Files | Functions | Variables
Workspace Handler
This handler encapsulates functionality related to the management of the RTEMS Executive Workspace. More...
Collaboration diagram for Workspace Handler:
file  wkspace.c
 Workspace Handler Support.
file  wkstringduplicate.c
 Duplicates String with Memory from the Workspace.
void _Workspace_Handler_initialization (Heap_Area *areas, size_t area_count, Heap_Initialization_or_extend_handler extend)
 Initilize workspace handler. More...
void * _Workspace_Allocate (size_t size)
 Allocate memory from workspace. More...
void * _Workspace_Allocate_aligned (size_t size, size_t alignment)
 Allocate aligned memory from workspace. More...
void _Workspace_Free (void *block)
 Free memory to the workspace. More...
void * _Workspace_Allocate_or_fatal_error (size_t size)
 Workspace allocate or fail with fatal error. More...
char * _Workspace_String_duplicate (const char *string, size_t len)
 Duplicates string with memory from the workspace. More...
SCORE_EXTERN Heap_Control _Workspace_Area
 Executive workspace control. More...
◆ _Workspace_Allocate()
void* _Workspace_Allocate ( size_t  size)
This routine returns the address of a block of memory of size bytes. If a block of the appropriate size cannot be allocated from the workspace, then NULL is returned.
Parameters
sizeis the requested size
Return values
apointer to the requested memory or NULL.
◆ _Workspace_Allocate_aligned()
void* _Workspace_Allocate_aligned ( size_t  size,
size_t  alignment
Parameters
[in]sizeThe size of the requested memory.
[in]alignmentThe alignment of the requested memory.
Return values
NULLNot enough resources.
otherThe memory area begin.
◆ _Workspace_Allocate_or_fatal_error()
void* _Workspace_Allocate_or_fatal_error ( size_t  size)
This routine returns the address of a block of memory of size bytes. If a block of the appropriate size cannot be allocated from the workspace, then the internal error handler is invoked.
Parameters
[in]sizeis the desired number of bytes to allocate
Return values
Ifsuccessful, the starting address of the allocated memory
Referenced by _Objects_MP_Handler_initialization(), and _Thread_MP_Handler_initialization().
◆ _Workspace_Free()
void _Workspace_Free ( void *  block)
This function frees the specified block of memory. If the block belongs to the Workspace and can be successfully freed, then true is returned. Otherwise false is returned.
Parameters
blockis the memory to free
Note
If block is equal to NULL, then the request is ignored. This allows the caller to not worry about whether or not a pointer is NULL.
Referenced by _Objects_Namespace_remove(), _POSIX_Message_queue_Delete(), _POSIX_Threads_cancel_run(), and _RTEMS_Tasks_Invoke_task_variable_dtor().
◆ _Workspace_Handler_initialization()
void _Workspace_Handler_initialization ( Heap_Area areas,
size_t  area_count,
This routine performs the initialization necessary for this handler.
References _Heap_Initialize().
◆ _Workspace_String_duplicate()
char* _Workspace_String_duplicate ( const char *  string,
size_t  len
Parameters
[in]stringis the pointer to a zero terminated string.
[in]lenis the length of the string (equal to strlen(string)).
Return values
NULLNot enough memory.
otherDuplicated string.
Variable Documentation
◆ _Workspace_Area
This is the heap control structure used to manage the RTEMS Executive Workspace.
Referenced by rtems_workspace_allocate(), rtems_workspace_free(), and rtems_workspace_get_information().
