Here is a list of all documented functions, variables, defines, enums, and typedefs with links to the documentation:
- f -
F12_F13_OFFSET :
cpu.h
F14_F15_OFFSET :
cpu.h
F16_F17_OFFSET :
cpu.h
F18_F19_OFFSET :
cpu.h
F1O_F11_OFFSET :
cpu.h
F22_F23_OFFSET :
cpu.h
F24_F25_OFFSET :
cpu.h
F26_F27_OFFSET :
cpu.h
F28_F29_OFFSET :
cpu.h
F2_F3_OFFSET :
cpu.h
F2O_F21_OFFSET :
cpu.h
F3O_F31_OFFSET :
cpu.h
F4_F5_OFFSET :
cpu.h
F6_F7_OFFSET :
cpu.h
F8_F9_OFFSET :
cpu.h
fastlz_compress() :
fastlz.c
fastlz.h
fastlz_compress_level() :
fastlz.c
fastlz.h
fastlz_decompress() :
fastlz.c
fastlz.h
fat_file_fd_t :
fat_file.h
fat_file_map_t :
fat_file.h
fchdir() :
fchdir.c
fchmod() :
fchmod.c
fchown() :
fchown.c
fifo_open() :
fifo.c
pipe.h
FO_F1_OFFSET :
cpu.h
fpathconf() :
fpathconf.c
frame_buffer_close() :
framebuffer.h
frame_buffer_control() :
framebuffer.h
FRAME_BUFFER_DRIVER_TABLE_ENTRY :
framebuffer.h
frame_buffer_initialize() :
framebuffer.h
frame_buffer_open() :
framebuffer.h
frame_buffer_read() :
framebuffer.h
frame_buffer_write() :
framebuffer.h
FRAMEBUFFER_DEVICE_0_NAME :
framebuffer.h
FRAMEBUFFER_DEVICE_NAME :
framebuffer.h
Freechain_Allocator :
freechain.h
FSR_OFFSET :
cpu.h
fsync() :
fsync.c
