Internal structure used to manager per task variables. More...
#include <thread.h>
Data Fields | |
| struct rtems_task_variable_tt * | next |
| This field points to the next per task variable for this task. More... | |
| void ** | ptr |
| This field points to the physical memory location of this per task variable. | |
| void * | gval |
| This field is to the global value for this per task variable. More... | |
| void * | tval |
| This field is to this thread's value for this per task variable. More... | |
| void(* | dtor )(void *) |
| This field points to the destructor for this per task variable. More... | |
This is the internal structure used to manager per Task Variables.
| void(* rtems_task_variable_t::dtor) (void *) |
Referenced by _RTEMS_Tasks_Invoke_task_variable_dtor().
| void* rtems_task_variable_t::gval |
| struct rtems_task_variable_tt* rtems_task_variable_t::next |
| void* rtems_task_variable_t::tval |
