The Fatal Manager provides functions for fatal system states and or irrecoverable errors. More...
Files | |
| file | fatal.c |
| Invokes the internal error handler with a source of INTERNAL_ERROR_RTEMS_API and is internal set to false. | |
| file | fatal2.c |
| Invokes the internal error handler with is internal set to false. | |
| file | fatalsrctext.c |
| Implementation of rtems_fatal_source_text() | |
| file | interrtext.c |
| Returns a text for an internal error code. | |
| struct | rtems_assert_context |
| Assert context. More... | |
Typedefs | |
| typedef CPU_Exception_frame | rtems_exception_frame |
| Exception frame. | |
| void | rtems_fatal_error_occurred (uint32_t the_error) |
| Invokes the internal error handler with a source of INTERNAL_ERROR_RTEMS_API and is internal set to false. More... | |
| void | rtems_fatal (rtems_fatal_source source, rtems_fatal_code error) |
| Invokes the internal error handler with is internal set to false. More... | |
| const char * | rtems_fatal_source_text (rtems_fatal_source source) |
| Returns a text for a fatal source. More... | |
| const char * | rtems_internal_error_text (rtems_fatal_code error) |
| Returns a text for an internal error code. More... | |
| void rtems_fatal | ( | rtems_fatal_source | source, |
| rtems_fatal_code | error | ||
| [in] | source | is the fatal source. |
| [in] | error | is the fatal code. |
| void rtems_fatal_error_occurred | ( | uint32_t | the_error | ) |
| [in] | the_error | is a 32-bit fatal error code. |
References _Terminate(), and INTERNAL_ERROR_RTEMS_API.
Referenced by rtems_termios_device_close().
| const char* rtems_fatal_source_text | ( | rtems_fatal_source | source | ) |
The text for each fatal source is the enumerator constant.
| text | The fatal source text. |
| ? | The passed fatal source is invalid. |
| const char* rtems_internal_error_text | ( | rtems_fatal_code | error | ) |
The text for each internal error code is the enumerator constant.
| [in] | error | is the error code. |
| text | The error code text. |
| ? | The passed error code is invalid. |
