cpu.h File Reference
SPARC CPU Department Source. More...
#include <rtems/score/types.h>
#include <rtems/score/sparc.h>
Include dependency graph for cpu.h:
struct  CPU_Minimum_stack_frame
 This structure represents the organization of the minimum stack frame for the SPARC. More...
struct  CPU_Per_CPU_control
 The CPU specific per-CPU control. More...
struct  Context_Control
 This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More...
struct  Context_Control_fp
 This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More...
struct  CPU_Interrupt_frame
 This defines the set of integer and processor state registers that must be saved during an interrupt. More...
struct  CPU_Trap_table_entry
 The following type defines an entry in the SPARC's trap table. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
struct  SPARC_Counter
#define CPU_INLINE_ENABLE_DISPATCH   TRUE
 Should the calls to _Thread_Enable_dispatch be inlined? More...
#define CPU_HAS_SOFTWARE_INTERRUPT_STACK   TRUE
 Does the executive manage a dedicated interrupt stack in software? More...
#define CPU_SIMPLE_VECTORED_INTERRUPTS   TRUE
 Does the CPU follow the simple vectored interrupt model? More...
#define CPU_HAS_HARDWARE_INTERRUPT_STACK   FALSE
 Does this CPU have hardware support for a dedicated interrupt stack? More...
#define CPU_ALLOCATE_INTERRUPT_STACK   TRUE
 Do we allocate a dedicated interrupt stack in the Interrupt Manager? More...
#define CPU_ISR_PASSES_FRAME_POINTER   0
 Does the RTEMS invoke the user's ISR with the vector number and a pointer to the saved interrupt frame (1) or just the vector number (0)? More...
#define CPU_HARDWARE_FP   FALSE
 Does the CPU have hardware floating point? More...
#define CPU_SOFTWARE_FP   FALSE
 The SPARC GCC port does not have a software floating point library that requires RTEMS assistance.
#define CPU_ALL_TASKS_ARE_FP   FALSE
 Are all tasks FLOATING_POINT tasks implicitly? More...
#define CPU_IDLE_TASK_IS_FP   FALSE
 Should the IDLE task have a floating point context? More...
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
 Should the saving of the floating point registers be deferred until a context switch is made to another different floating point task? More...
#define CPU_PROVIDES_IDLE_THREAD_BODY   FALSE
 Does this port provide a CPU dependent IDLE task implementation? More...
#define CPU_STACK_GROWS_UP   FALSE
 Does the stack grow up (toward higher addresses) or down (toward lower addresses)? More...
#define CPU_STRUCTURE_ALIGNMENT   __attribute__ ((aligned (32)))
 The following is the variable attribute used to force alignment of critical data structures. More...
#define CPU_TIMESTAMP_USE_INT64_INLINE   TRUE
#define CPU_BIG_ENDIAN   TRUE
 Define what is required to specify how the network to host conversion routines are handled. More...
#define CPU_LITTLE_ENDIAN   FALSE
#define CPU_MODES_INTERRUPT_MASK   0x0000000F
 The following defines the number of bits actually used in the interrupt field of the task mode. More...
#define CPU_STACK_FRAME_L0_OFFSET   0x00
 This macro defines an offset into the stack frame for use in assembly. More...
#define CPU_STACK_FRAME_L1_OFFSET   0x04
#define CPU_STACK_FRAME_L2_OFFSET   0x08
#define CPU_STACK_FRAME_L3_OFFSET   0x0c
#define CPU_STACK_FRAME_L4_OFFSET   0x10
#define CPU_STACK_FRAME_L5_OFFSET   0x14
#define CPU_STACK_FRAME_L6_OFFSET   0x18
#define CPU_STACK_FRAME_L7_OFFSET   0x1c
#define CPU_STACK_FRAME_I0_OFFSET   0x20
#define CPU_STACK_FRAME_I1_OFFSET   0x24
#define CPU_STACK_FRAME_I2_OFFSET   0x28
#define CPU_STACK_FRAME_I3_OFFSET   0x2c
#define CPU_STACK_FRAME_I4_OFFSET   0x30
#define CPU_STACK_FRAME_I5_OFFSET   0x34
#define CPU_STACK_FRAME_I6_FP_OFFSET   0x38
#define CPU_STACK_FRAME_I7_OFFSET   0x3c
#define CPU_STRUCTURE_RETURN_ADDRESS_OFFSET   0x40
#define CPU_STACK_FRAME_SAVED_ARG0_OFFSET   0x44
#define CPU_STACK_FRAME_SAVED_ARG1_OFFSET   0x48
#define CPU_STACK_FRAME_SAVED_ARG2_OFFSET   0x4c
#define CPU_STACK_FRAME_SAVED_ARG3_OFFSET   0x50
#define CPU_STACK_FRAME_SAVED_ARG4_OFFSET   0x54
#define CPU_STACK_FRAME_SAVED_ARG5_OFFSET   0x58
#define CPU_STACK_FRAME_PAD0_OFFSET   0x5c
#define CPU_MINIMUM_STACK_FRAME_SIZE   0x60
 This defines the size of the minimum stack frame. More...
#define CPU_PER_CPU_CONTROL_SIZE   4
#define SPARC_PER_CPU_ISR_DISPATCH_DISABLE   0
 Offset of the CPU_Per_CPU_control::isr_dispatch_disable field relative to the Per_CPU_Control begin.
#define _CPU_Context_Get_SP(_context)   (_context)->o6_sp
 This macro provides a CPU independent way for RTEMS to access the stack pointer in a context structure. More...
#define G5_OFFSET   0x00
 This macro defines an offset into the context for use in assembly. More...
#define G7_OFFSET   0x04
#define L0_OFFSET   0x08
#define L1_OFFSET   0x0C
#define L2_OFFSET   0x10
#define L3_OFFSET   0x14
#define L4_OFFSET   0x18
#define L5_OFFSET   0x1C
#define L6_OFFSET   0x20
#define L7_OFFSET   0x24
#define I0_OFFSET   0x28
#define I1_OFFSET   0x2C
#define I2_OFFSET   0x30
#define I3_OFFSET   0x34
#define I4_OFFSET   0x38
#define I5_OFFSET   0x3C
#define I6_FP_OFFSET   0x40
#define I7_OFFSET   0x44
#define O6_SP_OFFSET   0x48
#define O7_OFFSET   0x4C
#define PSR_OFFSET   0x50
#define ISR_DISPATCH_DISABLE_STACK_OFFSET   0x54
#define FO_F1_OFFSET   0x00
 This macro defines an offset into the FPU context for use in assembly. More...
#define F2_F3_OFFSET   0x08
#define F4_F5_OFFSET   0x10
#define F6_F7_OFFSET   0x18
#define F8_F9_OFFSET   0x20
#define F1O_F11_OFFSET   0x28
#define F12_F13_OFFSET   0x30
#define F14_F15_OFFSET   0x38
#define F16_F17_OFFSET   0x40
#define F18_F19_OFFSET   0x48
#define F2O_F21_OFFSET   0x50
#define F22_F23_OFFSET   0x58
#define F24_F25_OFFSET   0x60
#define F26_F27_OFFSET   0x68
#define F28_F29_OFFSET   0x70
#define F3O_F31_OFFSET   0x78
#define FSR_OFFSET   0x80
#define CONTEXT_CONTROL_FP_SIZE   0x84
 This defines the size of the FPU context area for use in assembly. More...
#define ISF_PSR_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x00
 This macro defines an offset into the ISF for use in assembly. More...
#define ISF_PC_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x04
#define ISF_NPC_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x08
#define ISF_G1_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x0c
#define ISF_G2_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x10
#define ISF_G3_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x14
#define ISF_G4_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x18
#define ISF_G5_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x1c
#define ISF_G7_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x24
#define ISF_I0_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x28
#define ISF_I1_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x2c
#define ISF_I2_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x30
#define ISF_I3_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x34
#define ISF_I4_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x38
#define ISF_I5_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x3c
#define ISF_I6_FP_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x40
#define ISF_I7_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x44
#define ISF_Y_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x48
#define ISF_TPC_OFFSET   CPU_MINIMUM_STACK_FRAME_SIZE + 0x4c
#define CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE   CPU_MINIMUM_STACK_FRAME_SIZE + 0x50
 This defines the size of the ISF area for use in assembly. More...
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
 The size of the floating point context area.
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   1024
 Amount of extra stack (above minimum stack size) required by MPCI receive server thread. More...
#define CPU_INTERRUPT_NUMBER_OF_VECTORS   256
 This defines the number of entries in the ISR_Vector_table managed by the executive. More...
#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER   511
 The SPARC has 256 vectors but the port treats 256-512 as synchronous traps.
#define SPARC_SYNCHRONOUS_TRAP_BIT_MASK   0x100
 This is the bit step in a vector number to indicate it is being installed as a synchronous trap.
#define SPARC_ASYNCHRONOUS_TRAP(_trap)   (_trap)
 This macro indicates that _trap as an asynchronous trap.
#define SPARC_SYNCHRONOUS_TRAP(_trap)   ((_trap) + 256 )
 This macro indicates that _trap as a synchronous trap.
#define SPARC_REAL_TRAP_NUMBER(_trap)   ((_trap) % 256)
 This macro returns the real hardware vector number associated with _trap.
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
 This is defined if the port has a special way to report the ISR nesting level. More...
#define CPU_STACK_MINIMUM_SIZE   (1024*4)
 Should be large enough to run all tests. More...
#define CPU_SIZEOF_POINTER   4
 What is the size of a pointer on this architecture?
#define CPU_ALIGNMENT   8
 CPU's worst alignment requirement for data types on a byte boundary. More...
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
 This number corresponds to the byte alignment requirement for the heap handler. More...
#define CPU_PARTITION_ALIGNMENT   CPU_ALIGNMENT
 This number corresponds to the byte alignment requirement for memory buffers allocated by the partition manager. More...
#define CPU_STACK_ALIGNMENT   16
 This number corresponds to the byte alignment requirement for the stack. More...
#define _CPU_Initialize_vectors()
 Support routine to initialize the RTEMS vector table after it is allocated.
#define _CPU_ISR_Disable(_level)   (_level) = sparc_disable_interrupts()
 Disable all interrupts for a critical section. More...
#define _CPU_ISR_Enable(_level)   sparc_enable_interrupts( _level )
 Enable interrupts to the previous level (returned by _CPU_ISR_Disable). More...
#define _CPU_ISR_Flash(_level)   sparc_flash_interrupts( _level )
 This temporarily restores the interrupt to _level before immediately disabling them again. More...
#define _CPU_ISR_Set_level(_newlevel)   sparc_enable_interrupts( _newlevel << 8)
 Map interrupt level in task mode onto the hardware that the CPU actually provides. More...
#define _CPU_Context_Initialization_at_thread_begin()
 This macro is invoked from _Thread_Handler to do whatever CPU specific magic is required that must be done in the context of the thread when it starts. More...
#define _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) );
 This routine is responsible for somehow restarting the currently executing task. More...
#define _CPU_Context_Fp_start(_base, _offset)   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
 The FP context area for the SPARC is a simple structure and nothing special is required to find the "starting load point".
#define _CPU_Context_Initialize_fp(_destination)
 This routine initializes the FP context area passed to it to. More...
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
 The SPARC port uses the generic C algorithm for bitfield scan if the CPU model does not have a scan instruction.
#define CPU_USE_GENERIC_BITFIELD_DATA   TRUE
 The SPARC port uses the generic C algorithm for bitfield scan if the CPU model does not have a scan instruction. More...
#define _CPU_Get_current_per_CPU_control()   ( _SPARC_Per_CPU_current )
#define CPU_swap_u16(value)   (((value&0xff) << 8) | ((value >> 8)&0xff))
 SPARC specific method to endian swap an uint16_t. More...
typedef uint32_t CPU_Counter_ticks
typedef CPU_Counter_ticks(* SPARC_Counter_difference) (CPU_Counter_ticks second, CPU_Counter_ticks first)
uint32_t _CPU_ISR_Get_level (void)
 Obtain the current interrupt disable level. More...
void _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
 Initialize the context to a state suitable for starting a task after a context restore operation. More...
void _CPU_Fatal_halt (uint32_t source, uint32_t error)
 This routine copies _error into a known place – typically a stack location or a register, optionally disables interrupts, and halts/stops the CPU.
void _CPU_Initialize (void)
 SPARC specific initialization. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 SPARC specific raw ISR installer. More...
void _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 SPARC specific RTEMS ISR installer. More...
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 SPARC specific context switch. More...
void _CPU_Context_restore (Context_Control *new_context)
 SPARC specific context restore. More...
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__ ("g6")
 The pointer to the current per-CPU control is available via register g6.
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
 SPARC specific save FPU method. More...
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
 SPARC specific restore FPU method. More...
void _CPU_Context_volatile_clobber (uintptr_t pattern)
 Clobbers all volatile registers with values derived from the pattern parameter. More...
void _CPU_Context_validate (uintptr_t pattern)
 Initializes and validates the CPU context with values derived from the pattern parameter. More...
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
CPU_Counter_ticks _SPARC_Counter_difference_default (CPU_Counter_ticks second, CPU_Counter_ticks first)
SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context CPU_STRUCTURE_ALIGNMENT
 This variable is contains the initialize context for the FP unit. More...
const CPU_Trap_table_entry _CPU_Trap_slot_template
 This is the set of opcodes for the instructions loaded into a trap table entry. More...
SPARC_Counter _SPARC_Counter
This include file contains information pertaining to the port of the executive to the SPARC processor.
◆ _CPU_Context_Initialization_at_thread_begin
#define _CPU_Context_Initialization_at_thread_begin ( )
Value:
do { \
__asm__ volatile ("set _Thread_Handler,%%i7\n"::); \
} while (0)
On the SPARC, this is setting the frame pointer so GDB is happy. Make GDB stop unwinding at _Thread_Handler, previous register window Frame pointer is 0 and calling address must be a function with starting with a SAVE instruction. If return address is leaf-function (no SAVE) GDB will not look at prev reg window fp.
_Thread_Handler is known to start with SAVE.
◆ _CPU_Context_Initialize_fp
#define _CPU_Context_Initialize_fp (   _destination)
Value:
do { \
*(*(_destination)) = _CPU_Null_fp_context; \
} while (0)
This variable is optional.
Definition: cpu.h:494
The SPARC allows us to use the simple initialization model in which an "initial" FP context was saved into _CPU_Null_fp_context at CPU initialization and it is simply copied into the destination context.
◆ _CPU_Context_Restart_self
#define _CPU_Context_Restart_self (   _the_context)    _CPU_Context_restore( (_the_context) );
On the SPARC, this is is relatively painless but requires a small amount of wrapper code before using the regular restore code in of the context switch.
◆ _CPU_ISR_Disable
#define _CPU_ISR_Disable (   _level)    (_level) = sparc_disable_interrupts()
The previous level is returned in _level.
◆ _CPU_ISR_Enable
#define _CPU_ISR_Enable (   _level)    sparc_enable_interrupts( _level )
This indicates the end of a critical section. The parameter _level is not modified.
◆ _CPU_ISR_Flash
#define _CPU_ISR_Flash (   _level)    sparc_flash_interrupts( _level )
This is used to divide long critical sections into two or more parts. The parameter _level is not modified.
◆ _CPU_ISR_Set_level
#define _CPU_ISR_Set_level (   _newlevel)    sparc_enable_interrupts( _newlevel << 8)
Currently, interrupt levels which do not map onto the CPU in a straight fashion are undefined.
◆ CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE
◆ CPU_ALIGNMENT
This alignment does not take into account the requirements for the stack.
On the SPARC, this is required for double word loads and stores.
◆ CPU_ALL_TASKS_ARE_FP
  • If TRUE, then the FLOATING_POINT task attribute is assumed.
  • If FALSE, then the FLOATING_POINT task attribute is followed.
The SPARC GCC port does not implicitly use floating point registers.
◆ CPU_ALLOCATE_INTERRUPT_STACK
  • If TRUE, then the memory is allocated during initialization.
  • If FALSE, then the memory is allocated during initialization.
The SPARC does not have hardware support for switching to a dedicated interrupt stack. The port includes support for doing this in software.
◆ CPU_BIG_ENDIAN
The SPARC is big endian.
◆ CPU_HARDWARE_FP
  • If TRUE, then the FLOATING_POINT task attribute is supported.
  • If FALSE, then the FLOATING_POINT task attribute is ignored.
This is set based upon the multilib settings.
◆ CPU_HAS_HARDWARE_INTERRUPT_STACK
  • If TRUE, then it must be installed during initialization.
  • If FALSE, then no installation is performed.
The SPARC does not have a dedicated HW interrupt stack.
◆ CPU_HAS_SOFTWARE_INTERRUPT_STACK
If TRUE, then a stack is allocated in _ISR_Handler_initialization. If FALSE, nothing is done.
The SPARC does not have a dedicated HW interrupt stack and one has been implemented in SW.
◆ CPU_HEAP_ALIGNMENT
This alignment requirement may be stricter than that for the data types alignment specified by CPU_ALIGNMENT. It is common for the heap to follow the same alignment requirement as CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the heap, then this should be set to CPU_ALIGNMENT.
NOTE: This does not have to be a power of 2. It does have to be greater or equal to than CPU_ALIGNMENT.
◆ CPU_IDLE_TASK_IS_FP
  • If TRUE, then the IDLE task is created as a FLOATING_POINT task and it has a floating point context which is switched in and out.
  • If FALSE, then the IDLE task does not have a floating point context.
The IDLE task does not have to be floating point on the SPARC.
◆ CPU_INLINE_ENABLE_DISPATCH
  • If TRUE, then they are inlined.
  • If FALSE, then a subroutine call is made.
On this port, it is faster to inline _Thread_Enable_dispatch.
◆ CPU_INTERRUPT_NUMBER_OF_VECTORS
On the SPARC, there are really only 256 vectors. However, the executive has no easy, fast, reliable way to determine which traps are synchronous and which are asynchronous. By default, synchronous traps return to the instruction which caused the interrupt. So if you install a software trap handler as an executive interrupt handler (which is desirable since RTEMS takes care of window and register issues), then the executive needs to know that the return address is to the trap rather than the instruction following the trap.
So vectors 0 through 255 are treated as regular asynchronous traps which provide the "correct" return address. Vectors 256 through 512 are assumed by the executive to be synchronous and to require that the return address be fudged.
If you use this mechanism to install a trap handler which must reexecute the instruction which caused the trap, then it should be installed as an asynchronous trap. This will avoid the executive changing the return address.
◆ CPU_ISR_PASSES_FRAME_POINTER
The SPARC port does not pass an Interrupt Stack Frame pointer to interrupt handlers.
◆ CPU_LITTLE_ENDIAN
The SPARC is NOT little endian.
◆ CPU_MINIMUM_STACK_FRAME_SIZE
◆ CPU_MODES_INTERRUPT_MASK
How those bits map to the CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
The SPARC has 16 interrupt levels in the PIL field of the PSR.
◆ CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK
Remember that in a multiprocessor system this thread must exist and be able to process all directives.
◆ CPU_PARTITION_ALIGNMENT
This alignment requirement may be stricter than that for the data types alignment specified by CPU_ALIGNMENT. It is common for the partition to follow the same alignment requirement as CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the partition, then this should be set to CPU_ALIGNMENT.
◆ CPU_PROVIDES_IDLE_THREAD_BODY
  • If TRUE, then the routine _CPU_Thread_Idle_body must be provided and is the default IDLE thread body instead of _CPU_Thread_Idle_body.
  • If FALSE, then use the generic IDLE thread body if the BSP does not provide one.
The SPARC architecture does not have a low power or halt instruction. It is left to the BSP and/or CPU specific code to provide an IDLE thread body which is aware of low power modes.
◆ CPU_PROVIDES_ISR_IS_IN_PROGRESS
Most ports maintain the variable _ISR_Nest_level.
◆ CPU_SIMPLE_VECTORED_INTERRUPTS
  • If TRUE, then RTEMS allocates the vector table it internally manages.
  • If FALSE, then the BSP is assumed to allocate and manage the vector table
THe SPARC is a simple vectored architecture. Usually there is no PIC and the CPU directly vectors the interrupts.
◆ CPU_STACK_ALIGNMENT
This alignment requirement may be stricter than that for the data types alignment specified by CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the stack, then this should be set to 0.
NOTE: This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
The alignment restrictions for the SPARC are not that strict but this should unsure that the stack is always sufficiently alignment that the window overflow, underflow, and flush routines can use double word loads and stores.
◆ CPU_STACK_FRAME_I0_OFFSET
◆ CPU_STACK_FRAME_I1_OFFSET
◆ CPU_STACK_FRAME_I2_OFFSET
◆ CPU_STACK_FRAME_I3_OFFSET
◆ CPU_STACK_FRAME_I4_OFFSET
◆ CPU_STACK_FRAME_I5_OFFSET
◆ CPU_STACK_FRAME_I6_FP_OFFSET
◆ CPU_STACK_FRAME_I7_OFFSET
◆ CPU_STACK_FRAME_L0_OFFSET
◆ CPU_STACK_FRAME_L1_OFFSET
◆ CPU_STACK_FRAME_L2_OFFSET
◆ CPU_STACK_FRAME_L3_OFFSET
◆ CPU_STACK_FRAME_L4_OFFSET
◆ CPU_STACK_FRAME_L5_OFFSET
◆ CPU_STACK_FRAME_L6_OFFSET
◆ CPU_STACK_FRAME_L7_OFFSET
◆ CPU_STACK_FRAME_PAD0_OFFSET
◆ CPU_STACK_FRAME_SAVED_ARG0_OFFSET
◆ CPU_STACK_FRAME_SAVED_ARG1_OFFSET
◆ CPU_STACK_FRAME_SAVED_ARG2_OFFSET
◆ CPU_STACK_FRAME_SAVED_ARG3_OFFSET
◆ CPU_STACK_FRAME_SAVED_ARG4_OFFSET
◆ CPU_STACK_FRAME_SAVED_ARG5_OFFSET
◆ CPU_STACK_GROWS_UP
  • If TRUE, then the grows upward.
  • If FALSE, then the grows toward smaller addresses.
The stack grows to lower addresses on the SPARC.
◆ CPU_STACK_MINIMUM_SIZE
This ensures that a "reasonable" small application should not have any problems.
This appears to be a fairly generous number for the SPARC since represents a call depth of about 20 routines based on the minimum stack frame.
◆ CPU_STRUCTURE_ALIGNMENT
On some processors it may make sense to have these aligned on tighter boundaries than the minimum requirements of the compiler in order to have as much of the critical data area as possible in a cache line.
The SPARC does not appear to have particularly strict alignment requirements. This value was chosen to take advantages of caches.
◆ CPU_STRUCTURE_RETURN_ADDRESS_OFFSET
◆ CPU_swap_u16
#define CPU_swap_u16 (   value)    (((value&0xff) << 8) | ((value >> 8)&0xff))
The following routine swaps the endian format of a uint16_t.
Parameters
[in]valueis the value to endian swap
◆ CPU_USE_DEFERRED_FP_SWITCH
  • If TRUE, then the floating point context will not be stored until necessary. It will remain in the floating point registers and not disturned until another floating point task is switched to.
  • If FALSE, then the floating point context is saved when a floating point task is switched out and restored when the next floating point task is restored. The state of the floating point registers between those two operations is not specified.
On the SPARC, we can disable the FPU for integer only tasks so it is safe to defer floating point context switches.
◆ CPU_USE_GENERIC_BITFIELD_DATA
Thus is needs the generic data table used by that algorithm.
◆ ISF_G1_OFFSET
◆ ISF_G2_OFFSET
◆ ISF_G3_OFFSET
◆ ISF_G4_OFFSET
◆ ISF_G5_OFFSET
◆ ISF_G7_OFFSET
◆ ISF_I0_OFFSET
◆ ISF_I1_OFFSET
◆ ISF_I2_OFFSET
◆ ISF_I3_OFFSET
◆ ISF_I4_OFFSET
◆ ISF_I5_OFFSET
◆ ISF_I6_FP_OFFSET
◆ ISF_I7_OFFSET
◆ ISF_NPC_OFFSET
◆ ISF_PC_OFFSET
◆ ISF_PSR_OFFSET
◆ ISF_TPC_OFFSET
◆ ISF_Y_OFFSET
Variable Documentation
◆ _CPU_Trap_slot_template
The routine which installs a handler is responsible for filling in the fields for the _handler address and the _vector trap type.
The constants following this structure are masks for the fields which must be filled in when the handler is installed.
Referenced by _CPU_ISR_install_raw_handler().
