#define | FASTLZ_VERSION 0x000100 |
#define | FASTLZ_VERSION_MAJOR 0 |
#define | FASTLZ_VERSION_MINOR 0 |
#define | FASTLZ_VERSION_REVISION 0 |
#define | FASTLZ_VERSION_STRING "0.1.0" |
int | fastlz_compress (const void *input, int length, void *output) |
Compress a block of data in the input buffer and returns the size of compressed block. More... | |
int | fastlz_decompress (const void *input, int length, void *output, int maxout) |
Decompress a block of compressed data and returns the size of the decompressed block. More... | |
int | fastlz_compress_level (int level, const void *input, int length, void *output) |
int fastlz_compress | ( | const void * | input, |
int | length, | ||
void * | output | ||
The size of input buffer is specified by length. The minimum input buffer size is 16.
The output buffer must be at least 5% larger than the input buffer and can not be smaller than 66 bytes.
If the input is not compressible, the return value might be larger than length (input buffer size).
The input buffer and the output buffer can not overlap.
References fastlz_decompress().
int fastlz_compress_level | ( | int | level, |
const void * | input, | ||
int | length, | ||
Compression level can be specified in parameter level. At the moment, only level 1 and level 2 are supported. Level 1 is the fastest compression and generally useful for short data. Level 2 is slightly slower but it gives better compression ratio.
Note that the compressed data, regardless of the level, can always be decompressed using the function fastlz_decompress above.
int fastlz_decompress | ( | const void * | input, |
int | length, | ||
void * | output, | ||
int | maxout | ||
If error occurs, e.g. the compressed data is corrupted or the output buffer is not large enough, then 0 (zero) will be returned instead.
Decompression is memory safe and guaranteed not to write the output buffer more than what is specified in maxout.
Referenced by fastlz_compress().
