Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Fat File
file  fat_file.c
 General operations on "fat-file".
file  fat_file.h
 Constants/Data Structures/Prototypes for Operations on "fat-file".
struct  fat_file_map_s
 The "fat-file" representation. More...
struct  fat_file_fd_s
 Descriptor of a fat-file. More...
#define FAT_FILE_REMOVED   0x01
#define FAT_FILE_META_DATA_CHANGED   0x02
#define F_CLU_NUM   0x01
#define FAT_ROOTDIR_CLUSTER_NUM   0x01
#define FAT_FD_OF_ROOT_DIR(fat_fd)
#define FAT_EOF   0x00
typedef struct fat_file_map_s fat_file_map_t
typedef struct fat_file_fd_s fat_file_fd_t
enum  fat_file_type_t { FAT_DIRECTORY = 0, FAT_HARD_LINK = 2, FAT_FILE = 4 }
int fat_file_open (fat_fs_info_t *fs_info, fat_dir_pos_t *dir_pos, fat_file_fd_t **fat_fd)
int fat_file_reopen (fat_file_fd_t *fat_fd)
int fat_file_close (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd)
ssize_t fat_file_read (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd, uint32_t start, uint32_t count, uint8_t *buf)
ssize_t fat_file_write (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd, uint32_t start, uint32_t count, const uint8_t *buf)
int fat_file_extend (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd, bool zero_fill, uint32_t new_length, uint32_t *a_length)
int fat_file_truncate (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd, uint32_t new_length)
int fat_file_ioctl (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd, int cmd,...)
int fat_file_size (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd)
void fat_file_mark_removed (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd)
int fat_file_write_first_cluster_num (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd)
int fat_file_write_file_size (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd)
int fat_file_write_time_and_date (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd)
int fat_file_update (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd)
◆ FAT_FD_OF_ROOT_DIR
#define FAT_FD_OF_ROOT_DIR (   fat_fd)
Value:
((fat_fd->dir_pos.sname.cln == FAT_ROOTDIR_CLUSTER_NUM) && \
(fat_fd->dir_pos.sname.ofs == 0))
Typedef Documentation
◆ fat_file_fd_t
To each particular clusters chain
◆ fat_file_map_t
the idea is: fat-file is nothing but a cluster chain, any open fat-file is represented in system by fat-file descriptor and has well-known file interface:
fat_file_open() fat_file_close() fat_file_read() fat_file_write()
Such interface hides the architecture of fat-file and represents it like linear file
