Data Structures | Macros
isrlock.h File Reference
ISR Locks. More...
#include <rtems/score/isrlevel.h>
#include <rtems/score/smplock.h>
Include dependency graph for isrlock.h:
struct  ISR_lock_Control
 ISR lock control. More...
struct  ISR_lock_Context
 Local ISR lock context for acquire and release pairs. More...
#define ISR_LOCK_MEMBER(_designator)
 Defines an ISR lock member. More...
#define ISR_LOCK_DECLARE(_qualifier, _designator)
 Declares an ISR lock variable. More...
#define ISR_LOCK_DEFINE(_qualifier, _designator, _name)
 Defines an ISR lock variable. More...
#define ISR_LOCK_REFERENCE(_designator, _target)
 Defines an ISR lock variable reference. More...
#define ISR_LOCK_INITIALIZER(_name)   { }
 Initializer for static initialization of ISR locks. More...
#define _ISR_lock_Initialize(_lock, _name)
 Initializes an ISR lock. More...
#define _ISR_lock_Destroy(_lock)
 Destroys an ISR lock. More...
#define _ISR_lock_ISR_disable_and_acquire(_lock, _context)   _ISR_Disable( ( _context )->isr_level )
 Acquires an ISR lock. More...
#define _ISR_lock_Release_and_ISR_enable(_lock, _context)   _ISR_Enable( ( _context )->isr_level )
 Releases an ISR lock. More...
#define _ISR_lock_Acquire(_lock, _context)
 Acquires an ISR lock inside an ISR disabled section. More...
#define _ISR_lock_Release(_lock, _context)
 Releases an ISR lock inside an ISR disabled section. More...
#define _ISR_lock_Flash(_lock, _context)   _ISR_Flash( ( _context )->isr_level )
 Flashes an ISR lock. More...
#define _ISR_lock_ISR_disable_profile(_context)
#define _ISR_lock_ISR_disable(_context)
 Disables interrupts and saves the previous interrupt state in the ISR lock context. More...
#define _ISR_lock_ISR_enable(_context)   _ISR_Enable( ( _context )->isr_level )
 Restores the saved interrupt state of the ISR lock context. More...
ISR Locks.
