This is used to manage each element (node) which is placed on a chain. More...
#include <chain.h>
Data Fields | |
Chain_Node * | next |
This points to the node after this one on this chain. More... | |
Chain_Node * | previous |
This points to the node immediate prior to this one on this chain. More... | |
Chain_Node* Chain_Node_struct::next |
Referenced by _API_extensions_Add(), _API_extensions_Run_postdriver(), _Chain_Append_unprotected(), _Chain_First(), _Chain_Get_first_unprotected(), _Chain_Get_with_empty_check_unprotected(), _Chain_Immutable_first(), _Chain_Immutable_next(), _Chain_Initialize_empty(), _Chain_Insert_unprotected(), _Chain_Is_last(), _Chain_Is_node_off_chain(), _Chain_Next(), _Chain_Set_off_chain(), and _Watchdog_Next().
Chain_Node* Chain_Node_struct::previous |
Referenced by _Chain_Append_unprotected(), _Chain_Get_first_unprotected(), _Chain_Get_with_empty_check_unprotected(), _Chain_Immutable_last(), _Chain_Immutable_previous(), _Chain_Initialize_empty(), _Chain_Insert_unprotected(), _Chain_Is_first(), _Chain_Last(), _Chain_Previous(), _POSIX_Threads_cancel_run(), and _Watchdog_Previous().
