The Red-Black Tree Handler is used to manage sets of entities. More...
Files | |
| file | rbtree.c |
| Initialize a RBTree Header. | |
| file | rbtreefind.c |
| Find the control structure of the tree containing the given node. | |
| file | rbtreeiterate.c |
| _RBTree_Iterate() implementation. | |
| file | rbtreenext.c |
| _RBTree_Next() and _RBTree_Next() implementation. | |
| struct | RBTree_Node_struct |
| This is used to manage each element (node) which is placed on a RBT. More... | |
| struct | RBTree_Control |
| This is used to manage a RBT. More... | |
| #define | RBTREE_INITIALIZER_EMPTY(name) { NULL, NULL, { NULL, NULL } } |
| RBTree initializer for an empty rbtree with designator name. | |
| #define | RBTREE_DEFINE_EMPTY(name) RBTree_Control name = RBTREE_INITIALIZER_EMPTY( name ) |
| RBTree definition for an empty rbtree with designator name. | |
| #define | RBTREE_NODE_INITIALIZER_EMPTY(name) { NULL, { NULL, NULL }, RBT_RED } |
| RBTree_Node initializer for an empty node with designator name. | |
| #define | RBTREE_NODE_DEFINE_EMPTY(name) RBTree_Node name = RBTREE_NODE_INITIALIZER_EMPTY( name ) |
Typedefs | |
| typedef struct RBTree_Node_struct | RBTree_Node |
| This type definition promotes the name for the RBTree Node used by all RTEMS code. More... | |
| typedef long | RBTree_Compare_result |
| Integer type for compare results. More... | |
| typedef RBTree_Compare_result(* | RBTree_Compare) (const RBTree_Node *first, const RBTree_Node *second) |
| Compares two red-black tree nodes. More... | |
| typedef bool(* | RBTree_Visitor) (const RBTree_Node *node, RBTree_Direction dir, void *visitor_arg) |
| Red-black tree visitor. More... | |
Enumerations | |
| enum | RBTree_Color { RBT_BLACK, RBT_RED } |
| This enum type defines the colors available for the RBTree Nodes. | |
| enum | RBTree_Direction { RBT_LEFT =0, RBT_RIGHT =1 } |
| This type indicates the direction. | |
| void | _RBTree_Initialize (RBTree_Control *the_rbtree, RBTree_Compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique) |
| Initialize a RBTree Header. More... | |
| RBTree_Node * | _RBTree_Find (const RBTree_Control *the_rbtree, const RBTree_Node *the_node, RBTree_Compare compare, bool is_unique) |
| Tries to find a node for the specified key in the tree. More... | |
| RBTree_Node * | _RBTree_Insert (RBTree_Control *the_rbtree, RBTree_Node *the_node, RBTree_Compare compare, bool is_unique) |
| Inserts the node into the red-black tree. More... | |
| void | _RBTree_Extract (RBTree_Control *the_rbtree, RBTree_Node *the_node) |
| Extracts (removes) the node from the red-black tree. More... | |
| RBTree_Node * | _RBTree_Next (const RBTree_Node *node, RBTree_Direction dir) |
| Returns the in-order next node of a node. More... | |
| RTEMS_INLINE_ROUTINE void | _RBTree_Set_off_tree (RBTree_Node *the_node) |
| Sets a red-black tree node as off-tree. More... | |
| RTEMS_INLINE_ROUTINE bool | _RBTree_Is_node_off_tree (const RBTree_Node *the_node) |
| Returns true, if this red-black tree node is off-tree, and false otherwise. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _RBTree_Root (const RBTree_Control *the_rbtree) |
| Returns a pointer to root node of the red-black tree. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _RBTree_First (const RBTree_Control *the_rbtree, RBTree_Direction dir) |
| Return pointer to RBTree's first node. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _RBTree_Parent (const RBTree_Node *the_node) |
| Returns a pointer to the parent of this node. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _RBTree_Left (const RBTree_Node *the_node) |
| Return pointer to the left of this node. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _RBTree_Right (const RBTree_Node *the_node) |
| Return pointer to the right of this node. More... | |
| RTEMS_INLINE_ROUTINE bool | _RBTree_Is_empty (const RBTree_Control *the_rbtree) |
| Is the RBTree empty. More... | |
| RTEMS_INLINE_ROUTINE bool | _RBTree_Is_first (const RBTree_Control *the_rbtree, const RBTree_Node *the_node, RBTree_Direction dir) |
| Is this the first node on the RBTree. More... | |
| RTEMS_INLINE_ROUTINE bool | _RBTree_Is_root (const RBTree_Node *the_node) |
| Returns true if this node is the root node of a red-black tree, and false otherwise. More... | |
| RTEMS_INLINE_ROUTINE void | _RBTree_Initialize_empty (RBTree_Control *the_rbtree) |
| Initialize this RBTree as empty. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _RBTree_Predecessor (const RBTree_Node *node) |
| Returns the predecessor of a node. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _RBTree_Successor (const RBTree_Node *node) |
| Returns the successor of a node. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _RBTree_Get (RBTree_Control *the_rbtree, RBTree_Direction dir) |
| Gets a node with an extremal key value from the red-black tree. More... | |
| void | _RBTree_Iterate (const RBTree_Control *rbtree, RBTree_Direction dir, RBTree_Visitor visitor, void *visitor_arg) |
| Red-black tree iteration. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Direction | _RBTree_Opposite_direction (RBTree_Direction the_dir) |
| Get the direction opposite to the_dir. | |
| RTEMS_INLINE_ROUTINE RBTree_Direction | _RBTree_Direction (const RBTree_Node *the_node, const RBTree_Node *parent) |
| Returns the direction of the node. More... | |
| RTEMS_INLINE_ROUTINE bool | _RBTree_Is_red (const RBTree_Node *the_node) |
| Is this node red. More... | |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _RBTree_Sibling (const RBTree_Node *the_node, const RBTree_Node *parent) |
| Returns the sibling of the node. More... | |
| RTEMS_INLINE_ROUTINE bool | _RBTree_Is_equal (RBTree_Compare_result compare_result) |
| RTEMS_INLINE_ROUTINE bool | _RBTree_Is_greater (RBTree_Compare_result compare_result) |
| RTEMS_INLINE_ROUTINE bool | _RBTree_Is_lesser (RBTree_Compare_result compare_result) |
| RTEMS_INLINE_ROUTINE void | _RBTree_Rotate (RBTree_Node *the_node, RBTree_Direction dir) |
| Rotates the node in the specified direction. More... | |
This handler provides two data structures. The rbtree Node data structure is included as the first part of every data structure that will be placed on a RBTree. The second data structure is rbtree Control which is used to manage a set of rbtree Nodes.
| typedef RBTree_Compare_result( * RBTree_Compare) (const RBTree_Node *first, const RBTree_Node *second) |
| [in] | first | The first node. |
| [in] | second | The second node. |
| positive | The key value of the first node is greater than the one of the second node. |
| 0 | The key value of the first node is equal to the one of the second node. |
| negative | The key value of the first node is less than the one of the second node. |
| typedef long RBTree_Compare_result |
The type is large enough to represent pointers and 32-bit signed integers.
It is a separate type definition because a forward reference is required to define it. See RBTree_Node_struct for detailed information.
| typedef bool(* RBTree_Visitor) (const RBTree_Node *node, RBTree_Direction dir, void *visitor_arg) |
| [in] | node | The node. |
| [in] | dir | The direction. |
| [in] | visitor_arg | The visitor argument. |
| true | Stop the iteration. |
| false | Continue the iteration. |
| RTEMS_INLINE_ROUTINE RBTree_Direction _RBTree_Direction | ( | const RBTree_Node * | the_node, |
| const RBTree_Node * | parent | ||
| [in] | the_node | The node of interest. |
| [in] | parent | The parent of the node. The parent must exist, thus it is invalid to use this function for the root node. |
References RBTree_Node_struct::child.
Referenced by _RBTree_Rotate().
| void _RBTree_Extract | ( | RBTree_Control * | the_rbtree, |
| RBTree_Node * | the_node | ||
This function does not set the node off-tree. In case this is desired, then call _RBTree_Set_off_tree() after the extraction.
In case the node to extract is not a node of the tree, then this function yields unpredictable results.
| [in] | the_rbtree | The red-black tree control. |
| [in] | the_node | The node to extract. |
References RBTree_Control::first.
Referenced by _RBTree_Get(), and rtems_rbtree_extract().
| RBTree_Node* _RBTree_Find | ( | const RBTree_Control * | the_rbtree, |
| const RBTree_Node * | the_node, | ||
| RBTree_Compare | compare, | ||
| bool | is_unique | ||
| [in] | the_node | A node specifying the key. |
| [in] | compare | The node compare function. |
| [in] | is_unique | If true, then return the first node with a key equal to the one of the node specified if it exits, else return the last node if it exists. |
| node | A node corresponding to the key. If the tree is not unique and contains duplicate keys, the set of duplicate keys acts as FIFO. |
| NULL | No node exists in the tree for the key. |
| RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_First | ( | const RBTree_Control * | the_rbtree, |
| RBTree_Direction | dir | ||
This function returns a pointer to the first node on the_rbtree, where dir specifies whether to return the minimum (0) or maximum (1).
Referenced by _RBTree_Is_first(), _RBTree_Iterate(), rtems_rbtree_max(), rtems_rbtree_min(), rtems_rbtree_peek_max(), and rtems_rbtree_peek_min().
| RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Get | ( | RBTree_Control * | the_rbtree, |
This function extracts a node with the minimum or maximum key value from tree and returns a pointer to that node if it exists. In case multiple nodes with a minimum key value exist, then they are extracted in FIFO order. In case multiple nodes with a maximum key value exist, then they are extracted in LIFO order.
| [in] | dir | Specifies whether to get a node with the minimum (RBT_LEFT) or maximum (RBT_RIGHT) key value. |
| NULL | The tree is empty. |
| extremal_node | A node with a minimal or maximal key value on the tree. |
References _RBTree_Extract(), and RBTree_Control::first.
Referenced by rtems_rbtree_get_max(), and rtems_rbtree_get_min().
| void _RBTree_Initialize | ( | RBTree_Control * | the_rbtree, |
| void * | starting_address, | ||
| size_t | number_nodes, | ||
| size_t | node_size, | ||
This routine initializes the_rbtree structure to manage the contiguous array of number_nodes nodes which starts at starting_address. Each node is of node_size bytes.
| [in] | the_rbtree | is the pointer to rbtree header |
| [in] | starting_address | is the starting address of first node |
| [in] | number_nodes | is the number of nodes in rbtree |
| [in] | node_size | is the size of node in bytes |
| [in] | is_unique | If true, then reject nodes with a duplicate key, else otherwise. |
| RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty | ( | RBTree_Control * | the_rbtree | ) |
This routine initializes the_rbtree to contain zero nodes.
References RBTree_Control::first, RBTree_Control::permanent_null, and RBTree_Control::root.
Referenced by rtems_rbtree_initialize_empty().
| RBTree_Node* _RBTree_Insert | ( | RBTree_Control * | the_rbtree, |
In case the node is already a node of a tree, then this function yields unpredictable results.
| [in] | the_node | The node to insert. |
| [in] | is_unique | If true, then reject nodes with a duplicate key, else insert nodes in FIFO order in case the key value is equal to existing nodes. |
| NULL | Successfully inserted. |
| existing_node | This is a unique insert and there exists a node with an equal key in the tree already. |
| RTEMS_INLINE_ROUTINE bool _RBTree_Is_empty | ( | const RBTree_Control * | the_rbtree | ) |
This function returns true if there are no nodes on the_rbtree and false otherwise.
| [in] | the_rbtree | is the rbtree to be operated upon. |
| true | There are no nodes on the_rbtree. |
| false | There are nodes on the_rbtree. |
References RBTree_Control::root.
Referenced by rtems_rbtree_is_empty().
| RTEMS_INLINE_ROUTINE bool _RBTree_Is_first | ( | const RBTree_Control * | the_rbtree, |
This function returns true if the_node is the first node on the_rbtree and false otherwise. dir specifies whether first means minimum (0) or maximum (1).
| true | the_node is the first node on the_rbtree. |
| false | the_node is not the first node on the_rbtree. |
References _RBTree_First().
Referenced by rtems_rbtree_is_max(), and rtems_rbtree_is_min().
| RTEMS_INLINE_ROUTINE bool _RBTree_Is_node_off_tree | ( | const RBTree_Node * | the_node | ) |
| [in] | the_node | The node to test. |
| true | The node is not a part of a tree (off-tree). |
| false | Otherwise. |
References RBTree_Node_struct::parent.
Referenced by rtems_rbtree_is_node_off_tree().
| RTEMS_INLINE_ROUTINE bool _RBTree_Is_red | ( | const RBTree_Node * | the_node | ) |
Is this node red.
This function returns true if the_node is red and false otherwise.
| true | the_node is red. |
| false | the_node in not red. |
References RBTree_Node_struct::color.
| RTEMS_INLINE_ROUTINE bool _RBTree_Is_root | ( | const RBTree_Node * | the_node | ) |
The root node may change after insert or extract operations. In case the node is not a node of a tree, then this function yields unpredictable results.
| true | The node is the root node. |
References _RBTree_Parent().
Referenced by rtems_rbtree_is_root().
| void _RBTree_Iterate | ( | const RBTree_Control * | rbtree, |
| RBTree_Direction | dir, | ||
| RBTree_Visitor | visitor, | ||
| void * | visitor_arg | ||
| [in] | rbtree | The red-black tree. |
| [in] | visitor | The visitor. |
References _RBTree_First(), _RBTree_Next(), and _RBTree_Opposite_direction().
| RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Left | ( | const RBTree_Node * | the_node | ) |
This function returns a pointer to the left node of this node.
| [in] | the_node | is the node to be operated upon. |
Referenced by rtems_rbtree_left().
| RBTree_Node* _RBTree_Next | ( | const RBTree_Node * | node, |
| NULL | The in-order next node does not exist. |
| otherwise | The next node. |
References _RBTree_Opposite_direction(), and RBTree_Node_struct::child.
Referenced by _RBTree_Iterate(), _RBTree_Predecessor(), and _RBTree_Successor().
| RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Parent | ( | const RBTree_Node * | the_node | ) |
The node must have a parent, thus it is invalid to use this function for the root node or a node that is not part of a tree. To test for the root node compare with _RBTree_Root() or use _RBTree_Is_root().
| parent | The parent of this node. |
| undefined | The node is the root node or not part of a tree. |
Referenced by _RBTree_Is_root(), _RBTree_Rotate(), and rtems_rbtree_parent().
| RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Predecessor | ( | const RBTree_Node * | node | ) |
| [in] | node | is the node. |
| NULL | The predecessor does not exist. Otherwise it returns the predecessor node. |
References _RBTree_Next().
Referenced by rtems_rbtree_predecessor().
| RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Right | ( | const RBTree_Node * | the_node | ) |
This function returns a pointer to the right node of this node.
Referenced by rtems_rbtree_right().
| RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Root | ( | const RBTree_Control * | the_rbtree | ) |
| root | The root node. |
Referenced by rtems_rbtree_root().
| RTEMS_INLINE_ROUTINE void _RBTree_Rotate | ( | RBTree_Node * | the_node, |
The node is swapped with its child in the opposite direction if it exists.
Sub-tree before rotation:
Sub-tree after rotation:
| [in] | the_node | The node to rotate. |
| [in] | dir | The rotation direction. |
References _RBTree_Direction(), _RBTree_Opposite_direction(), _RBTree_Parent(), RBTree_Node_struct::child, and RBTree_Node_struct::parent.
| RTEMS_INLINE_ROUTINE void _RBTree_Set_off_tree | ( | RBTree_Node * | the_node | ) |
Do not use this function on nodes which are a part of a tree.
| [in] | the_node | The node to set off-tree. |
Referenced by rtems_rbtree_set_off_tree().
| RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Sibling | ( | const RBTree_Node * | the_node, |
| NULL | No sibling exists. |
| sibling | The sibling of the node. |
| RTEMS_INLINE_ROUTINE RBTree_Node* _RBTree_Successor | ( | const RBTree_Node * | node | ) |
| NULL | The successor does not exist. Otherwise the successor node. |
Referenced by rtems_rbtree_successor().
