fastlz.h
1 /*
2  FastLZ - lightning-fast lossless compression library
3
4  Copyright (C) 2007 Ariya Hidayat (ariya@kde.org)
5  Copyright (C) 2006 Ariya Hidayat (ariya@kde.org)
6  Copyright (C) 2005 Ariya Hidayat (ariya@kde.org)
7
8  Permission is hereby granted, free of charge, to any person obtaining a copy
9  of this software and associated documentation files (the "Software"), to deal
10  in the Software without restriction, including without limitation the rights
11  to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
12  copies of the Software, and to permit persons to whom the Software is
13  furnished to do so, subject to the following conditions:
14
15  The above copyright notice and this permission notice shall be included in
16  all copies or substantial portions of the Software.
17
18  THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
19  IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
20  FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
21  AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
22  LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
23  OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
24  THE SOFTWARE.
25 */
26
27 #ifndef FASTLZ_H
28 #define FASTLZ_H
29
30 #define FASTLZ_VERSION 0x000100
31
32 #define FASTLZ_VERSION_MAJOR 0
33 #define FASTLZ_VERSION_MINOR 0
34 #define FASTLZ_VERSION_REVISION 0
35
36 #define FASTLZ_VERSION_STRING "0.1.0"
37
38 #if defined (__cplusplus)
39 extern "C" {
40 #endif
41
56 int fastlz_compress(const void* input, int length, void* output);
57
70 int fastlz_decompress(const void* input, int length, void* output, int maxout);
71
94 int fastlz_compress_level(int level, const void* input, int length, void* output);
95
96 #if defined (__cplusplus)
97 }
98 #endif
99
100 #endif /* FASTLZ_H */
int fastlz_compress_level(int level, const void *input, int length, void *output)
Compress a block of data in the input buffer and returns the size of compressed block.
Definition: fastlz.c:155
int fastlz_compress(const void *input, int length, void *output)
Definition: fastlz.c:131
int fastlz_decompress(const void *input, int length, void *output, int maxout)
Decompress a block of compressed data and returns the size of the decompressed block.
Definition: fastlz.c:141
