CPU_Minimum_stack_frame Struct Reference
This structure represents the organization of the minimum stack frame for the SPARC. More...
#include <cpu.h>
uint32_t l0
 This is the offset of the l0 register. More...
uint32_t l1
 This is the offset of the l1 register. More...
uint32_t l2
 This is the offset of the l2 register. More...
uint32_t l3
 This is the offset of the l3 register. More...
uint32_t l4
 This is the offset of the l4 register. More...
uint32_t l5
 This is the offset of the l5 register. More...
uint32_t l6
 This is the offset of the l6 register. More...
uint32_t l7
 This is the offset of the l7 register. More...
uint32_t i0
uint32_t i1
 This is the offset of the i1 register. More...
uint32_t i2
 This is the offset of the i2 register. More...
uint32_t i3
 This is the offset of the i3 register. More...
uint32_t i4
 This is the offset of the i4 register. More...
uint32_t i5
 This is the offset of the i5 register. More...
uint32_t i6_fp
 This is the offset of the i6 register. More...
uint32_t i7
 This is the offset of the i7 register. More...
void * structure_return_address
 This is the offset of the register used to return structures. More...
uint32_t saved_arg0
 This is the offset of the register for saved argument 0. More...
uint32_t saved_arg1
 This is the offset of the register for saved argument 1. More...
uint32_t saved_arg2
 This is the offset of the register for saved argument 2. More...
uint32_t saved_arg3
 This is the offset of the register for saved argument 3. More...
uint32_t saved_arg4
 This is the offset of the register for saved argument 4. More...
uint32_t saved_arg5
 This is the offset of the register for saved argument 5. More...
uint32_t pad0
 This field pads the structure so ldd and std instructions can be used. More...
uint64_t l0
uint64_t l1
uint64_t l2
uint64_t l3
uint64_t l4
uint64_t l5
uint64_t l6
uint64_t l7
uint64_t i0
uint64_t i1
uint64_t i2
uint64_t i3
uint64_t i4
uint64_t i5
uint64_t i6_fp
uint64_t i7
uint64_t saved_arg0
uint64_t saved_arg1
uint64_t saved_arg2
uint64_t saved_arg3
uint64_t saved_arg4
uint64_t saved_arg5
uint64_t pad0
More framing information is required in certain situaions such as when there are a large number of out parameters or when the callee must save floating point registers.
Field Documentation
◆ i0
uint32_t CPU_Minimum_stack_frame::i0
◆ i1
uint32_t CPU_Minimum_stack_frame::i1
◆ i2
uint32_t CPU_Minimum_stack_frame::i2
◆ i3
uint32_t CPU_Minimum_stack_frame::i3
◆ i4
uint32_t CPU_Minimum_stack_frame::i4
◆ i5
uint32_t CPU_Minimum_stack_frame::i5
◆ i6_fp
uint32_t CPU_Minimum_stack_frame::i6_fp
◆ i7
uint32_t CPU_Minimum_stack_frame::i7
◆ l0
uint32_t CPU_Minimum_stack_frame::l0
◆ l1
uint32_t CPU_Minimum_stack_frame::l1
◆ l2
uint32_t CPU_Minimum_stack_frame::l2
◆ l3
uint32_t CPU_Minimum_stack_frame::l3
◆ l4
uint32_t CPU_Minimum_stack_frame::l4
◆ l5
uint32_t CPU_Minimum_stack_frame::l5
◆ l6
uint32_t CPU_Minimum_stack_frame::l6
◆ l7
uint32_t CPU_Minimum_stack_frame::l7
◆ pad0
uint32_t CPU_Minimum_stack_frame::pad0
◆ saved_arg0
uint32_t CPU_Minimum_stack_frame::saved_arg0
◆ saved_arg1
uint32_t CPU_Minimum_stack_frame::saved_arg1
◆ saved_arg2
uint32_t CPU_Minimum_stack_frame::saved_arg2
◆ saved_arg3
uint32_t CPU_Minimum_stack_frame::saved_arg3
◆ saved_arg4
uint32_t CPU_Minimum_stack_frame::saved_arg4
◆ saved_arg5
uint32_t CPU_Minimum_stack_frame::saved_arg5
◆ structure_return_address
void * CPU_Minimum_stack_frame::structure_return_address
