Files | Macros | Functions
Classic Attributes Implementation
Collaboration diagram for Classic Attributes Implementation:
file  attrimpl.h
 Classic Attributes Implementation.
#define ATTRIBUTES_NOT_SUPPORTED   0
 This attribute constant indicates the attributes that are not supportable given the hardware configuration.
#define ATTRIBUTES_REQUIRED   RTEMS_FLOATING_POINT
 This attribute constant indicates the attributes that are required given the hardware configuration.
RTEMS_INLINE_ROUTINE rtems_attribute _Attributes_Set (rtems_attribute new_attributes, rtems_attribute attribute_set)
 Sets the requested new_attributes in the attribute_set passed in. More...
RTEMS_INLINE_ROUTINE rtems_attribute _Attributes_Clear (rtems_attribute attribute_set, rtems_attribute mask)
 Clears the requested new_attributes in the attribute_set passed in. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_floating_point (rtems_attribute attribute_set)
 Checks if the floating point attribute is enabled in the attribute_set. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_priority (rtems_attribute attribute_set)
 Checks if the priority attribute is enabled in the attribute_set. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_binary_semaphore (rtems_attribute attribute_set)
 Checks if the binary semaphore attribute is enabled in the attribute_set. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_simple_binary_semaphore (rtems_attribute attribute_set)
 Checks if the simple binary semaphore attribute is enabled in the attribute_set. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_counting_semaphore (rtems_attribute attribute_set)
 Checks if the counting semaphore attribute is enabled in the attribute_set. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_inherit_priority (rtems_attribute attribute_set)
 Checks if the priority inheritance attribute is enabled in the attribute_set. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Has_at_most_one_protocol (rtems_attribute attribute_set)
 Returns true if the attribute set has at most one protocol, and false otherwise. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_priority_ceiling (rtems_attribute attribute_set)
 Checks if the priority ceiling attribute is enabled in the attribute_set. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_multiprocessor_resource_sharing (rtems_attribute attribute_set)
 Checks if the Multiprocessor Resource Sharing Protocol attribute is enabled in the attribute_set. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_barrier_automatic (rtems_attribute attribute_set)
 Checks if the barrier automatic release attribute is enabled in the attribute_set. More...
RTEMS_INLINE_ROUTINE bool _Attributes_Is_system_task (rtems_attribute attribute_set)
 Checks if the system task attribute is enabled in the attribute_set. More...
◆ _Attributes_Clear()
RTEMS_INLINE_ROUTINE rtems_attribute _Attributes_Clear ( rtems_attribute  attribute_set,
This function clears the requested new_attributes in the attribute_set passed in. The result is returned to the user.
◆ _Attributes_Has_at_most_one_protocol()
RTEMS_INLINE_ROUTINE bool _Attributes_Has_at_most_one_protocol ( rtems_attribute  attribute_set)
The protocols are RTEMS_INHERIT_PRIORITY, RTEMS_PRIORITY_CEILING and RTEMS_MULTIPROCESSOR_RESOURCE_SHARING.
References RTEMS_INHERIT_PRIORITY, RTEMS_MULTIPROCESSOR_RESOURCE_SHARING, and RTEMS_PRIORITY_CEILING.
Referenced by rtems_semaphore_create().
◆ _Attributes_Is_barrier_automatic()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_barrier_automatic ( rtems_attribute  attribute_set)
This function returns TRUE if the barrier automatic release attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_BARRIER_AUTOMATIC_RELEASE.
Referenced by rtems_barrier_create().
◆ _Attributes_Is_binary_semaphore()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_binary_semaphore ( rtems_attribute  attribute_set)
This function returns TRUE if the binary semaphore attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_BINARY_SEMAPHORE, and RTEMS_SEMAPHORE_CLASS.
◆ _Attributes_Is_counting_semaphore()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_counting_semaphore ( rtems_attribute  attribute_set)
This function returns TRUE if the counting semaphore attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_COUNTING_SEMAPHORE, and RTEMS_SEMAPHORE_CLASS.
◆ _Attributes_Is_floating_point()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_floating_point ( rtems_attribute  attribute_set)
This function returns TRUE if the floating point attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_FLOATING_POINT, RTEMS_GLOBAL, and RTEMS_INLINE_ROUTINE.
◆ _Attributes_Is_inherit_priority()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_inherit_priority ( rtems_attribute  attribute_set)
This function returns TRUE if the priority inheritance attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_INHERIT_PRIORITY.
◆ _Attributes_Is_multiprocessor_resource_sharing()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_multiprocessor_resource_sharing ( rtems_attribute  attribute_set)
This function returns TRUE if the Multiprocessor Resource Sharing Protocol attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_MULTIPROCESSOR_RESOURCE_SHARING.
◆ _Attributes_Is_priority()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_priority ( rtems_attribute  attribute_set)
This function returns TRUE if the priority attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_PRIORITY.
◆ _Attributes_Is_priority_ceiling()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_priority_ceiling ( rtems_attribute  attribute_set)
This function returns TRUE if the priority ceiling attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_PRIORITY_CEILING.
◆ _Attributes_Is_simple_binary_semaphore()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_simple_binary_semaphore ( rtems_attribute  attribute_set)
This function returns TRUE if the simple binary semaphore attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_SEMAPHORE_CLASS, and RTEMS_SIMPLE_BINARY_SEMAPHORE.
◆ _Attributes_Is_system_task()
RTEMS_INLINE_ROUTINE bool _Attributes_Is_system_task ( rtems_attribute  attribute_set)
This function returns TRUE if the system task attribute is enabled in the attribute_set and FALSE otherwise.
References RTEMS_SYSTEM_TASK.
◆ _Attributes_Set()
RTEMS_INLINE_ROUTINE rtems_attribute _Attributes_Set ( rtems_attribute  new_attributes,
This function sets the requested new_attributes in the attribute_set passed in. The result is returned to the user.
