheduler_Control *scheduler, Thread_Control *the_thread, Per_CPU_Control *cpu) |
| Starts the idle thread for a particular processor. More... | |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_Has_processor_ownership (const Scheduler_Control *scheduler, uint32_t cpu_index) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Set (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Update_heir (Thread_Control *new_heir, bool force_dispatch) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Generic_block (const Scheduler_Control *scheduler, Thread_Control *the_thread, void(*extract)(const Scheduler_Control *, Thread_Control *), void(*schedule)(const Scheduler_Control *, Thread_Control *, bool)) |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_Is_priority_lower_than (const Scheduler_Control *scheduler, Priority_Control p1, Priority_Control p2) |
| Returns true if p1 encodes a lower priority than p2 in the intuitive sense of priority. | |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_Is_priority_higher_than (const Scheduler_Control *scheduler, Priority_Control p1, Priority_Control p2) |
| Returns true if p1 encodes a higher priority than p2 in the intuitive sense of priority. | |
| RTEMS_INLINE_ROUTINE uint32_t | _Scheduler_Get_processor_count (const Scheduler_Control *scheduler) |
| RTEMS_INLINE_ROUTINE Objects_Id | _Scheduler_Build_id (uint32_t scheduler_index) |
| RTEMS_INLINE_ROUTINE uint32_t | _Scheduler_Get_index_by_id (Objects_Id id) |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_Get_by_id (Objects_Id id, const Scheduler_Control **scheduler_p) |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_Is_id_valid (Objects_Id id) |
| RTEMS_INLINE_ROUTINE uint32_t | _Scheduler_Get_index (const Scheduler_Control *scheduler) |
| RTEMS_INLINE_ROUTINE Scheduler_Node * | _Scheduler_Thread_get_node (const Thread_Control *the_thread) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Node_do_initialize (Scheduler_Node *node, Thread_Control *the_thread) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Acquire (Thread_Control *the_thread, ISR_lock_Context *lock_context) |
| Acquires the scheduler instance of the thread. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Release (Thread_Control *the_thread, ISR_lock_Context *lock_context) |
| Releases the scheduler instance of the thread. More... | |
| const Scheduler_Control | _Scheduler_Table [] |
| Registered schedulers. More... | |
| #define _Scheduler_Count ( (size_t) 1 ) |
Application provided via <rtems/confdefs.h> on SMP configurations.
It is very important that this is a compile-time constant on uni-processor configurations (in this case RTEMS_SMP is not defined) so that the compiler can optimize the some loops away
Referenced by _Scheduler_Handler_initialization(), and rtems_scheduler_ident().
| typedef struct Scheduler_Context Scheduler_Context |
Scheduler context.
The scheduler context of a particular scheduler implementation must place this structure at the begin of its context structure.
| RTEMS_INLINE_ROUTINE void _Scheduler_Acquire | ( | Thread_Control * | the_thread, |
| ISR_lock_Context * | lock_context | ||
| [in] | the_thread | The thread. |
| [in] | lock_context | The lock context for _Scheduler_Release(). |
References _ISR_lock_ISR_disable_and_acquire.
| RTEMS_INLINE_ROUTINE void _Scheduler_Block | ( | Thread_Control * | the_thread | ) |
This routine removes the_thread from the scheduling decision for the scheduler. The primary task is to remove the thread from the ready queue. It performs any necessary schedulering operations including the selection of a new heir thread.
| RTEMS_INLINE_ROUTINE void _Scheduler_Change_priority | ( | Thread_Control * | the_thread, |
| Priority_Control | new_priority, | ||
| bool | prepend_it | ||
The caller must ensure that the thread is in the ready state. The caller must ensure that the priority value actually changed and is not equal to the current priority value.
The operation must update the heir and thread dispatch necessary variables in case the set of scheduled threads changes.
| [in] | the_thread | The thread changing its priority. |
| [in] | new_priority | The new thread priority. |
| [in] | prepend_it | In case this is true, then enqueue the thread as the first of its priority group, otherwise enqueue the thread as the last of its priority group. |
| void _Scheduler_default_Node_destroy | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread | ||
Does nothing.
| [in] | scheduler | Unused. |
| [in] | the_thread | Unused. |
| void _Scheduler_default_Node_initialize | ( | const Scheduler_Control * | scheduler, |
Does nothing.
| void _Scheduler_default_Release_job | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread, | ||
| uint32_t | deadline | ||
Does nothing.
| [in] | deadline | Unused. |
| void _Scheduler_default_Schedule | ( | const Scheduler_Control * | scheduler, |
Does nothing.
| void _Scheduler_default_Start_idle | ( | const Scheduler_Control * | scheduler, |
| struct Per_CPU_Control * | cpu | ||
| [in] | scheduler | The scheduler. |
| [in] | the_thread | An idle thread. |
| [in] | cpu | This parameter is unused. |
References _Scheduler_Unblock().
| void _Scheduler_default_Tick | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | executing | ||
This routine is invoked as part of processing each clock tick.
| [in] | executing | An executing thread. |
References _States_Is_ready(), Thread_Control::budget_algorithm, Thread_Control::current_state, and Thread_Control::is_preemptible.
| void _Scheduler_default_Update_priority | ( | const Scheduler_Control * | scheduler, |
| Priority_Control | new_priority | ||
Does nothing.
| [in] | new_priority | Unused. |
| void _Scheduler_Handler_initialization | ( | void | ) |
This routine initializes the scheduler to the policy chosen by the user through confdefs, or to the priority scheduler with ready chains by default.
References _Scheduler_Count, _Scheduler_Table, Scheduler_Operations::initialize, and Scheduler_Control::Operations.
| RTEMS_INLINE_ROUTINE void _Scheduler_Node_destroy | ( | const Scheduler_Control * | scheduler, |
The caller must ensure that _Scheduler_Node_destroy() will be called only after a corresponding _Scheduler_Node_initialize().
| [in] | scheduler | The scheduler instance. |
| [in] | the_thread | The thread containing the scheduler node. |
References Scheduler_Operations::node_destroy, and Scheduler_Control::Operations.
| RTEMS_INLINE_ROUTINE void _Scheduler_Node_initialize | ( | const Scheduler_Control * | scheduler, |
The scheduler node contains arbitrary data on function entry. The caller must ensure that _Scheduler_Node_destroy() will be called after a _Scheduler_Node_initialize() before the memory of the scheduler node is destroyed.
References Scheduler_Operations::node_initialize, and Scheduler_Control::Operations.
| RTEMS_INLINE_ROUTINE int _Scheduler_Priority_compare | ( | const Scheduler_Control * | scheduler, |
| Priority_Control | p1, | ||
| Priority_Control | p2 | ||
| [in] | p1 | The first priority value. |
| [in] | p2 | The second priority value. |
| negative | The value p1 encodes a lower priority than p2 in the intuitive sense of priority. |
| 0 | The priorities p1 and p2 are equal. |
| positive | The value p1 encodes a higher priority than p2 in the intuitive sense of priority. |
References Scheduler_Control::Operations, and Scheduler_Operations::priority_compare.
Referenced by _Scheduler_Is_priority_higher_than(), and _Scheduler_Is_priority_lower_than().
| RTEMS_INLINE_ROUTINE void _Scheduler_Release | ( | Thread_Control * | the_thread, |
| [in] | lock_context | The lock context used for _Scheduler_Acquire(). |
References _ISR_lock_Release_and_ISR_enable.
| RTEMS_INLINE_ROUTINE void _Scheduler_Release_job | ( | Thread_Control * | the_thread, |
| uint32_t | length | ||
| [in] | length | The period length. |
| RTEMS_INLINE_ROUTINE void _Scheduler_Schedule | ( | Thread_Control * | the_thread | ) |
Generic scheduling implementations that rely on the ready queue only can be found in the _Scheduler_queue_XXX functions. General scheduling decision.
This kernel routine implements the scheduling decision logic for the scheduler. It does NOT dispatch.
| [in] | the_thread | The thread which state changed previously. |
| RTEMS_INLINE_ROUTINE void _Scheduler_Start_idle | ( | const Scheduler_Control * | scheduler, |
| [in,out] | the_thread | The idle thread for the processor. |
| [in,out] | cpu | The processor for the idle thread. |
References Scheduler_Control::Operations, RTEMS_INLINE_ROUTINE, and Scheduler_Operations::start_idle.
| RTEMS_INLINE_ROUTINE void _Scheduler_Tick | ( | void | ) |
This method is invoked at each clock tick to allow the scheduler implementation to perform any activities required. For the scheduler which support standard RTEMS features, this includes time-slicing management.
Referenced by _Watchdog_Tick().
| RTEMS_INLINE_ROUTINE void _Scheduler_Unblock | ( | Thread_Control * | the_thread | ) |
This routine adds the_thread to the scheduling decision for the scheduler. The primary task is to add the thread to the ready queue per the schedulering policy and update any appropriate scheduling variables, for example the heir thread.
Referenced by _Scheduler_default_Start_idle().
| RTEMS_INLINE_ROUTINE void _Scheduler_Update_priority | ( | Thread_Control * | the_thread, |
| [in] | new_priority | The new priority of the thread. |
| RTEMS_INLINE_ROUTINE void _Scheduler_Yield | ( | Thread_Control * | the_thread | ) |
This routine is invoked when a thread wishes to voluntarily transfer control of the processor to another thread.
| [in] | the_thread | The yielding thread. |
| const Scheduler_Control _Scheduler_Table[] |
Application provided via <rtems/confdefs.h>.
