Files | Data Structures | Macros | Enumerations | Functions
Collaboration diagram for EDF Scheduler:
file  scheduleredfimpl.h
 EDF Scheduler Implementation.
struct  Scheduler_EDF_Context
struct  Scheduler_EDF_Node
 Scheduler node specialization for EDF schedulers. More...
#define SCHEDULER_EDF_ENTRY_POINTS
 Entry points for the Earliest Deadline First Scheduler. More...
#define SCHEDULER_EDF_PRIO_MSB   0x80000000
 This is just a most significant bit of Priority_Control type. More...
enum  Scheduler_EDF_Queue_state { SCHEDULER_EDF_QUEUE_STATE_NOT_PRESENTLY, SCHEDULER_EDF_QUEUE_STATE_YES, SCHEDULER_EDF_QUEUE_STATE_NEVER_HAS_BEEN }
 This enumeration distiguishes state of a thread with respect to the ready queue.
void _Scheduler_EDF_Initialize (const Scheduler_Control *scheduler)
 Initialize EDF scheduler. More...
void _Scheduler_EDF_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Removes thread from ready queue. More...
void _Scheduler_EDF_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Sets the heir thread to be the next ready thread in the rbtree ready queue. More...
void _Scheduler_EDF_Node_initialize (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Initializes an EDF specific scheduler node of the_thread. More...
void _Scheduler_EDF_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Control new_priority)
 Updates position in the ready queue of the_thread. More...
Scheduler_Void_or_thread _Scheduler_EDF_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Adds the_thread to the scheduling decision. More...
Scheduler_Void_or_thread _Scheduler_EDF_Change_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Control new_priority, bool prepend_it)
Scheduler_Void_or_thread _Scheduler_EDF_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 invoked when a thread wishes to voluntarily transfer control of the processor to another thread with equal deadline. More...
int _Scheduler_EDF_Priority_compare (Priority_Control p1, Priority_Control p2)
 Explicitly compare absolute dedlines (priorities) of threads. More...
void _Scheduler_EDF_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, uint32_t deadline)
 Called when a new job of task is released. More...
RTEMS_INLINE_ROUTINE Scheduler_EDF_Context_Scheduler_EDF_Get_context (const Scheduler_Control *scheduler)
RTEMS_INLINE_ROUTINE Scheduler_EDF_Node_Scheduler_EDF_Thread_get_node (Thread_Control *the_thread)
RBTree_Compare_result _Scheduler_EDF_Compare (const RBTree_Node *n1, const RBTree_Node *n2)
RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Enqueue (const Scheduler_Control *scheduler, Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Extract (const Scheduler_Control *scheduler, Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE void _Scheduler_EDF_Schedule_body (const Scheduler_Control *scheduler, Thread_Control *the_thread, bool force_dispatch)
◆ SCHEDULER_EDF_ENTRY_POINTS
Value:
_Scheduler_EDF_Initialize, /* initialize entry point */ \
_Scheduler_EDF_Schedule, /* schedule entry point */ \
_Scheduler_EDF_Yield, /* yield entry point */ \
_Scheduler_EDF_Block, /* block entry point */ \
_Scheduler_EDF_Unblock, /* unblock entry point */ \
_Scheduler_EDF_Change_priority, /* change priority entry point */ \
_Scheduler_EDF_Node_initialize, /* node initialize entry point */ \
_Scheduler_default_Node_destroy, /* node destroy entry point */ \
_Scheduler_EDF_Update_priority, /* update priority entry point */ \
_Scheduler_EDF_Priority_compare, /* compares two priorities */ \
_Scheduler_EDF_Release_job, /* new period of task */ \
_Scheduler_default_Tick, /* tick entry point */ \
_Scheduler_default_Start_idle /* start idle entry point */ \
SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
void _Scheduler_EDF_Node_initialize(const Scheduler_Control *scheduler, Thread_Control *the_thread)
Definition: scheduleredfnodeinit.c:23
◆ SCHEDULER_EDF_PRIO_MSB
It distinguishes threads which are deadline driven (priority represented by a lower number than SCHEDULER_EDF_PRIO_MSB) from those ones who do not have any deadlines and thus are considered background tasks.
Referenced by _Scheduler_EDF_Priority_compare(), and _Scheduler_EDF_Release_job().
◆ _Scheduler_EDF_Block()
void _Scheduler_EDF_Block ( const Scheduler_Control scheduler,
Thread_Control the_thread
This routine removes the_thread from the scheduling decision, that is, removes it from the ready queue. It performs any necessary scheduling operations including the selection of a new heir thread.
Parameters
[in]schedulerThe scheduler instance.
[in]the_threadis the thread to be blocked.
◆ _Scheduler_EDF_Initialize()
void _Scheduler_EDF_Initialize ( const Scheduler_Control scheduler)
This routine initializes the EDF scheduler.
Parameters
◆ _Scheduler_EDF_Node_initialize()
void _Scheduler_EDF_Node_initialize ( const Scheduler_Control scheduler,
Parameters
[in]the_threadbeing initialized.
◆ _Scheduler_EDF_Priority_compare()
int _Scheduler_EDF_Priority_compare ( Priority_Control  p1,
Priority_Control  p2
This routine explicitly compares absolute dedlines (priorities) of threads. In case of EDF scheduling time overflow is taken into account.
Return values
>0for p1 > p2; 0 for p1 == p2; <0 for p1 < p2.
References _Watchdog_Ticks_since_boot, and SCHEDULER_EDF_PRIO_MSB.
◆ _Scheduler_EDF_Release_job()
void _Scheduler_EDF_Release_job ( const Scheduler_Control scheduler,
Thread_Control the_thread,
uint32_t  deadline
This routine is called when a new job of task is released. It is called only from Rate Monotonic manager in the beginning of new period.
Parameters
[in]the_threadis the owner of the job.
[in]deadlineof the new job from now. If equal to 0, the job was cancelled or deleted, thus a running task has to be suspended.
References _Thread_Set_priority(), _Watchdog_Ticks_since_boot, Thread_Start_information::initial_priority, SCHEDULER_EDF_PRIO_MSB, and Thread_Control::Start.
◆ _Scheduler_EDF_Schedule()
void _Scheduler_EDF_Schedule ( const Scheduler_Control scheduler,
This kernel routine sets the heir thread to be the next ready thread in the rbtree ready queue.
Parameters
[in]the_threadbeing scheduled.
◆ _Scheduler_EDF_Unblock()
Scheduler_Void_or_thread _Scheduler_EDF_Unblock ( const Scheduler_Control scheduler,
This routine adds the_thread to the scheduling decision, that is, adds it to the ready queue and updates any appropriate scheduling variables, for example the heir thread.
Parameters
[in]the_threadwill be unblocked.
◆ _Scheduler_EDF_Update_priority()
void _Scheduler_EDF_Update_priority ( const Scheduler_Control scheduler,
This routine updates position in the ready queue of the_thread.
Parameters
[in]the_threadwill have its scheduler specific information structure updated.
[in]new_priorityis the desired new priority.
◆ _Scheduler_EDF_Yield()
Scheduler_Void_or_thread _Scheduler_EDF_Yield ( const Scheduler_Control scheduler,
This routine is invoked when a thread wishes to voluntarily transfer control of the processor to another thread in the queue with equal deadline. This does not have to happen very often.
This routine will remove the specified THREAD from the ready queue and place it back. The rbtree ready queue is responsible for FIFO ordering in such a case.
Parameters
[in,out]the_threadThe yielding thread.
