Thread_Wait_information Struct Reference
Information required to manage a thread while it is blocked. More...
#include <thread.h>
Collaboration diagram for Thread_Wait_information:
Collaboration graph
[legend]
union {
   Chain_Node   Chain
 A node for chains.
   RBTree_Node   RBTree
 A node for red-black trees.
Node
 Node for thread queues.
Objects_Id id
 This field is the Id of the object this thread is waiting upon. More...
uint32_t count
 This field is used to return an integer while when blocked. More...
void * return_argument
 This field is for a pointer to a user return argument. More...
Thread_Wait_information_Object_argument_type return_argument_second
 This field is for a pointer to a second user return argument. More...
uint32_t option
 This field contains any options in effect on this blocking operation. More...
uint32_t return_code
 This field will contain the return status from a blocking operation. More...
uint32_t timeout_code
 Code to set the timeout return code in _Thread_Timeout().
Thread_queue_Controlqueue
 The current thread queue. More...
Thread_Wait_flags flags
 This field contains several flags used to control the wait class and state of a thread in case fine-grained locking is used.
const Thread_queue_Operationsoperations
 The current thread queue operations. More...
This contains the information required to manage a thread while it is blocked and to return information to it.
Field Documentation
◆ count
uint32_t Thread_Wait_information::count
◆ id
Objects_Id Thread_Wait_information::id
◆ operations
const Thread_queue_Operations* Thread_Wait_information::operations
This field is protected by the thread lock.
See also
_Thread_Lock_set() and _Thread_Wait_set_operations().
Referenced by _Thread_Wait_restore_default_operations(), and _Thread_Wait_set_operations().
◆ option
uint32_t Thread_Wait_information::option
◆ queue
Thread_queue_Control* Thread_Wait_information::queue
In case this field is NULL, then the thread is not blocked on a thread queue. This field is protected by the thread lock.
See also
_Thread_Lock_set() and _Thread_Wait_set_queue().
Referenced by _Thread_Wait_set_queue().
◆ return_argument
void* Thread_Wait_information::return_argument
◆ return_argument_second
Thread_Wait_information_Object_argument_type Thread_Wait_information::return_argument_second
◆ return_code
uint32_t Thread_Wait_information::return_code
Note
The following assumes that all API return codes can be treated as an uint32_t.
Referenced by _CORE_mutex_Seize_interrupt_trylock_body().
