Low-level lock to protect critical sections accessed by threads and interrupt service routines. More...
Files | |
file | isrlock.h |
ISR Locks. | |
struct | ISR_lock_Control |
ISR lock control. More... | |
struct | ISR_lock_Context |
Local ISR lock context for acquire and release pairs. More... | |
#define | ISR_LOCK_MEMBER(_designator) |
Defines an ISR lock member. More... | |
#define | ISR_LOCK_DECLARE(_qualifier, _designator) |
Declares an ISR lock variable. More... | |
#define | ISR_LOCK_DEFINE(_qualifier, _designator, _name) |
Defines an ISR lock variable. More... | |
#define | ISR_LOCK_REFERENCE(_designator, _target) |
Defines an ISR lock variable reference. More... | |
#define | ISR_LOCK_INITIALIZER(_name) { } |
Initializer for static initialization of ISR locks. More... | |
#define | _ISR_lock_Initialize(_lock, _name) |
Initializes an ISR lock. More... | |
#define | _ISR_lock_Destroy(_lock) |
Destroys an ISR lock. More... | |
#define | _ISR_lock_ISR_disable_and_acquire(_lock, _context) _ISR_Disable( ( _context )->isr_level ) |
Acquires an ISR lock. More... | |
#define | _ISR_lock_Release_and_ISR_enable(_lock, _context) _ISR_Enable( ( _context )->isr_level ) |
Releases an ISR lock. More... | |
#define | _ISR_lock_Acquire(_lock, _context) |
Acquires an ISR lock inside an ISR disabled section. More... | |
#define | _ISR_lock_Release(_lock, _context) |
Releases an ISR lock inside an ISR disabled section. More... | |
#define | _ISR_lock_Flash(_lock, _context) _ISR_Flash( ( _context )->isr_level ) |
Flashes an ISR lock. More... | |
#define | _ISR_lock_ISR_disable_profile(_context) |
#define | _ISR_lock_ISR_disable(_context) |
Disables interrupts and saves the previous interrupt state in the ISR lock context. More... | |
#define | _ISR_lock_ISR_enable(_context) _ISR_Enable( ( _context )->isr_level ) |
Restores the saved interrupt state of the ISR lock context. More... | |
On single processor configurations the ISR locks degrade to simple ISR disable/enable sequences. No additional storage or objects are required.
This synchronization primitive is supported on SMP configurations. Here SMP locks are used.
#define _ISR_lock_Acquire | ( | _lock, | |
_context | |||
The interrupt status will remain unchanged. On SMP configurations this function acquires an SMP lock.
In case the executing context can be interrupted by higher priority interrupts and these interrupts enter the critical section protected by this lock, then the result is unpredictable.
[in] | _lock | The ISR lock control. |
[in] | _context | The local ISR lock context for an acquire and release pair. |
Referenced by _Thread_Lock_acquire_default_critical().
#define _ISR_lock_Destroy | ( | _lock | ) |
Concurrent destruction leads to unpredictable results.
#define _ISR_lock_Flash | ( | _lock, | |
_context | |||
) | _ISR_Flash( ( _context )->isr_level ) |
On uni-processor configurations this a simple _ISR_Flash(). On SMP configurations this function releases an SMP lock, restores the interrupt status, then disables interrupts and acquires the SMP lock again.
This function can be used in thread and interrupt context.
#define _ISR_lock_Initialize | ( | _lock, | |
_name | |||
Concurrent initialization leads to unpredictable results.
[in] | _name | The name for the ISR lock. This name must be a string persistent throughout the life time of this lock. The name is only used if profiling is enabled. |
Referenced by _Thread_queue_Initialize().
#define _ISR_lock_ISR_disable | ( | _context | ) |
[in] | _context | The local ISR lock context to store the interrupt state. |
Referenced by _API_Mutex_Unlock(), _MPCI_Announce(), _MPCI_Receive_server(), _Thread_Dispatch_disable(), and _Thread_Lock_acquire_default_for_executing().
#define _ISR_lock_ISR_disable_and_acquire | ( | _lock, | |
_context | |||
) | _ISR_Disable( ( _context )->isr_level ) |
Interrupts will be disabled. On SMP configurations this function acquires an SMP lock.
Referenced by _ASR_Post_signals(), _ASR_Swap_signals(), _Scheduler_Acquire(), and _Thread_Lock_acquire_default().
#define _ISR_lock_ISR_enable | ( | _context | ) | _ISR_Enable( ( _context )->isr_level ) |
[in] | _context | The local ISR lock context containing the saved interrupt state. |
Referenced by _CORE_mutex_Surrender(), _Thread_Dispatch_disable(), and _Thread_Lock_release_default().
#define _ISR_lock_Release | ( | _lock, | |
_context | |||
The interrupt status will remain unchanged. On SMP configurations this function releases an SMP lock.
#define _ISR_lock_Release_and_ISR_enable | ( | _lock, | |
_context | |||
The interrupt status will be restored. On SMP configurations this function releases an SMP lock.
Referenced by _ASR_Post_signals(), _ASR_Swap_signals(), and _Scheduler_Release().
#define ISR_LOCK_DECLARE | ( | _qualifier, | |
_designator | |||
Do not add a ';' after this macro.
_qualifier | The qualifier for the interrupt lock, e.g. extern. |
_designator | The designator for the interrupt lock. |
#define ISR_LOCK_DEFINE | ( | _qualifier, | |
_designator, | |||
_name | |||
_qualifier | The qualifier for the interrupt lock, e.g. static. |
_name | The name for the interrupt lock. It must be a string. The name is only used if profiling is enabled. |
#define ISR_LOCK_INITIALIZER | ( | _name | ) | { } |
#define ISR_LOCK_MEMBER | ( | _designator | ) |
#define ISR_LOCK_REFERENCE | ( | _designator, | |
_target | |||
_designator | The designator for the interrupt lock reference. |
_target | The target for the interrupt lock reference. |
