Executes a thread's cancellation handlers. More...
#include <pthread.h>#include <rtems/score/thread.h>#include <rtems/score/threaddispatch.h>#include <rtems/posix/cancel.h>#include <rtems/posix/threadsup.h>#include <rtems/score/chainimpl.h>#include <rtems/score/isr.h>#include <rtems/score/wkspace.h>#include <rtems/posix/pthreadimpl.h>
| void | _POSIX_Threads_cancel_run (Thread_Control *the_thread) |
| POSIX run thread cancelation. More... | |
| void _POSIX_Threads_cancel_run | ( | Thread_Control * | the_thread | ) |
This support routine runs through the chain of cancel handlers that have been registered and executes them.
| [in] | the_thread | is a pointer to the thread whose cancelation handlers should be run |
References _Chain_Extract_unprotected(), _Chain_Is_empty(), _Chain_Tail(), _ISR_Disable, _ISR_Enable, _Thread_Disable_dispatch(), _Thread_Enable_dispatch(), _Workspace_Free(), Thread_Control::API_Extensions, POSIX_Cancel_Handler_control::arg, POSIX_API_Control::cancelability_state, POSIX_API_Control::Cancellation_Handlers, POSIX_Cancel_Handler_control::Node, Chain_Node_struct::previous, POSIX_Cancel_Handler_control::routine, and THREAD_API_POSIX.
