CPU_Per_CPU_control Struct Reference
The CPU specific per-CPU control. More...
#include <cpu.h>
uint32_t isr_dispatch_disable
 This flag is context switched with each thread. More...
The CPU port can place here all state information that must be available and maintained for each processor in the system. This structure must contain at least one field for C/C++ compatibility. In GNU C empty structures have a size of zero. In C++ structures have a non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero, then this structure is not used.
Field Documentation
◆ isr_dispatch_disable
uint32_t CPU_Per_CPU_control::isr_dispatch_disable
It indicates that THIS thread has an _ISR_Dispatch stack frame on its stack. By using this flag, we can avoid nesting more interrupt dispatching attempts on a previously interrupted thread's stack.
